Old 06-30-2011, 10:35 AM   #106
Moto Vaquero
Trail less traveled
Moto Vaquero's Avatar
Oddometer: 91
What Tim said with pictures!
http://www.youtube.com/watch?v=XBaOUpw-aG0
I'm not day dreaming, I'm prerunning
Moto Vaquero is offline   Reply With Quote
Old 07-02-2011, 10:02 PM   #107
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 523
New EXCs,
Anyone heard how much oil the new exc motors hold with the single sump arrangement? Hope these new motors are tight....
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 07-03-2011, 05:59 AM   #108
gmtcm
KTM RIDER
Oddometer: 295
Oil capacity
This is right out of the Owners Manual for the XCF-W. It holds 1.6 Quarts or 1.5 Liters. of 10W/50
gmtcm is offline   Reply With Quote
Old 07-03-2011, 01:42 PM   #109
Magile
"What exit?"
Magile's Avatar
Oddometer: 320
2012 Owner's Manual here -
http://www.ktm.com/enduro/500-exc-eu/downloads.html
Magile is offline   Reply With Quote
Old 07-03-2011, 09:08 PM   #110
campfire
campfire's Avatar
Oddometer: 25
Originally Posted by timedpolaris View Post
2012 KTM 500 EXC Street Legal
Enough is never enough for all those who are forever seeking a little bit more, KTM has created the 500 EXC. Perfectly controllable power in extravagant proportions, low weight and an unsurpassed chassis characterise an enduro of remarkable versatility: a sensational fighting machine and absolutely reliable workhorse rolled into one, the indisputable benchmark in terms of weight and rideability. At any rate, there's no way to avoid to 500 EXC on the path to the podium in the E3 class.
NEW ENGINE
With the 500 EXC's newly developed engine, KTM engineers have created a new dimension: The power unit has been redesigned from scratch and is now more compact, lighter and more powerful than before. Reduced reciprocating weight and a balancer shaft minimise vibration.
NEW SILENCER
The 500 EXC's new, improved silencer not only offers greater volume and a new design, it also reduces noise levels to the stricter standards of the future.
NEW CYLINDER HEAD
All ports and the combustion chamber have been redesigned in the OHC cylinder head of the 500 EXC's new engine. The new camshaft actuates four valves via lightweight rocker arms. High-quality titanium valves are used on the intake side. As before, the cylinder head cover mounted at an angle simplifies service work.
NEW CYLINDER AND PISTON
The 500 EXC's cylinder has been further developed especially for the new engine configuration. The new, 15 % lighter forged piston minimises reciprocating weight and optimises durability at high engine speeds. New, nitrided piston rings ensure highest levels of resistance to wear.
NEW CRANKSHAFT
When designing the new crankshaft on the 450 EXC, KTM engineers focussed on reducing the reciprocating weight. Thanks to the new, lighter connecting rod and the new, lighter piston, they managed to achieve minimum vibration, while maximising engine-speed strength.
NEW ENGINE CASE
The 500 EXC's new engine case weighs almost 2 kg (4 lb.) less than its predecessor, although it offers better resistance to damage due to stone impact or falls. This has been achieved by using a high-strength, elastic aluminium alloy and changing from sand-casting to die-casting.
NEW BALANCER SHAFT
The 500 EXC's new, more compact balancer shaft not only eliminates vibration, but also serves as the drive for the water pump. This intelligent multi-functionality contributes to the compactness and low weight of the 500 EXC's new engine.
NEW OIL CIRCUIT
The 500 EXC's new engine is equipped with a common oil circuit for engine and transmission, and two oil pumps. A pressure pump lubricates the engine, while a suction pump draws oil from the crankcase, using it to lubricate the transmission and the clutch. At the same time and in conjunction with a steel diaphragm, negative pressure arises in the casing, which boosts the engine power.
NEW EFI/EMS
The newly developed Keihin engine management system with electronic fuel injection ensures spontaneous responsiveness from the engine. Various engine characteristics can be activated with an optional map select switch.
NEW CLUTCH
The 500 EXC's newly developed clutch, with a robust steel cage and transmission-friendly back-damping, makes use of a spring washer for the first time instead of the customary conical springs, hence substantially reducing the operating force. The hydraulic actuation mechanism from Brembo® facilitates sensitive modulation of the clutch.
NEW FRAME
The completely revamped frame made from high-quality chrome-molybdenum steel is characterised by even greater lateral stiffness. Furthermore, it is even better at absorbing jolts introduced by the suspension system, whereby the simple handling and comfort of the 500 EXC have been further optimised.
NEW SWINGARM, NEW PDS, NEW SETTING
The 450 EXC's new, lighter, cast aluminium swingarm accommodates the shock absorber more centrally, in order to load the swing arms more evenly. The new, 7 mm (0.28 in) longer PDS shock absorber with adjustable rebound and high/low-speed compression damping, and a new setting is installed more flatly, so providing even more progression.
TELESCOPIC FORK, NEW SETTING
The 500 EXC is equipped with the latest WP upside-down fork with wider adjustment ranges and a new setting. The sensitive responsiveness and outstanding damping of the open-cartridge fork with 48 mm (1.89 in) outer tubes are a perfect complement for the 500 EXC's simple handling and precision.
NEW WHEELS
Practically unbeatable in terms of weight and stability, the new wheels have CNC-machined hubs, Excel rims, zinc/nickel-coated spokes and aluminium nipples. They reduce the unsprung and gyroscopic masses, hence bolstering the simple handling of the 500 EXC.
BODYWORK
The 500 EXC's new bodywork with the very slim seat and spoiler lines, plus excellent contact points, perfects the bike's ergonomics, making handling even simpler and more precise. The longer rear fender protects the rider even more effectively from swirled up stones.
To much new,, I;ll pass..EFI, it will leave me stranded, no doubt.. I'm very hard on my offroad bikes..Don't trust it if I can't fix it..
I used to jog but the icecubes kept falling out of my glass
2010 KTM 'Special Edition" EXC 450R Street Legal.
2003 KTM 625 SXC (sold)
1985 Honda CR250R(sold)
campfire is offline   Reply With Quote
Old 07-03-2011, 09:13 PM   #111
team ftb
Befuddled Adventurer
Oddometer: 1,210
Very nice to hear. Thats 50% more than the old RFS motors.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 07-03-2011, 09:18 PM   #112
Bora20
Oddometer: 845
This is the same as the current 450/530 when both quantities are combined.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 07-04-2011, 06:52 PM   #113
SirJono_777
n00b adventurer
SirJono_777's Avatar
Oddometer: 14
Not quite, the RFS motors hold 1.2 liters.. So its only 0.3 of a liter more. Still more is good
SirJono_777 screwed with this post 07-04-2011 at 07:01 PM
SirJono_777 is offline   Reply With Quote
Old 07-12-2011, 12:23 AM   #114
Swede
Swede's Avatar
Oddometer: 0
Picked her up yesterday. Mounting blinkers and stuff tonight, tomorrow is testingday!
1000cc BMW, 2090cc KTM
Swede is offline   Reply With Quote
Old 07-12-2011, 04:20 AM   #115
touser
canned fruit
Oddometer: 325
Hubba Hubba
I know the voices arn't real, but they do have good ideas.
touser is offline   Reply With Quote
Old 07-12-2011, 06:04 AM   #116
gmtcm
KTM RIDER
Oddometer: 295
Attachment 276178
Please let us know about your first ride impressions
Old 07-12-2011, 06:09 AM   #117
blowout
on a mission
blowout's Avatar
Oddometer: 11
[QUOTE=gmtcm;16374429]Please let us know about your first ride impressions[/Q
BRAAAAAAAAAAAAAAAAAAAAAP!
2009 KTM 690 R
2009 DRZ 400 SM
2005 TW 200 SM
1985 ATC 70
1974 XL 350
blowout is offline   Reply With Quote
Old 07-12-2011, 06:23 AM   #118
Helikoptermann
bloody german...
Oddometer: 35
Attachment 276178
Man! This aint anything else but pure bike porn!
If it has tits or wheels it will bring you problems
Helikoptermann is offline   Reply With Quote
Old 07-12-2011, 06:32 AM   #119
roadholder
roadholder's Avatar
Oddometer: 1,985
Looks after all like I'm going to skip over the 530 series completely for my next purchase!
Doug
2006 KTM 525 EXC
2002 Yamaha FZ1
1973 Norton Commando & other old stuff
roadholder is online now   Reply With Quote
Old 07-14-2011, 01:29 PM   #120
axehead
Oddometer: 48
Sorry for the partial hi-jack but I just got my 2012 350 EXC-F.
I got a hard copy of the owners manual, and I know there is a soft copy here: http://www.ktm.com/enduro/350-exc-f-eu/downloads.html
But what about a parts manual, with the expoded diagrams and part numbers? I want to be able to print one out instead of referring to an online fiche all the time.
Anyone know where to find one?
Thanks.
PS - I thought a photo might increase my chance of an answer:
axehead is offline   Reply With Quote
Times are GMT -7.   It's 10:44 AM.
