06-02-2011, 06:05 AM
#76 | |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
06-02-2011, 08:46 AM
#77 |
Oddometer: 869
Nice machining and design! But the only thing I don't like about the two recent bolt-on setups is that the bolts go straight back towards the bike. I've used mounting brackets like this in long rallies and the bolts sometimes get loose. Bigger and more bolts will minimize this, of course. Some of the more successful bolt-on mounting brackets wrap around the head tube a bit more and send the mounting bolts in from the side, so that the side stress on the bolts does not tend to loosen them so much. After messing around with several different options, I've decided that welding the bracket to the frame is the safest way to go.
Please keep posting photos. I'll try to dig up some more too. fun fun Charlie |
06-02-2011, 09:43 AM
#78 |
Rally addicted
Hey Charlie! For not loosing the screws you could put a hard rubber piece inside which takes up the vibrations. If this doesn't help you should use rubber+selflocking nuts+loctite and some of these little ones:
![]() They are called Nordlock washer. Quite an intelligent product: ![]() Normaly you only get them in a 100-pieces-box but KTM uses them for some really important screws eg. shift lever and you can order them seperately. |
06-02-2011, 07:21 PM
#79 | |
In the flow...
CSK & Loctite
Charlie said:
I went with smaller threads, to get more threads in the headstock tube and where possible I use CSK SHCS; countersunk socket head cap screws. Countersunk heads are self locking by nature and resist vibration and loosening to a far greater extent than flat head bolts. You will notice this is why they use countersunk nuts on touring cars (and maybe F1) cause they dont want the nut coming loose and the wheel falling off. It is obviously more of a PITA to drill AND countersink holes than just drilling a hole and putting a bolt in. However the reliability is greatly increased using countersunk heads. You just need to have the right tools used at the right speed to get a good countersink. Secondly, to be sure, Loctite, the real strong kind cause once that block is on it aint coming off. ![]() Cheers Pilbara |
06-03-2011, 12:14 AM
#80 | |
Oddometer: 730
If ignorance is bliss, why arenīt more people happy?????
06-03-2011, 12:16 AM
#81 | |
Oddometer: 730
![]() Pilbara, are you using fairings with this setup and do you have any more pics of this???
06-05-2011, 08:49 PM
#82 |
Oddometer: 869
Front of Neil's WR450. I've copied the dimensions of the JVO kit so the fairing and light will fit, but slightly different design. Hopefully strong enough now to withstand Neil's abuse.
06-05-2011, 08:50 PM
#83 |
Oddometer: 869
Front photo of that same WR.
06-06-2011, 03:59 PM
#84 | |
Oddometer: 730
Did you consider delrin round rod for the spacers between the centre spine and the side plates? From the specs I have found its about 1/3 the weight of most alloys without a massive loss in strength and being a polymer would likely have greater vibration resistance. Thoughts anyhow.
06-17-2011, 04:07 AM
#85 |
Oddometer: 874
How does everyone with the handlebar mounted setups get around the problem of the brake line banging up against the nav mount when the forks compress? On my DRZ I just put the line through a P clamp and allowed the line to bow out in front.
![]() Not perfect but it worked. any ideas? Or do I just tilt the brackets up further? A pic or two of my setup for Yilgarn. I have test ridden it and apart from the brake line issue it works really well. I really don't notice the weight but I haven't done 400 odd km on it yet ![]() ![]()
If a man does his best, what else is there?
06-17-2011, 04:23 AM
#86 |
Oddometer: 1,353
Route it straight up the fork leg and inbetween handlebars and roadbook;
=> http://www.eatdirt.nl/blog <= |
06-17-2011, 04:28 AM
#87 |
Oddometer: 874
Thanks mate
06-17-2011, 05:51 AM
#88 | |
Oddometer: 324
"Rally racing makes heroin addiction seem like a vague craving for something salty!" (Apologies to Peter Egan) The appropriate number of cylinders for any motorcycle is two. |
06-17-2011, 06:46 AM
#89 | |
Oddometer: 869
The DRZ looks good. Good luck. fun fun Charlie |
07-02-2011, 08:54 AM
#90 |
Reforming Neandertal
Oddometer: 866
The piece that is driving my design are the lights,
Baja Designs 4" and 6" and Hella 90mm, ![]() Seth mentioned a page or so ago that the BD Fuegos could be used in pod mode, they can! They're about perfect for what I want to do ![]() With the lights finally nailed down I could move on to the rest of the assembly, ![]() ![]() While riding over the last few weeks, I've been playing with where I want the roadbook mounted, I can't see squat with it down low while standing, but I don't want to sit every time I want to look at it, what are the real guys doing? ![]() I'll be making it so that I can run the bike with the whole assembly removed and stock headlight or just the fairing/lights mounted to the forks. I'll start with a Voyager that'll be staying on for all configs, the rest will bolt on and off depending on what type of riding I'm doing. ![]()
