Old 04-25-2012, 01:46 PM   #976
jpdiller
Oddometer: 21
No "star" nut, It is a KTM part? looks like it is a taper fit. The puller matches up, in size, to the axle.The part that it replaces looks to be a taper fit as well? Gonna find out in a bit!
jpd
Still waiting on a couple parts, suspension is off and getting revalved, can't wait to ride this little monster!
Pics coming soon....
jpdiller is offline   Reply With Quote
Old 04-25-2012, 03:04 PM   #977
Lulu7404
Oddometer: 273
more switch info maybe...
So I found this great thread over on ktmt from E-ticket who is also on this thread. Regarding his 350 EXC. And another member pointed out this little tidbit. Just curious if the 500 is so different, that it doesn't hold true for us.
KTM parts told me that the 2012 EXC's need the map switch and the motor control unit. Price for both is $140.
The motor control unit mounts to the black plastic mount that is vacated when you pull that plug off to connect to the map switch. Do you have the motor control unit hooked up or just the map switch?
The directions for installation can be found at KTMPARTS.com under the map switch labeled downloads.
There are good photos of this in that manual.
See also Caltrex post on Map switch install for 350 EXC. He has pics there.
edit:
And yet another
No I do not have the motor control switch, nor have I got the KTM map switch.
I'm using the mild/wild plugs ($25) which probably represent setting 1(mild) and 9(Wild) on the motor control switch.
When I read those instructions it seems like the motor control switch allows more granularity and in combination with the map switch you can switch between whatever you set on the motor control switch and the standard map.
this was also from a 350 exc owner
14 Triumph Tiger 800
13 KTM 350XCF-W -- new hotness
13 KTM 250XCF-W -- hers
Lulu7404 screwed with this post 04-25-2012 at 04:31 PM
Lulu7404 is offline   Reply With Quote
Old 04-25-2012, 05:57 PM   #978
ridethedesert
Oddometer: 38
Originally Posted by ABYSS View Post
But he was talking about motorcycle oil buddy not automotive oil.
Understood. I haven't seen Mobil 1 in my offroad books. I only see it in the street books for V-twin motorcycles. That's why I thought he was talking about Mobil 1 for cars. Most of our customers buy Mobil 1 from Wal-Mart because it's cheaper.
ridethedesert is offline   Reply With Quote
Old 04-25-2012, 06:00 PM   #979
ridethedesert
Oddometer: 38
Originally Posted by Zuber View Post
What I was told at KTM Tech School - EXC and XC-W maps were the same and both were locked. They are both 'Green Sticker' and can't be modified. They both have only one internal map, no 'Soft Map', no 'Aggressive Map'.
Thanks California!
The SX and XCF maps are open, since they are not 'Green Sticker'.
JD Jetting 6x Tuner. $200, problem solved. No need for unlocking, dealer, will it work , blah blah blah. You leave it plugged in and can program away up to a 1,000 different possible scenarios/mapping.
Old 04-25-2012, 06:51 PM   #980
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,513
Added some KTM parts today - skid plate and some black plastic pieces. I also recovered the pan with a comfort seat. I feel like I'm just about done. Some simple bark busters and that's it.
I'll get two more good rides in before we go up the mountains.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 04-25-2012, 06:52 PM   #981
ridethedesert
Oddometer: 38
Just finished doing the LED conversion for those who are interested. When you change out your stock flasher unit, you must rewire the green blinker bulb in order for the signals to blink correctly. Sicass makes a little wire kit for it.
Sicass LED Front Turn Signals
Stock shifter was too short, the Hammerhead fits really nicely. Had to put a DID VT2 120 Link chain on the bike to clear my Maxxis Desert IT 120/100-18. My 500 came stock with a DID VT2, just without the gold and mine only had 112 links.
Old 04-25-2012, 06:54 PM   #982
ridethedesert
Oddometer: 38
Supermoto Wheels
Also picked up some Excel/Talon Supermoto wheels. 17x5.00 rear and 16.5x3.50 front. Might end up converting the front to a 17. I'll see how the slicks last on the street.
Old 04-25-2012, 06:54 PM   #983
Lulu7404
Oddometer: 273
THX! That is what Evil K has now that you mention that. I have it bookmarked but didn't realize it was different than map switch. Is that something that requires Dyno to tune or do they have preset settings? I will check their info... thanks again for the reminder about that.
Old 04-25-2012, 07:00 PM   #984
Lulu7404
Oddometer: 273
What are those tires, and how did you like them? I just ordered some Shinko 705's in 18/21 until I can scrounge up enough coin for SUMOs. Which might be a while after the 13l tank, bash plate, SICASS lights, and the invoice I got from HDB today for the whole shebang on the handlebars....
Old 04-25-2012, 07:34 PM   #985
APBlack
nOOb on a fly
APBlack's Avatar
Oddometer: 204
Ok I have a question as I have not tried the JD box yet... Isn't the JD Jetting 6x turner for adjusting the "fuel" map and the handle bar mount switch for switching between the "soft / aggressive" ignition map??
13 KTM 950 Adv Baja
11 Husaberg FE570S Swedish hotness
08 Husky SM610.. gone
06 KTM 950 Adv (orange one).. gone.. damit
05 Honda 650L.. gone
APBlack is offline   Reply With Quote
Old 04-25-2012, 09:15 PM   #986
helotaxi
Oddometer: 380
What did those run you? I also did the Sicass LED treatment but only in the rear.
helotaxi is offline   Reply With Quote
Old 04-25-2012, 10:50 PM   #987
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,943
The CPU has many maps that are overlaid on each other to get the final values for fuel and ignition. There is a temperature map, accellerator map, altitude map, and finally the aggressive/standard/soft maps that are overlaid depending on the external switch settings.
I believe the 'soft' effects the ign mostly. The aggressive effects both the ign and fuel. But, I also believe these are only available for the SX and XCF, not the XCW and not the EXC.
The JD Jet attaches between the CPU and the injector. It lengthens or shortens the injection pulse.
"Son, you can't do both"
Old 04-26-2012, 07:26 AM   #988
Honda_jedi
Oddometer: 8
Thumb Wheels/Tires/Hubs/Cush
Interested in 500EXC owners thoughts:... not that anyone has had to break into their clutch, but.
Through hours of internet and ADV research on the 500exc I'm obsessed- and need to buy one, though one detail I can't figure out - the new clutch incorporates "transmission friendly back-damping". I assume this is some type of cush mechanism, but what is it? I can't find any pictures or details anywhere. The KTM literature is vague, and I assume no one has had to put a new clutch assembly in their 500 yet to see what's actually going on...
There's definitely plenty of talk that the 500exc may not make the best adventure bike due to lack of cush drive rear hub, and some other small issues like fuel and oil capacity. Just wondering if KTM actually addressed the cush issue from the factory. Definitely something good to figure out before investing money in some Excels.
thoughts? would a cush drive still be necessary?
on a similar note: I also found that many street bikes incorporate rubberized front sprockets. Trying to figure out now if it's actually something that separates the middle from outer splines/teeth, or just rubberized to lessen chain noise. thoughts on that too would be great.
Honda_jedi is offline   Reply With Quote
Old 04-26-2012, 07:26 AM   #989
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,729
This statement taken alone, does not seem like it is in the right forum
toddler is online now   Reply With Quote
Old 04-26-2012, 07:30 AM   #990
toddler
Unpronouncible
toddler's Avatar
Oddometer: 2,729
The rubberized front sprockets are just extra rubber on a normal sprocket to cut down on chain noise. No tranny to rear wheel damping there.
Times are GMT -7.   It's 08:54 AM.
