Old 09-21-2012, 03:42 PM   #931
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
HA! My First RC car was a Tamiya Frog
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-21-2012, 04:00 PM   #932
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,827
Now lets have a break from the roadbook and go back to the NavTower...
Today I went and got the parts from the Lasercutting supplier... They are ready to go to the sheet bending facility and then maybe anodising ...
Girlfriend almost had me killed when she saw these parts on the table but anyways...
Here you can see the mark lines for the bending machine... I just hope the sheet benders do not mark these things... They are really beautifull. It is 50 series aluminium but it is so smooth, really rare to find here a good supplier...
The pivoting mechanism...
We had some troubles with the text so what was not done will either be an addon stencil or if I anodise the parts it will be engraved (basically remove the anodising so you can see white text on the black anodised part... )
The loT and below are the advmonster light supports. I made some new ones out of SS
And here is the Tamiya I was talking about ...
I will do a preliminary test on the Navtower even though it is not bended at least I could check if the height is right ...
gOOdnighT to all of you people,
-o0-
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 09-21-2012, 04:56 PM   #933
tileman
tileman's Avatar
Oddometer: 884
I got hold of a F2R roadbook and designed my own basically copying what they had done. I'd say they are pretty simple really and spare parts for it would be pretty easy to carry. They run with a couple of one way clutches which are easy enough to slip on and off.
My query is how different are the rolls? Would a roll that was used to the oz safari and then dakar and all the other events be that similar? Or is there in reality a specific standard that is used?
This thread is brilliant as it has so many people with ideas and the will to design and try stuff
If ignorance is bliss, why arenīt more people happy?????
tileman is offline   Reply With Quote
Old 09-21-2012, 05:13 PM   #934
Bluebull2007
Bluebull2007's Avatar
Oddometer: 5,261
Dreaming of Dakar
Everyone has a max speed, 90% of that max speed is much safer and easier, and if that 90% speed isn't fast enough at Dakar, you enter the snowball. - neduro
Bluebull2007 is offline   Reply With Quote
Old 09-21-2012, 05:57 PM   #935
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,837
Mine was a Tamiya Hornet
Old 09-21-2012, 07:33 PM   #936
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Tamiya Hornet here...
NordieBoy is offline   Reply With Quote
Old 09-21-2012, 09:52 PM   #937
tileman
tileman's Avatar
Oddometer: 884
In regards to the drive axles it'd be possible to design in Technic lego wouldn't it? The pulley knobs
can be glued onto the axles eg.
Run the spring as you say and then attach a pulley;
The motor can have to one way clutch pulleys on it therefore providing the drive.
The cartridge drive axles can intermesh with the lego axles and theres your drive, and to be honest they may be able to be made from lego parts as well.
Heres a motor that could be used depending on size requirements although rpm would be the limiting factor.
Since one of the ideas was to make it possible to fix nearly anywhere lego is pretty common all over the world. And if people are going to build this most of us would I figure have used lego in the past.
And some of use may still use it now
Old 09-21-2012, 10:10 PM   #938
wrk2surf OP
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,894
think sand dirt mud and crashing !
wrk2surf is offline   Reply With Quote
Old 09-21-2012, 10:13 PM   #939
tileman
tileman's Avatar
Oddometer: 884
Fairnouf. Though through this thread there has been some designs that took a different route, maybe the motor wouldn't work but the drive system may be an idea.
Also as per the ideas of using hdpe and the like it may be an easy way to design things just for trial, finding alloy/teflon rod etc isn't that easy sometimes.
Old 09-22-2012, 01:05 AM   #940
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
Following Dimitri's roadbook endeavours closely now, I agree with Seth that I'd rather pack a roadbook packed onto just a roller in my pack instead of a whole loaded cassette
Regardless, this thread should be awarded a medal
Oh, and a wee update on my post a few months back regarding the leather Leatherman pouch zip-tied to the fork tube: don't do it
After repeated power washings, the leather started to deteriorate and I was lucky enough to see my $120 flapping off the forks in the special of day 3 in Serres ...the zip ties had cut through the leather belt hoop. That said, I do believe that if I can source a nylon/cordura pouch it will be a non-issue
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Old 09-22-2012, 08:46 AM   #941
crankshaft
crankshaft's Avatar
Oddometer: 14,005
The Lego idea is brilliant, total out of the box thinking! You never know what won't work until you try it
Just say'IN
Old 09-22-2012, 08:48 AM   #942
crankshaft
crankshaft's Avatar
Oddometer: 14,005
My Cousin and I made it as far as 1/8 scale electric buggies and then bought dirt bikes a couple years ago. The R/C stuff sits on the shelf now
One more roadbook test shot from Unadilla.....
The Nav tower held up very well, I wish I could say the same for the Cycra hand guards
Just say'IN
crankshaft screwed with this post 09-22-2012 at 12:49 PM
Old 09-22-2012, 04:57 PM   #943
tileman
tileman's Avatar
Oddometer: 884
When I had lego it did spend a lot of time in dirt/mud/sand etc so the stuff has been tested to some degree. Probably by us all when we were wipper snappers
Old 09-22-2012, 05:01 PM   #944
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,837
Originally Posted by theantipaul View Post
Still working things out and will post up a link when it's all ready, but the aluminum variant complete bolt on with the plastic fairing less then $500, need to finish this first.
can't wait to see how it turns out!
I took my headlight mask off in anticipation
Old 09-22-2012, 05:42 PM   #945
crankshaft
crankshaft's Avatar
Oddometer: 14,005
I took my Pants off in anticipation
Just say'IN
Times are GMT -7.   It's 10:05 AM.
