Old 03-25-2012, 12:43 AM   #301
Cummo
Cummo's Avatar
Oddometer: 569
Avoid using Zipp Ties( most folks pull them too tight) on ICO cables, use tape or velcro the ties will damage the cable after a few hundred kms.
Cummo is offline   Reply With Quote
Old 03-25-2012, 12:22 PM   #302
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by beechum1 View Post
were you petrified?
Like an old tree
Just say'IN
crankshaft is offline   Reply With Quote
Old 03-25-2012, 12:27 PM   #303
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
were you petrified?
Don't worry, he will survive.
DR650 Wiki
NordieBoy is online now   Reply With Quote
Old 03-26-2012, 12:52 AM   #304
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Originally Posted by wrk2surf View Post
I just ordered this part. It should be here in a few days. One question. With this mount do you use the stock magnet, or do I need to putty one into the hub or will a fancy magnet bolt from touratech be needed?
My SPOT tracker link: SPOT
14' KTM 690R
13' R1200GS "Wasser Baby"
10' KTM 450EXC
84' Honda 500VT Ascot
RuckedUp is offline   Reply With Quote
Old 03-26-2012, 10:50 AM   #305
wrk2surf OP
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,692
Circlip and magnet
go into the rotor
This is my new rotor I am getting ready to install for the Mexican 1000 rally. It has a drilled out spot in the cooling cut (at 6 o'clock positon)
I dont know if you have an OEM KTM rotor with this done or what size it is. So you would have to use a drill press and the appropriate sized bit to drill yours out to fit the magnet set up you have. As you can see the hole "captures" the magnet and is held by the C clip.
hope this helps
wrk2surf is offline   Reply With Quote
Old 03-26-2012, 03:51 PM   #306
tileman
tileman's Avatar
Oddometer: 872
rare earth magnets?
Is it possible (a thought anyhow) to use rare earth magnets on either side of a hole similar to the disc above? I mean if a magnet can be found that is the correct OD to the hole in the disc and then used another 2, one on either side of the disc to hold it in place, wouldn´t that do it? I have a few of these and they have a lot of strength to hold themselves together. I would figure it would be enough for this use anyhow.
Thoughts?
there are lots of options with sizing;
http://www.ebay.com.au/sch/frenergym...id=p4340.l2562
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Old 03-26-2012, 09:03 PM   #307
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,465
Thoughts?
so you want to use magnetic force to hold the magnet in place? bad idea. use one magnet and epoxy it in place or use one of the magnetic rotor bolts.
Seth S
Seth S is offline   Reply With Quote
Old 03-27-2012, 03:05 AM   #308
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Drill the hole almost all the way through.
Lasted over 2 years so far. Would be better epoxied in but I've got a handful of them. I use them for sump bung bolts too.
Old 03-27-2012, 06:30 AM   #309
Seth S
Seth S's Avatar
Oddometer: 4,465
This method is better than using 2 other magnets to sandwhich the units in place by magnetic force. On a rally where you may live or die by the odometer I like to know my magnet is securely in place.
Seth S
Old 03-27-2012, 06:45 AM   #310
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
hence magnetic bolts
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Old 03-27-2012, 07:08 AM   #311
cross-country
cross-country's Avatar
Oddometer: 1,645
Here is another option, same as the stock KTM part, just a bit cheaper;
https://shop.enduroeng.com/cgi-bin/c...&category=90KT $12.99
"Magnet Kit with Snapring fits in Stock KTM/Husaberg Rotor"
You could also use one of these
http://sicassracing.com/store/produc...dometer_sensor $18.99
and one of these, to run two ICO's from one pickup.
http://sicassracing.com/store/index....roducts_id=329 $4.99
or buy the parts seperate from digikey
cross-country screwed with this post 03-27-2012 at 07:21 AM
cross-country is online now   Reply With Quote
Old 03-27-2012, 10:03 AM   #312
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Mags in the mail
Originally Posted by Brodovitch View Post
Funny, I was just at the touratech shop here in Athens, saw some (of various sizes) and thought of your brake line routing connundrum... check their online catalogue. If not let me know and I can pick some up for last minute tweaking before scrutineering
edit: over here
I just scored some mag bolts from Trailtech in the states. The lady who took my order was nice enough to give it to me with free shipping. I have also used some other Trailtech stuff and all have been quality parts.
So in a week or so I should have all the parts I need for the sensor pickup mounting. I also got a fuse block set up from Beaver Creek so its all coming together. Pretty soon all I will have to do is get on the boat in Venice and sail to Greece for the rally.(Like a Boss)
14' KTM 690R
10' KTM 450EXC
Old 03-28-2012, 12:21 AM   #313
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,106
My ico magnet makes the ktm speedo go haywire I might go a trail tech unit to replace the ktm one using the same magnet .
Mudguts is offline   Reply With Quote
Old 03-28-2012, 06:34 AM   #314
RuckedUp
RuckedUp's Avatar
Oddometer: 1,053
Brake line stripped and clamped
I got the brake cover off and still have all my fingers. How does it look now?
14' KTM 690R
10' KTM 450EXC
Old 03-28-2012, 09:26 AM   #315
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
cool, get some electrical tape and tape the sensor & brake line together, and, even better,
put some spiral cable protector over the result... pics tomorrow
TWOONEZERO
Times are GMT -7.   It's 09:55 AM.
