Old 05-25-2012, 06:15 AM   #1306
Joby Rebel
Joby Rebel's Avatar
Oddometer: 34
I love this thread!!! Of course I love this bike:) My headlight is toast too with 28 hrs. Just put supermoto setup on it, Holy shit I'm in trouble:) What a kick in the ass. Thanks for all the awesome info.
45 acp; Turning human garbage into useful fertilizer since 1911
Joby Rebel is offline   Reply With Quote
Old 05-25-2012, 06:23 AM   #1307
Lulu7404
Oddometer: 273
sumo!!!
I'm about to cash in my penny jar for some SUMO's. Which set-up did you go with? Did you get a cush hub? Pics please.
14 Triumph Tiger 800
13 KTM 350XCF-W -- new hotness
13 KTM 250XCF-W -- hers
Lulu7404 is offline   Reply With Quote
Old 05-25-2012, 06:34 AM   #1308
Joby Rebel
Joby Rebel's Avatar
Oddometer: 34
I got the warp 9 wheels and contiforce tires. I wanted the mag wheels like in my avatar but I got these from a buddy with extra sprockets and a new chain and rotors and the 320mm front rotor and bracket, oh ya, and axle sliders for six hundred bucks from a buddy. And the tires still have the tits on them:) So I couldn't complain. I'll get some pics up in a bit.I put them on last night at about midnight so I dont have any pics yet but soon. Gotta have a little coffee:)
Old 05-25-2012, 06:44 AM   #1309
Joby Rebel
Joby Rebel's Avatar
Oddometer: 34
Well nevermind. Evidentally I am too new to post pics or somethin. It says at the bottom I may not post attachments. So thats GAY
Old 05-25-2012, 07:56 AM   #1310
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,728
My bulb went at about 30hrs as well.
toddler is offline   Reply With Quote
Old 05-25-2012, 07:59 AM   #1311
toddler
Unpronouncible
toddler's Avatar
Oddometer: 2,728
Nothing wrong with being Gay, but something wrong with not making a full effort to post pics. Give it some more effort sport. Let us know if you continue to have problems.
Old 05-25-2012, 08:35 AM   #1312
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,506
17 in wheel code
Cool - anyone know the code for a 17 in front? It comes setup for a 21. With 17's my speedo was way off.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 05-25-2012, 09:56 AM   #1313
Davonat
Oddometer: 24
Yeah....... I cant post pics of my bike either... Whats up with that?...
Davonat is offline   Reply With Quote
Old 05-25-2012, 10:02 AM   #1314
EVELKNIEVEL
EVELKNIEVEL's Avatar
Oddometer: 49
Cool2 wheel speed
Originally Posted by Colemanfu;[SIZE=2
18764707[/SIZE]]Cool - anyone know the code for a 17 in front? It comes setup for a 21. With 17's my speedo was way off.
Originally Posted by Zuber
To Set the 'Wheel Speed'... I don't think this is in the Owners Man.
Push the 'O' to display the 'H' (hours)
Hold the 'O' down 3-5 sec to go into the setup screen
Push the 'O' repeatedly to highlight the 'WS' (wheel speed in the lower left corner)
Push the '+' to select WS, the number '2205' standard 21" wheel dia is displayed.
Use the '+' or '-' to adjust the diameter in mm.
Push the 'O' to accept the value.
Hold the 'O' down to exit the setup and save.
Anyone check out the accuracy of the standard settings?
EVELKNIEVEL is offline   Reply With Quote
Old 05-25-2012, 10:02 AM   #1315
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,933
I found this. I have a set of 17's on the way for my 525, so I've looked around a little. Easiest way to find the circumference is by rolling it on the floor, not by applying the grade 8 mathematics below. Sloog of something wet on your tire, roll until you have two splooges on the floor, and measure between them.
I too have just bought a set of motard wheels for my KTM 450EXC (05 model) and was scratching my head as to how to change the Wheel Size setting. After reading your comments on this thread I went and tried just unplugging the 3pin plug that connects into the Digital speedo (the one that has the black, brown and red cables to it). I then just pressed the Mode "O" button to turn it on, then just got into the normal setup menu (holding the O button for 3 secs from the Speed/Hours display I think). The difference now with the cable unplugged is first there is no backlight (because the bike battery is unplugged), and second there is now a WS shown as one of the options.....so you simply press the "O" mode button until the WS option is flashing, then just press the "+" button once to go into the Wheel Size setup screen - it should be showing 2205 if it is still set as factory for a 21" front. Using the "+" and "-" buttons you can just adjust the wheel size to the correct circumference based on whatever you have installed. Note this includes the rubber. I have worked mine out to be about 1822 based on a 17" front rim with a 120/70R17 motard tyre on it. Once you have got the right number set, just hold the mode "O" button for about 3 seconds to save the setting. I then just waited for the unit to turn itself off and then plugged the 3pin cable back in and hey presto, job done.
I have only just done this change and haven't been out on the road to test it, but I will double check it against my GPS to see how accurate it is when take it out. If I make any changes I'll let you know.
For those who are interested in working out the exact figures, the measurements are in millimetres and you can calculate the circumference as wheel diametre (in mm) x pi
(pi = 3.14159265 approx). Hence working the 2205 backwards, a 21" wheel with rubber should have a diametre of about 701mm
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is online now   Reply With Quote
Old 05-25-2012, 02:13 PM   #1316
toddler
Unpronouncible
toddler's Avatar
Oddometer: 2,728
Lets see those pictures.....
http://www.advrider.com/forums/showthread.php?t=919
Old 05-25-2012, 10:16 PM   #1317
Davonat
Oddometer: 24
You can get a good replacement from Sicass or Enduro Engineering....... They are brighter too I replaced mine before it went. Also check the head light angle... mine was shinning way up into space... No bulb worked !
1 more thing..... careful with the O ring around the bulb holder.....They are 12 bucks at the dealer...U can figure out how I know this...I got spares. Sicass or EE also make an LED that will fit and it ROCKS.... except its not dimable, high beam only.
Davonat screwed with this post 05-26-2012 at 07:39 PM
Old 05-26-2012, 04:45 AM   #1318
HeadintheClouds
HeadintheClouds's Avatar
Oddometer: 43
Video link
Here is one of the video clips from a ride I took with 2 buddies around the NW corner of NC. The 500 never skipped a beat! More to come.
http://www.youtube.com/watch?v=TuhG66AFaUU
Hope you enjoy
HeadintheClouds is offline   Reply With Quote
Old 05-26-2012, 07:42 PM   #1319
308 Sniper
Oddometer: 9
2013 500 exc
OK,
I put a deposit on a 2013 KTM 500 EXC around 2 weeks ago. When are they scheduled for delivery to the US? The dealer says anytime between June and August. I need this bike now and am drooling over pics and vids. Great info guys. Now I need to save up more money to properly outfit it. This will be my first new bike purchase. Kinda sucks that I will have to upgrade it from the beginning just to make it run right, but I do know that it'll be worth it.
Oh, and btw I had to redefine my bike collection to be able to afford this. I just sold my 03 CBR600RR and have for sale my 02 KTM 640 LC4 enduro which it will be replacing. It took about a month for me to pull the trigger, but I know it'll be worth it after riding a 2012 500 around a month or so ago.
308 Sniper is offline   Reply With Quote
Old 05-26-2012, 10:13 PM   #1320
jpdiller
Oddometer: 21
Whats up everybody, still trying to figure out a solution for the scotts damper/steering stem nut clearance.....
I got something else for y'all, the big foot kickstand. How do you get the stock kickstand end piece off?
Happy riding everybody, hope you all are enjoying a long weekend.
JP
jpdiller is offline   Reply With Quote
Times are GMT -7.   It's 02:24 PM.
