Old 05-02-2011, 05:50 PM   #1
kglazer OP
Oddometer: 27
Just got a kymco super 9 ac and want t put a top case on
Hey guys im new to the forums and jsut picked up a used 2008 kymco super 9 ac from craigslist. i would like to put a top case on the back so i can store my helemet in their. Does anyone know where i can find one to fit or a diy on a custom install?
Thanks,
Kyle
kglazer is offline   Reply With Quote
Old 05-03-2011, 06:50 AM   #2
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,887
I have a Givi E35 Traffic (monokey) top case on a Givi E200 base plate. Others will tell you that Givi is way too expensive and go with something else. In my defense, the Givi I'm using now came with another one of my bikes (Honda TransAlp). I had to make a custom rear rack to support it. There are some top cases that are too small to store your helmet. So, know the general dimensions of your helmet if you shop on-line. Most manufacturers will state that a full-face helmet will fit (or not).
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is online now   Reply With Quote
Old 05-03-2011, 08:47 AM   #3
kglazer OP
Oddometer: 27
thanks Bronco638 would you mind putting a picture up when you get a chance of how you mounted it and what the custom rack looks like? please
Old 05-03-2011, 09:27 AM   #4
klaviator
klaviator's Avatar
Oddometer: 6,379
I put this EMGO top case on my Super 8. I got it from the scooter dealer for $60 although I believe retail is $75. I your scooter has a rear rack and you have a drill then this top case is a no brainer to install. My Fulmer modular helmet just fits.
I ride, Therefore I Am.
klaviator is online now   Reply With Quote
Old 05-03-2011, 10:23 AM   #5
kglazer OP
Oddometer: 27
that case looks rlly good. i looked up some reviews and many people said the plastic mounting base plate cracks while riding and the top case falls off. How has yours held up?
Old 05-03-2011, 10:26 AM   #6
klaviator
klaviator's Avatar
Oddometer: 6,379
No problems in 2000 miles. If you don't trust the plastic mounting plate it comes with a couple of metal bars that could be used to reinforce it.
Old 05-03-2011, 10:43 AM   #7
kglazer OP
Oddometer: 27
yeah thats true. Im gonna order the egmo one hoping it will fit my helemt lol. ill post pictures once its installed
Old 05-03-2011, 12:29 PM   #8
klaviator
klaviator's Avatar
Oddometer: 6,379
I don't know how big the rack on your super 9 is but unless it is fairly large, I would use the metal brackets that come with the Emgo to make the mount more sturdy. Then you won't have to worry about it breaking. Another option is to get a metal plate and mount it under the plastic rack.
Old 05-03-2011, 12:43 PM   #9
kglazer OP
Oddometer: 27
yeah im thinking the the metal sheet underneath is the way to go. this is what the rack looks like. I think i could dril into the rack and run the bolts through the rack if the holes line up. what do you think?
Old 05-03-2011, 12:43 PM   #10
kglazer OP
Oddometer: 27
heres another picture of the rack itself
Old 05-03-2011, 12:59 PM   #11
klaviator
klaviator's Avatar
Oddometer: 6,379
I would probably mount a metal plate using the bolts that hold the rack in place, or some longer bolts with the same thread. The plastic mounting plate has a bunch of holes and will be easy to mount to the metal plate.
Old 05-03-2011, 02:58 PM   #12
kglazer OP
Oddometer: 27
thats what i was thinking and to mount it closer to the seat so its not hanging off. klaviator could you take a pic with your helemet in it so i can see the clearance and see if my full face bell will fit in their? please
Old 05-03-2011, 03:17 PM   #13
klaviator
klaviator's Avatar
Oddometer: 6,379
I think that the shell on my Fulmer is larger than most since it has an internal sun visor. It barely fits in a Givi E46 top case. The dealer said that normaly 2 full face helmets will fit in the E46. Here's some pics:
Old 05-03-2011, 03:35 PM   #14
kglazer OP
Oddometer: 27
thanks my helmet will def fit then. i dont imagine 2 could fit in there but the more room the better i can put my joe rocket mesh jacket in their as well which is a plus
Old 05-03-2011, 03:58 PM   #15
kglazer OP
Oddometer: 27
im a little confussed. is the EMGO bigger then the givi e46. and do you have a problem clossing the EMGO with your helmet in? it looks like the top wont close based on the depth of the top half of the case
Times are GMT -7.   It's 06:54 AM.
