04-26-2012, 04:56 PM
#1006 |
Huh???
Oddometer: 982
.................................................. .................................... NMOHVA.ORG - Help to keep your trails open! Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
04-26-2012, 06:38 PM
#1007 |
"What exit?"
Oddometer: 320
04-26-2012, 06:47 PM
#1008 | |
Oddometer: 38
04-26-2012, 06:49 PM
#1009 | |
Oddometer: 38
04-26-2012, 06:53 PM
#1010 | |
Oddometer: 38
The tuner plugs in under the seat. Run them both. |
04-26-2012, 06:54 PM
#1011 |
Oddometer: 38
I got the Excels on closeout for $615 for both the front and the rear. The front Sicass LED's are really easy. It's one bolt and plug. It was weird though that you have to rewire the indicator bulb to get the flasher to work properly. I'd never seen that before.
04-26-2012, 06:57 PM
#1012 | |
Oddometer: 38
04-26-2012, 07:01 PM
#1013 |
Oddometer: 38
Anyone ever tried or seen these? Its a cush sprocket. I'm not sure I would trust it.
http://www.kushsprockets.com/sprockets |
04-26-2012, 07:09 PM
#1014 |
Oddometer: 38
RLR Coolant Recovery Tank
Got my RLR CRT in the mail today. The guy I met had installed his on the rear left side panel. I didn't like that because it could get hit by the rear tire and you could see the bolts/rivets on the side panel. I chose to put mine inside the air box. Hose routing actually worked out really well.
(Yes I know this is a run on sentence)... I followed the breather hose for the fuel cap, then shot behind the frame over the rear shock, drilled a hole through the white airbox plastic, there was a nice black carrier inside as if ktm knew the hose was coming, wrapped it down around the air filter to the bottom of the tank, then out the top and over the battery back down and out the vent hole on the bottom of the air box. Anytime I filled the radiator so just the fins are covered inside, it will spill out through the overflow. All over my clutch case and my boots. Enough of that. This cost me $31 and should help keep more coolant in the system for those single track, Snowy Trail, days. ![]() ![]() ![]() ![]()
04-26-2012, 07:15 PM
#1015 |
Oddometer: 38
6x tuner
For those who may be interested, I mounted the 6x tuner on the air box panel/plastic. JD recommends the front right frame or the number plate. I don't want anyone seeing it so I like this spot better. It came with velcro so you can separate it from the panel if needed. I had to remove the factory sticker to mount the velcro. It wasn't water proof anyway. It already looked like crap.
04-26-2012, 07:59 PM
#1016 | |
Oddometer: 215
This sounds very similar to a plug-in for the Triumph Tiger I traded for this bike. I hope so. And the link to the Oregon site at the end of that great TT thread, is E-Ticket, the guy I mentioned up a few posts... he mirrored his thread from ktmt. may shoot him a PM while we are on topic. ![]() edit: and ridethedesert, thanks again for your contributions as well. I would love to hear your opinions of off idle, mild mannered riding conditions with the tuner. thanks
12 KTM 500EXC Lulu7404 screwed with this post 05-21-2012 at 02:04 PM |
04-26-2012, 09:20 PM
#1017 |
Allergic to Asphalt!
Oddometer: 6,087
Lots
, but I got a bit back for trading in the rear hub, it was practically new.
04-26-2012, 11:06 PM
#1018 |
Lost but laughing.
Oddometer: 4,641
Bought a RAD Cush hub built on an Excel rim for $820aud delivered to Australia from WWW for my Berg.
You can notice the smoother take up and ride on the bitumen and hard dirt roads.
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
04-27-2012, 05:31 AM
#1019 |
Oddometer: 8
Kushsprockets
ridethedesert • Yesterday 10:01 PM
Anyone ever tried or seen these? Its a cush sprocket. I'm not sure I would trust it. http://www.kushsprockets.com/sprockets Nice find. more research on that one to see if anyone has 1) put any kind of power through one (like 55hp/40 ftlb) and 2) that they at least last long enough for the chain ring to wear out. seems like a reasonable price when a steel sprocket is about $45, and one of the Supersprox combo sprockets is $90 or so. This is about $100 and says it has aluminum center section and steel chain ring. I'll see if anyone out there has ever validated the longevity of the 'made in china' quality... |
04-27-2012, 06:22 AM
#1020 |
Oddometer: 8
KushSprockets
http://www.thumpertalk.com/topic/879468-kush-sprocket/
mixed results all over different forums. sounds like a bad first batch of parts (late 2010, early 2011 timeframe). Subsequent better design. Though no one has reported more than 1000 miles. Two guys reported (one at 450 miles, one at 1000) that they were still going strong. Plenty reported they were still waiting on their product to be shipped. sounds like a halfway decent product with poor business management... Also, if you think about it, there's just not enough rubber in there to get the job done. Lots of load over a small area = rubber damper separation. And then again the other way to look at it is - why spend $10,000 on a machine and skimp on a made in China sprocket! I guess I had to reach down and find my berries for a second. $800 for a rear rim sucks, but a kush sprocket failure that takes out your swing arm would suck worse. |
