Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 05-02-2011, 07:18 PM   #1
inmate-n00b OP
Ciao, Marco
inmate-n00b's Avatar
Oddometer: 1,006
Cry Garmin Nuvi 550 cable no worky, tech support problems
I bought a garmin mounting cradle and the power cable stopped working.
My garmin unit is fine. I looked at the fuse and it didn't blow. I'm pretty sure that the transformer broke.
Here's the photo of the power cable here:
http://www.amazon.com/gp/product/B001CX4INE
I bought this thing in December 2010.
I thought that I would be able to replace it under warranty, since it didn't last long.
It doesn't look like Garmin wants to replace my power cable. Here's my email communication from Garmin tech support.
MY TEXT IS IN BLUE
GARMIN's TEXT IS IN YELLOW
I bought a "Garmin Universal Mounting Cradle with Power Cable 010-11143-07 893" for my nuvi 550. It no longer gives power to my Garmin unit. I know the Garmin unit itself is ok I am able to power it from my computer. The power cable does not work. I checked the fuse it did not blow. I need a new cable.
...*snip*
Thank you for contacting Garmin International, I am happy to assist you with this. The mounting cable you purchased comes with Bare wires so you can hardware your unit. If you are not getting power I would double check the connection of the wires to make sure they are getting a connection. If the car charger is not working, does the light come on. I know you said the fuse is not blown if this is the case then the charger would need to be replaced. You can get one through us for $25.00 or you can check Best Buy, Radio Shack, or Walmart and see if they have a cable.
The car charger is fine. The bare wire cable is not. It is not the battery terminal connections. It is most likely the transformer.
This should be covered under warranty. I just bought the cable a few months ago.
Thank you for contacting Garmin International, I am happy to continue assistance. What actual cable did you purchase from us? I tried looking up your name to find a work order and I don't find anything. What name do I need to be looking under? Was it purchased directly from us?
I purchased the mounting kit from amazon.com.
It is here:
I've attached a pdf of my order.
^^I went ahead and made a pdf copy of my amazon.com order.
Thank you for contacting Garmin International, I am happy to help. Have you contacted Amazon if it is not working since it was not purchase directly from us but from Amazon?
I have not tried that. I thought to go through Garmin, since that is the manufacturer.
I hope you are not blowing me off.
I checked on amazon.com. They only offer 30 day returns. Dang.
Thank you for contacting Garmin International, I am happy to help. No I am not blowing you off. If that is where it was purchased it may still be within there warranty and would need to be replaced through them.
With Best Regards,
It looks like now I'm s.o.l because I bought the thing from amazon??!!
The only thing I can do is buy another cable, which means more of my money goes to Garmin. That sucks.
WTF should I do?
inmate-n00b screwed with this post 05-04-2011 at 02:23 PM
inmate-n00b is offline   Reply With Quote
Old 05-02-2011, 08:02 PM   #2
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,736
I have the Garmin cable you had problems with on my ST1100, but one of these on my Bonneville
http://www.gpscity.com/gilsson-bare-...wer-cable.html
Honestly the Garmin one is much more robust, this Gilsson one doesn't include a fuse either. I haven't had any problems with either of the cables so far though
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 05-02-2011, 08:52 PM   #3
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
i've heard of some folks having problems with their transformers.
it hasnt even been a year and it stopped working.
i haven't done any hardcore riding with it.
this is so hella-lame....
Old 05-03-2011, 04:18 AM   #4
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 12,935
So did you contact the seller to see if they would warranty it?
But more importantly, did you take a voltmeter and check the connectivity and output at the connectors and fuse block to identify where the power ceases to flow? That would be the first thing to do.
dunno.....
Old 05-03-2011, 06:55 AM   #5
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
The power cable is definitely getting power. I checked.
Also, the fuse didn't blow.
I haven't checked the micro usb with my multimeter. It was hard to get to the pins inside. I will try again.
Another thing is that the transformer gets kinda warm. This isn't the heat from the engine.
Amazon will only accept a 30 day return. So it's too late.
The thing was manufactured by Garmin. Should there be a manufacturer's warranty?
I think I'm screwed.
Old 05-03-2011, 10:32 AM   #6
mcnut
Oddometer: 1,365
I have the same kit and so far it is working OK.
Garmin is usually very good about warranty items, I'm thinking the problem may be that at one time Amazon was a Garmin authorized dealer but may no longer be. If I remember correctly there was a notice about Amazons dealer status in the not to distant past. I just looked on Amazon at their listing for a Nuvi 500 and don't see a reference to any warranty that I can find.
I would contact Garmin again and in a very direct manner ask what the manufactures warranty is for this kit and why Garmin is not honoring that warranty. If they say you purchased it from a non dealer you may indeed be SOL, on the other hand how does Amazon have access to thousands of Garmin units if they are not a Dealer?
Bruce
mcnut is offline   Reply With Quote
Old 05-03-2011, 10:33 AM   #7
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
Ok. Thanks for the input, everyone.
I will replace the fuse, as well, and try again.
Old 05-04-2011, 02:33 PM   #8
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
Well I replaced the fuse and tried again and it still didn't work.
I asked Garmin about the manufacturers warranty.
What is the manufacturer's warranty on this item?
Thanks,
The mounting kit has a one year warranty. Please tell me was the mount working when you first installed it or has it never functioned. Also please send a copy of the receipt and a address where a replacement can be sent.
So that's nice! I wonder why they didn't tell me that to begin with. It was a different customer service rep this time, so maybe that's it.
I'm going to open up the transformer and see if there was a mechanical failure inside. If so, I need to rig a way to prevent this from happening again!!!! Maybe the vibrations or heat from the engine caused the thing to break.
The cable and transformer sit where the red arrow points to in the photo I attached (ignore the finger). It's between the airbox and battery. I was thinking of packing it in a plastic container with some styrofoam.
Any ideas? I guess I need to figure out what the problem was originally.
Old 05-04-2011, 02:35 PM   #9
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,736
Did you see this?
http://www.advrider.com/forums/showthread.php?t=683845
Mike S.
AMA MSTA
Old 05-04-2011, 02:43 PM   #10
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
I will clean the connections and try again.
I couldn't see any corrosion, but it's worth trying again.
I should cover the mini usb end, anyways.
Thx for the link.
Hopefully it's not the transformer.
Old 05-05-2011, 02:06 AM   #11
Mike955i
Mike955i's Avatar
Oddometer: 997
Purchased 3 of these for my Nuvi 550 and 2 died on their very first ride (950 ADV in Death Valley and 525EXC at the local OHV park). The one on my street bike works fine but I don't trust it now. Plus, the power wires are the smallest I've ever seen in an automotive product.
Same boat as you, past 30 days with Amazon, I just chalk it up to a hard lesson learned. I now have a direct wired 12v adapter with a dual USB plug epoxied in place (and dielectric grease in the usb ports). So far, so good.
FWIW, good luck........Mike
Just another Dharma Bum, drifting in the void
Mike955i is offline   Reply With Quote
Old 05-05-2011, 06:14 AM   #12
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,736
Are we talking about the same thing? The Garmin one I have has pretty heavy-guage wire
Now thw Gilsson one on my Bonneville...
Mike S.
AMA MSTA
Old 05-05-2011, 08:17 AM   #13
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
Do you know why they died?
Was it the usb connection or the transformer?
Old 05-05-2011, 04:45 PM   #14
Mike955i
Mike955i's Avatar
Oddometer: 997
Can't say, I was at DV when the first died and had to scramble a fix in the field. When the 2nd died I just removed it, no troubleshooting on my part.
Sorry.....Mike
Old 05-05-2011, 04:58 PM   #15
Mike955i
Mike955i's Avatar
Oddometer: 997
This..... http://www.amazon.com/Garmin-Hardwir...ef=pd_sim_e_10
Not the Gillson, looks to be the Garmin but I cant say 100%.
Times are GMT -7.   It's 06:35 PM.
