Old 04-28-2014, 12:06 PM   #6211
KTM450SX
Oddometer: 416
I really am loving this 500exc!
Weekend camp and ride
Wheelie! I'm not a wheelie person but its so smooth and easy to loft it on this thing.
Got my first flat
Man the stock tire is junk! I only have 600 miles on the bike and the rear tire is basically done for. not much left of the knobbys on the rear.
Pretty much decided I hate my double take mirror I spend half the time screwing with it because it constantly moves or the ball comes unscrewed from clutch mount..there is no flat spot to tighten the ball in good. may try putting it in clamp and dremeling a flat spot so i can get a wrench of some sort on it.
2014 KTM 500 EXC
2007 KTM 950 Super Enduro
KTM450SX is offline   Reply With Quote
Old 04-28-2014, 12:26 PM   #6212
Medpilot
Oddometer: 65
So I ended up breaking my collar bone this weekend. I think I had my suspension set too stiff or I should say the compression dampening set too high. I hit a 6in divit in the trail which sent me flying. Here's the video.
http://youtu.be/8TpHUJN3KqA
Medpilot is offline   Reply With Quote
Old 04-28-2014, 12:38 PM   #6213
woodzrider
Oddometer: 592
OUCH! What were the settings?
Woodzrider AKA vetracer1
"If it can't kill ya-it's not a sport"......It ALMOST killed me tho.....
Check out my crash report:
http://www.advrider.com/forums/showthread.php?t=500314
Baja report http://www.advrider.com/forums/showthread.php?t=641219
woodzrider is offline   Reply With Quote
Old 04-28-2014, 12:44 PM   #6214
TwilightZone
Oddometer: 3,121
>"Pretty much decided I hate my double take mirror"
Do you have a 2" or 3" mount (ball stem) on it?
The 3" moves around. 2" stays put.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 04-28-2014, 01:03 PM   #6215
Medpilot
Oddometer: 65
Pretty much factory with the exception of my compression dampening. I think it was set A little stiff not sure of the exact setting.
Old 04-28-2014, 01:15 PM   #6216
MasterMarine
Oddometer: 1,625
2012 ktm 500 exc?
Use red loctite on the threads. You can also squeeze the bolt end with some pliers to deform the threads a bit. To tighten it, use the mirror. Line it all up to one side so you have max leverage to turn the ball part in. Then tighten it up. Hopefully that makes sense.
MasterMarine is online now   Reply With Quote
Old 04-28-2014, 01:19 PM   #6217
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,213
Nice!
Awesome slow-mo review too!
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 04-28-2014, 01:20 PM   #6218
Medpilot
Oddometer: 65
Oh I know, without the slow-mo, you can't really see what happens.
Old 04-28-2014, 01:21 PM   #6219
woodzrider
Oddometer: 592
I've been pitched in similar situations due to too little rebound dampening.
Stock settings may be ok for slower speeds but looks like you were hauling in the vid! Just my nickles worth tho!
Old 04-28-2014, 01:31 PM   #6220
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,213
here is a good explanation of the events.....
Ohhhh CRAP! What am I doing out here? In front of the bike!!!!!
Personal thoughts at this moment in time
"Did I turn off the oven........"
"Maybe I should get a puppy.....hmmmmmm"
ohhh, this isn't good.....
Old 04-28-2014, 02:11 PM   #6221
jtmajors
OCD with motorcycles
jtmajors's Avatar
Oddometer: 314
Originally Posted by jtmajors View Post
Went to install the KTM 5.0 tank today which to my understanding is made by acerbis and probably the same as the acerbis 5.3. When tightening up the fuel pump nuts on the bottom the tank I realized that the thickness of the plastic is smaller on this tank so even when the nuts are completely tight and metal on the nut is contacting metal on the fuel pump assembly it's still not tight enough because the thickness of the tank plastic is not the same. I looked at the stock tank and it's like twice as thick. Was the new tank supposed to come with more shallow nuts to connect to? Anybody else have this trouble?
RM warranty called me back today and they said their website is actually wrong and the KTM 5.0 tank they have only fits the Euro version and not the USA. So beware, just order the acerbis one.
2012 triumph tiger 800xc, 2012 ktm 500 xcw plated, 2010 wr 250x (sold), 2009 Crf 450r (sold), 2007 Crf 250r (sold), 2006 Triumph Daytona 675 (sold), 2001 yz 125 (sold), 2000 yz 250 (sold), 1997 yzf 600 (sold), 1996 cr250r (sold), 1992 rm 125 (sold), 1988 Yamaha Virago (sold), 1986 XR 200 (sold), 1984 cr 80r (sold), 1982 xr 80 (sold)
jtmajors is offline   Reply With Quote
Old 04-28-2014, 02:25 PM   #6222
Velociraptor
TrackBum
Oddometer: 1,122
Ouch! Good luck with the recovery. Hope you are back riding before summer is over. Are you getting surgery? I broke my collar bone when I was a kid-I went over the bars on a tricycle! Hit a water meter hidden in some grass....
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 04-28-2014, 02:27 PM   #6223
catalina38
Contrarian
Oddometer: 1,645
I use blue Loctite on the ball threads.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 04-28-2014, 02:30 PM   #6224
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,657
Dang, sorry to hear about injury. Do you run a damper?
Heal up!
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 04-28-2014, 02:58 PM   #6225
DirtWarrior
Oddometer: 77
Ktm 500 exc
Thanks for all the replies. Looks like I'll be looking more into the 500. I plan on doing some backcountry discovery routes, so will a 500 be fine for that type of riding? I've seen ride reports of guys riding small thumpers..
2014 KTM 500 EXC
2009 KTM 690 Adventure
2008 KTM 250 XCF-W ---Sold
DirtWarrior is offline   Reply With Quote
Times are GMT -7.   It's 06:35 PM.
