Old 05-06-2011, 10:09 AM   #1
LaurelPerryOnLand OP
Oddometer: 2,416
How not to mount a FUEL PACK on your GS/GSA
Is it just me? Or...do you see a GLARING RED FLAG?
Hint:
Hint #2: Famous anthropologist RICHARD LEAKEY
Source: Website of Fuel Pack seller
UPDATE: Website has advised me that they will be changing the orientation of the fuel pack and updating their website.
Also...they'll be advising buyers NOT to mount spout over muffler.
Photobucket
LaurelPerryOnLand screwed with this post 05-06-2011 at 11:46 AM
LaurelPerryOnLand is offline   Reply With Quote
Old 05-06-2011, 10:27 AM   #2
Scottly
Oddometer: 128
And.......that's different from your gas tank how?
Scottly is offline   Reply With Quote
Old 05-06-2011, 10:51 AM   #3
rtortore
'00 R1150GS
rtortore's Avatar
Oddometer: 463
Send a message via MSN to rtortore
Question
I think he is talking about the spout from the fuel pack directly over the exhaust of the bike.
My concern is that unlike the gas tank the Rotopax may leak - like any plastic gas can, the cap can fail, and in this photo dumping fuel all over a hot muffler.
Will it happen? Likely not, can it? Sure.
I have however had a fuel line burst while riding and sprayed my right leg with gas while riding down the road ... over my leg and the right head/cylinder and thankfully no fire or boom.
Richard
"From the point of ignition
To the final drive
The point of the journey is not to arrive
Anything can happen."
rtortore is offline   Reply With Quote
Old 05-06-2011, 11:35 AM   #4
McFuryMcNugget
me specie in dea ist
McFuryMcNugget's Avatar
Oddometer: 499
its a good setup if it away from the pipe.
Or it could end like this ?
So Close Yet So Far.
McFury sending and spreeding out gas fumes inn Islandic Highlands.
What´s you gonna do when they come for you.
Whats next ? Man walking on the moon ?.
All typing is done with One Finger using a MacPro Computer.
McFuryMcNugget is offline   Reply With Quote
Old 05-06-2011, 11:45 AM   #5
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,096
I'd be more concerned about taking up my entire rack with one little can. It's also putting the weight in almost the worst possible place. For all these reasons, it's not an ideal mounting location.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 05-06-2011, 11:55 AM   #6
VEGASGSA
VEGASGSA's Avatar
Oddometer: 2,938
Hint:
Photobucket
Several things..It's in Florida..you would never be more than 10 miles from a gas station..It's (by the rack anyway) an Adventure..it already has 9 gallons in the tank...what in the hell would you need more for..in Florida...
I keed I keed...
The exhaust would blow the ruptured fuel to the rear..no problem..
Insert witty sig line here..
VEGASGSA is offline   Reply With Quote
Old 05-06-2011, 12:02 PM   #7
DGraham
Oddometer: 200
Not the best idea but
As long as sparks weren't shooting out your exhaust nothing much would happen. The auto ignition temp of gas is over 500 deg. F
But yes, looks pretty stupid like that, I'm sure at least their legal department would appreciate a picture with the can oriented differently.
DGraham is offline   Reply With Quote
Old 05-06-2011, 02:05 PM   #8
slartidbartfast
Oddometer: 4,096
Product liability lawyers of the world rejoice! You are keeping the world "safe" while stifling development, increasing costs and lining your own pockets.
Old 05-06-2011, 03:26 PM   #9
McFuryMcNugget
Oddometer: 499
I can tell you.
I have a lot of kolpin products and they are all good.
These fuel boxes have been in the atv market in Iceland for some time now.
My buddies have them and they are solid and safe.
The abuse is blistering cold winter and ruff rides on atv they are the best tanks on the market in Iceland
But as my picture above shows it does not mix well fuel and heat.
Take care.
Old 05-06-2011, 08:26 PM   #10
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,208
Not sure what the mounting location problem is weight wise? It's mounted on the rack that takes the place of the rear seat. I don't care how skinny your girl is, the gas can still weighs less at 6lb per gallon!
Probably want to flip it over so the cap is on the right side of the bike tho if possible.
AviatorTroy is offline   Reply With Quote
Old 05-07-2011, 06:25 AM   #11
Oddometer: 2,416
I can't stand FIRE. Why Post #1
Had my airplane in for an annual inspection. Picked it up and asked the mechanic if he'd 'run-up' the engine after the inspection. "Oh sure...everything is fine".
So...I take off from Milwaukee to Minneapolis.
Climb out to 12,000 feet and try to 'lean the engine' (reduce fuel flow since engine can't burn it at altitude).
Engine WON'T lean. Huh?
So...rather than messing around trying to fix...decide to have a mechanic look at in MSP.
Land...mechanic comes to plane...looks at COWLING over the engine and says "Did you just have an annual inspection done?" Holy crap...what does HE know?
Seems like mechanic really didn't run up airplane to confirm engine was operating properly.
Because...he failed to more than 'finger tighten' the injectors. Thus...fuel was leaking around the threads of the injectors and RIGHT past my MUFFLER.
Mechanic at MSP said "I was lucky to be alive". Had it been SUMMER...I probably wouldn't be writing this reply.
So...when I see things that I KNOW are dangerous...I try to point them out. Odds of happening with Fuel Pack...low?
Don't want/need even those odds.
Old 05-07-2011, 07:51 AM   #12
slartidbartfast
Oddometer: 4,096
Originally Posted by island808 View Post
so you don't have panniers, where else you gunna put it.
Where the hell would ANYONE be going where they needed extra fuel but did not need to carry any other luggage?
If you only want to bring a gallon of fuel home for your mower, there are easier ways - certainly cheaper.
Old 05-07-2011, 08:26 AM   #13
CrustyAPO
CrustyAPO's Avatar
Oddometer: 434
Send a message via AIM to CrustyAPO
So is the GS going to join the ranks of the Pinto, Crown Vics, and old GM saddle-tank pickups?
Yeah, and maybe I'm a Chinese jet pilot.
CrustyAPO is offline   Reply With Quote
Old 05-07-2011, 09:18 AM   #14
Farmer Palmer
Oddometer: 244
Fjorirhjol i Island med Kolpin!
Take care.
Yep, saw them on ATV's in Iceland about five years ago. A guy from Rekjavik had a 'fully loaded' yellow Can Am Bombadier 700(I think they had just been made road legal unless like me you're a farmer)
We went out with some Landrover guys 'Upp i Sveit' and it was the first time i'd seen a quad with all the gear in proper snow......! Very Impressive!
The Kolpin boxes seem to be a very good secure way to carry spare fuel.
I've usually carried 2x2 litre Touratech fuel cans on the rear of my Zega panniers for years but have always worried what if?
Then I started thinking about the 34 litres i've got between my legs.....!
Either way it could be messy........!
Now I don't need to carry any spare fuel since I changed my HP2E for a GSA again.
FP.
11 G650GS/FL, 10 GSA30
Farmer Palmer is offline   Reply With Quote
Old 05-07-2011, 10:13 AM   #15
Lensgrinder
Oddometer: 1,025
Worked with no problems or leaks.
Name:  Arctic Circle01.JPG
Pain is Temporary, but Quitting Lasts Forever!
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is offline   Reply With Quote
Times are GMT -7.   It's 07:03 AM.
