Old 02-14-2013, 06:15 PM   #331
Les_Garten
Les_Garten's Avatar
Oddometer: 732
Originally Posted by TINK View Post
Like so...
Thanx! That makes it clear!
Les_Garten is offline   Reply With Quote
Old 02-15-2013, 02:38 AM   #332
TINK OP
Oddometer: 732
The ultimate motorcycle
TINK is offline   Reply With Quote
Old 02-16-2013, 07:17 PM   #333
TINK OP
Oddometer: 732
Brakes are a PITA
Spent the day installing the front brakes and "trying" to bleed the rears.
The front brakes went together like a breeze. The rear, not so. Struggled to bleed the rears, finally pushed fluid back into the system from the caliper... this was going well, or so I thought, until the hose jumped off the tool and sprayed brake fluied EVERYWHERE!!!
OMG, what a mess.
Got that cleaned up, but peddle is STILL soft, shoot!!!
Put the project away for the night, pounded down a couple of beers, will figure this out later.
TINK
Old 02-16-2013, 07:39 PM   #334
Les_Garten
Les_Garten's Avatar
Oddometer: 732
What did you use to clean those discs up with?
Old 02-16-2013, 10:35 PM   #335
villageidiot
Oddometer: 1,994
Tink,
Fill the rear reservoir, hook a line up to the bleeder, put line in bottle. Open bleeder.
Wait for fluid to run out of bleeder into line.
Then just pressure bleed as normal, 3 pumps, hold down, open bleeder, pedal down. Close bleeder.
Make sure you wipe up the fluid mess with clean water or your paint will hate you.
villageidiot is online now   Reply With Quote
Old 02-16-2013, 11:04 PM   #336
groop
So much to ponder
groop's Avatar
Oddometer: 3,305
Tink, best use of an argyle sock....ever
Because you cannot eat a salad with a spork.
groop is online now   Reply With Quote
Old 02-17-2013, 06:39 AM   #337
TINK OP
Oddometer: 732
Die Grinder Disk Clean Up
Just hit then with a 2" sanding disk on my die grinder.
TINK
Old 02-17-2013, 07:57 AM   #338
Les_Garten
Les_Garten's Avatar
Oddometer: 732
TINK
Thanx!
Let us know if you "feel" that surface when you start riding. I have some surface grunge I need to get off mine as well.
Old 02-17-2013, 08:05 AM   #339
villageidiot
Oddometer: 1,994
You won't notice a thing after hitting it with a disc. First couple stops it'll bed the pads in, then it's smooth braking.
Can use a scotch brite disc. Or the actually make a brake surface prep disc.
Old 02-17-2013, 11:07 AM   #340
Les_Garten
Les_Garten's Avatar
Oddometer: 732
Thanx! I was thinking Scitchbrite, but will look into the surface prep disc.
The price of those rotors is staggering!
Old 02-17-2013, 06:34 PM   #341
TINK OP
Oddometer: 732
Just some pics at the curb
Sooooo close! I want to R I D E !!!
Front is done!
TINK
Old 02-17-2013, 06:39 PM   #342
TINK OP
Oddometer: 732
Pissed One step forward, one step back
After trying to bleed the rear brakes using every method known to man, I determined the master is the problem, RATS!
TINK
Old 02-18-2013, 10:27 PM   #343
TINK OP
Oddometer: 732
Rear Master Mystery
Okay BMW brake expert, put on your thinking caps...
So here's the question; should the new piston, with the cup shaped seal, have holes in the front like the old piston?
I'm thinking my problem is that with the new piston (no holes) I'm not getting brake fluid flow from the master reservoir to the brake caliper when I release the brake piston and it returns to the starting position?
This is the old piston I took out, note the hole in the seal grove
This hole goes through to the front of the piston, there are two of them.
This is the old seal, note that it is not cup shaped but rather it is rounded like an o-ring...
And this is the new piston with a cup shaped seal and no holes under the front seal.
Old 02-19-2013, 03:58 PM   #344
TINK OP
Oddometer: 732
Cry Just Whining Now
Broke out my rear master issue into a new thread here > http://www.advrider.com/forums/showthread.php?t=864352
TINK
Old 02-22-2013, 11:46 PM   #345
TINK OP
Oddometer: 732
Cool2 Final Push!
The weekend is finally here and I'm going to push to get PROJECT-S on the road, come hell or high water!
Next week there's a local CAFE bike ride in and I really really really want to ride PROJECT-S there > http://www.british-customs.com/readers_ride_show.pdf
TINK
Times are GMT -7.   It's 08:07 AM.
