Old 05-06-2011, 06:19 PM   #1
DudeClone OP
DudeClone's Avatar
Oddometer: 1,798
Talking Scooter Exhaust Leak Help
Hey guys
My scoot is running fine, running great. Idle is good, performance good. Never stalls, dies, or quits. So this "sound" it's making, which is sort of a "gurgle thump thump," I figure is an exhaust leak, and a neighbor friend says the same.
Kymco Agility 125, much like any other gy6 125 with all the CARB stuff on it. My question is where should I check FIRST, and what is the most likely culprit? I have deduced the sound is not coming from the engine itself, but in and around the exhaust area, right side of the bike. No smoking or burning of oil, or performance issues whatsoever. So, I am going to take out my pet carrier and see whats up.
However while I know to check the header pipe at the manifold (forgive me if i get things wrong i am a newb) for a blown gasket, what if that is ok? Then where do I check, or what should I check FIRST instead?
Advice from anyone is fine. Doesn't have to be a Kymco or Agility owner as I figure this is fairly straightforward stuff. Also I assume before I loosen the header bolts or w/e to loosen the muffler mount bolts first, correct? That way the pipe will drop down easier. And maybe use a prop up thing for the muffler so it doesn't fall?
What else, guys? And thanks!
bikes
DudeClone screwed with this post 05-10-2011 at 05:06 AM
DudeClone is online now   Reply With Quote
Old 05-06-2011, 08:29 PM   #2
hexnut
Oddometer: 603
Guy I know has one that the exhaust has gotten louder but his only does it while accelerating. It doesn't do it at idle. He has not found the cause yet.
hexnut is offline   Reply With Quote
Times are GMT -7.   It's 08:20 AM.
