Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 05-05-2011, 05:37 PM   #16
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,758
Originally Posted by Mike955i View Post
This..... http://www.amazon.com/Garmin-Hardwir...ef=pd_sim_e_10
Not the Gillson, looks to be the Garmin but I cant say 100%.
Not the Garmin, see the first post in this thread. It has heavy guage wire and a mini-blade fuse holder included.
I have been unable to find the Garmin power wire for sale except in the "Universal mount cradle" kit I just mentioned.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 05-05-2011, 06:37 PM   #17
inmate-n00b OP
Ciao, Marco
inmate-n00b's Avatar
Oddometer: 1,006
I cleaned the connections with WD-40 and a brush and it still doesn't work.
I checked the fuse and it's fine.
I may replace the fuse, but I'm pretty sure it's the transformer.
Maybe it was the heat and/or vibration from the engine that killed the cable.
inmate-n00b is offline   Reply With Quote
Old 05-05-2011, 06:40 PM   #18
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
Purchased 3 of these for my Nuvi 550 and 2 died on their very first ride (950 ADV in Death Valley and 525EXC at the local OHV park). The one on my street bike works fine but I don't trust it now. Plus, the power wires are the smallest I've ever seen in an automotive product.
Same boat as you, past 30 days with Amazon, I just chalk it up to a hard lesson learned. I now have a direct wired 12v adapter with a dual USB plug epoxied in place (and dielectric grease in the usb ports). So far, so good.
FWIW, good luck........Mike
yes, the wires have a small gauge.
kinda fragile.
Old 05-06-2011, 09:15 AM   #19
mcnut
Oddometer: 1,376
Not the same as bird said. The Garmin unit in the kit has a 90 deg USB plug.
My Garmin kit has worked well but I think it has a parasitic drain even if not plugged into a GPS as my battery has gone flat after being parked for a month. My only complaint.
Bruce
mcnut is offline   Reply With Quote
Old 05-06-2011, 10:40 AM   #20
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,758
Yeah, I'm sure the voltage regulator always draws juice. I always hook my 60Cx up to the battery, but with the Nuvi I go to a switched source.
Mike S.
AMA MSTA
Old 05-06-2011, 12:38 PM   #21
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
Do you think that if the power was switched the cable would last longer?
Old 05-07-2011, 02:03 PM   #22
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
I cleaned the connections for a second time after a good soaking with wd40.
Still didn't work.
I took out the fuse and checked it. It looks good.
I took off the cap to the transformer. It looks ok. Should I stick the multimeter somewhere in here?
WTF?
Old 05-07-2011, 02:05 PM   #23
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
another pic, if it helps.
i'd like to know what went wrong so i can prevent it from happening again...
Old 05-07-2011, 07:12 PM   #24
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
multimeter
I hooked the cable to my battery and tested it with a multimeter. I measured ~12V DC going into the transformer and less than 1 V DC coming out.
It's supposed to be about 5V DC coming out. That's what it says on the back of the transformer.
Indeed, the transformer broke.
How do I prevent this from happening again? Insulate it from vibes and/or heat? Make it go to a switched source instead of always being on?
inmate-n00b screwed with this post 05-07-2011 at 07:30 PM
Old 05-07-2011, 07:14 PM   #25
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,758
Hard to say
Mike S.
AMA MSTA
Old 05-08-2011, 03:25 PM   #26
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
I asked Garmin how to prevent the power cable from breaking.
Their response:
I will gladly help with this issue. The cable from Amazon might have just being defective.
It was working for a few months. I don't think it was defective from the factory.
Old 05-08-2011, 04:59 PM   #27
250senuf
250senuf's Avatar
Oddometer: 2,401
It might. Others have posted that with the GPS off (off the bike even) the power cord still draws power. So maybe trying to feed a non-existent load shortens its life. Do you have any buddies who are electronics whizzes who could do a thorough autopsy on the dead one, re which component actualy failed.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 05-08-2011, 05:32 PM   #28
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
Moving the Garmin power cable to a switched lead may protect the power cable from the spikes and dips of starting the bike.
I will ask for help from some buddies in the local owners club.
Old 05-09-2011, 09:48 AM   #29
inmate-n00b OP
Ciao, Marco
Oddometer: 1,006
Ok..I can't do an autopsy because they put a lot of glue on the circuit board.
I asked garmin about hooking the power cable directly to the battery.
Probably my last question......was the power cable designed to be used in automotive and/or motorcycle applications?
Was it designed to be attached to a car or motorcycle battery?
Is it able to handle the power spikes and voltage dips from starting a car or motorcycle?
Their response:
Thank you for contacting Garmin International, I will be happy to help you with the unit that you have there and the power cable for the unit. The power cable was designed for use in the automobile and it is able to handle the spike of turning on and off the vehicle. It was not however designed to be plugged into a motorcyle as we have a line just for the motorcyle units called the Zumo's.
Sound like they don't really know what they are talking about.
Anyways, that's all I can do. Thanks for the help, folks.
Old 05-09-2011, 09:55 AM   #30
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,758
Bingo.
The Nuvi 500/550 is/was marketed as a "crossover" unit to be used for auto, hiking, boating and even scooter use. It even has a fucking scooter mode!
Also that exact same "universal mount cradle" kit with that cord is used for the Zumo 220
Mine works fine and now you have me pissed off at Garmin too
Mike S.
AMA MSTA
Times are GMT -7.   It's 04:24 AM.
