Old 05-07-2011, 06:42 PM   #1
ozranger OP
ozranger's Avatar
Oddometer: 7
smart phone gps' avalible in oz and reliability
hi
i am looking at getting a smart phone for navigation. has anyone had experience with this in remote areas where you won't be getting phone recieption?
any phones work better then others?
particular apps that are good?
cheers
ozranger is offline   Reply With Quote
Old 05-07-2011, 06:46 PM   #2
Hardhead
Hardhead's Avatar
Oddometer: 2,427
Originally Posted by ozranger View Post
hi
cheers
Apparently Garmin does one. I cant give you any details but I know some inmates here have them. GPS is separate to the phone bit so doesn't rely on the phone networks.
You think hiring a professional is expensive, wait until you hire an Amateur!
Hardhead is offline   Reply With Quote
Old 05-07-2011, 07:02 PM   #3
abhibeckert
abhibeckert's Avatar
Oddometer: 1,724
What type of riding do you do? What GPS features are you looking for?
I use MotionX GPS, it's great for trail riding but does not do driving directions and has a bit of a learning curve. There's lots of other software, though the ones with good australian map data that can do driving directions tend to be a bit expensive.
I'd definitely go for an iPhone 4 over any other choice, as it's much more mature. There are apps for everything from turn by turn navigation, to racing lap time statistics, to real time weather/rain maps, to suggestions for nice weekend rides. You can find a full list of navigation apps by clicking here. There are over 5,000 of them available in the Australian app store! If you have iTunes installed, click the "View Navigation in iTunes" link at the top right - it's much more organised than the website.
You will probably need to rig up some way to keep the phone charged while using it as a GPS, or else battery life will limit what features you can use.
abhibeckert screwed with this post 05-07-2011 at 07:24 PM
abhibeckert is offline   Reply With Quote
Old 05-07-2011, 07:05 PM   #4
abhibeckert
Oddometer: 1,724
This isn't really true. The 3G and WiFi radios are both used to get a significantly faster lock on your position than would otherwise be possible, and almost all of the freely available map data comes with license restrictions that lock you into using them when you have 3G coverage.
You can use it outside of 3G, but only with some apps, and even then a few features usually won't work (eg: finding directions to the nearest KTM dealer or SPOT style location updates).
Old 05-07-2011, 07:31 PM   #5
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,890
A "Smart phone" may also be a bit fragile for your purposes, depending on what you do. I've seen so many broken in the first 3 months of ownership it is not funny, and that is without them being strapped onto a set of handlebars either. They are not shockproof or waterproof. The ones with a dedicated GPS chip (SIRF III-compliant usually) should work when out-of-range, but as stated above an application and data will be required.
All up, they are expensive and delicate electronic gadgets that I would hesitate to use as a navigation tool in out of the way places. A dedicated GPS is prolly a cheaper and better bet. For more info have a browse of the Layin' Down Tracks forum off the main page, it has lots of good info there.
My 2c.
GodSilla is offline   Reply With Quote
Old 05-07-2011, 08:39 PM   #6
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,123
Hardhead is referring to the Garmin Asus A50 Nuvifone which has a separate GPS that also has a smart phone running Android 2.2 on it .
Runs Garmin maps just like a normal GPS off of the satellites or can run maps off phone app if you would want to.
Very happy with it so far and comes with car cradle etc. I use it in the car and have a Oregon 300 for the bike. Agree with Godsilla's comments. If you were touring and could mount it in a waterproof case on the bars then I think it would be okay, or carry it with you etc.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 05-07-2011, 08:41 PM   #7
abhibeckert
Oddometer: 1,724
?!? the iPhone 4's case is high strength glass and metal. Both are stronger than the plastic used on cheap "shockproof" GPS devices, waterproof is easily solved with a waterproof case, which also eliminates any chance of shattering the glass. I have dropped my iPhone 4 on concrete from 1 metre at least 10 times (without any protection at all), and crashed my KTM several times (with a protective mount) and it barely has a mark on it. Sure, it's not the most solid product out there but it is as good as it can be with the size/weight goals they have.
I would also trust apple's engineers to do a better job of designing and sourcing reliable components. They probably spend more time/money designing the iPhone's on/off button than Garmin spends on their entire product line. Apple has $65,000,000,000 in revenue to work with, vs garmin's $3,400,000 and the iPhone is Apple's most important product, while Garmin's most important product is their car GPS systems. Apple has a team of some of the highest paid engineers in the world working around the clock for about two years on each new version of the iPhone (when they release a new version, they've usually already been working on it's successor for a year). Garmin does not put that much effort into any of their products.
To give you an idea how high their standards are, apple just delayed the white iPhone by over a year because it didn't pass quality control (something to do with the colour changing slightly when exposed to several months of normal use). Garmin probably doesn't even bother testing for things like that. Sure, you and I might not give a **** about the colour of a device - but that close attention is applied to every aspect of the product.
I'm an iPhone software developer and have access to videos presentations by apple's engineers. Having watched them talk for many ours about the GPS technology in the iPhone, it's clear that they take GPS very seriously and are spending a lot of money and inventing a lot of new technology in the area. I wouldn't be surprised if they spend over a hundred millions of dollars a year on improving the iPhone's GPS feature set.
abhibeckert screwed with this post 05-07-2011 at 08:53 PM
Old 05-07-2011, 08:48 PM   #8
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,123
All their millions hasn't done much for all the screens on the guys work i phones that have cracked then, many from small falls or in pockets. You can't really be serious anyway after the stuff up with the phone reception on the i4 and the metal case. Just because they have money to spend does not mean they always do things well, and usually the more money they make the worse that becomes.
Think IBM, Microsoft, GM, Ford etc.
xronly
Old 05-07-2011, 08:59 PM   #9
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,890
I'm with Cruz here, busted screens seem to be a general Smart phone malady.
Maybe the iphone has a better one?? I couldn't say personally, but I treat my mobile phone like I treat my gps, a single-function device. I don't need (or want) blueteeth, mp3, photo's, voice commands, movies, camera, or any of that other peripheral stuff. Having said that, my son handed me one of his expired phones, and it does blueteeth in my car, so at that level it saves a hands-free kit if you like jabbering whilst driving (I don't).
Old 05-07-2011, 09:58 PM   #10
abhibeckert
Oddometer: 1,724
Sure, you can crack the screen on an iPhone if you drop it and it lands in a bad way or if you sit on it. None of those type of impacts will happen if it's in a good quality case attached to a bike's handlebars. Lots of people (like me) have abused their phones and not had it break, but you rarely hear those stories.
I've seen plenty of people in the Layin Down The Tracks section talk talk about replacing/repairing their GPS under warranty or outside warranty, so you're not necessarily safer by getting a unit purpose built to be exposed to elements and vibration.
I am serious, and for what it's worth the iPhone 4 gets better reception than any previous model iPhone (and no-one was complaining about their reception). This has been demonstrated over and over again by engineers who work in the field. Don't believe everything the media tells you, most of them have no idea what they're talking about. Here's what a team of independent phone engineers have to say about it:
AnandTech also found out that while the iPhone 4 suffers from its external antenna design, it also benefits greatly from it. In areas with very low signal (-113 dBm), the iPhone 4 performs much better than the iPhone 3GS. "I can honestly say that I've never held onto so many calls and data simultaneously on 1 bar at -113 dBm as I have with the iPhone 4, so it's readily apparent that the new baseband hardware is much more sensitive compared to what was in the 3GS. The difference is that reception is massively better on the iPhone 4 in actual use."
They have a damn good track record for getting this stuff right though.
abhibeckert screwed with this post 05-07-2011 at 10:04 PM
Old 05-07-2011, 10:00 PM   #11
lout
AYCIC
lout's Avatar
Oddometer: 769
Originally Posted by abhibeckert;15856633
I would also trust apple's engineers to do a better job of designing and sourcing reliable components. They probably spend more time/money designing the iPhone's on/off button than Garmin spends on their entire product line. Apple has $65,000,000,000 in revenue to work with, vs garmin's $3,400,000 and the iPhone is Apple's most important product, while Garmin's most important product is their car GPS systems. Apple has a team of some of the highest paid engineers in the world working around the clock for about [B
two years[/B] on each new version of the iPhone (when they release a new version, they've usually already been working on it's successor for a year). Garmin does not put that much effort into any of their products.
If they are so good how come they fucked up a simple thing like the aerial on the iphone 4? lack of testing or just plain lack of care?
Lout.
TASMANIA - Explore the corruption.
Orange paint and 37 clicks of suspension adjustment doesn't make up for being a shit rider :j Mo
It's not that I don't believe in God..I just believe in one less God than you.
Monsanto - The evil that keeps on growing
lout is offline   Reply With Quote
Old 05-07-2011, 10:14 PM   #12
abhibeckert
Oddometer: 1,724
They didn't test it by watching the "bars" as you hold the device in different ways. They tested it by checking if you are able to make phone calls while holding it in different ways, and in that test - the iPhone 4 has the best antenna they have ever sold.
Anyway, we're getting waaay off topic. The original question was whether or not anyone has experience using a smart phone as a GPS in remote australia. I've got lots of experience doing exactly that, and it works great!
The only issue I've ever had is over-heating, if you leave your phone turned on in harsh sunlight for hours on end it will show a temperature warning and turn itself off. After being off for a short time (even while still in harsh sunlight) the phone will begin to work again. I'm still playing around with this, but it seems like turning the screen off during extended periods of full sun riding is good enough. It probably doesn't happen while riding fast either, as the wind is enough to keep it cool. Something to be aware of, but not a deal breaker by any means.
abhibeckert screwed with this post 05-07-2011 at 10:27 PM
Old 05-07-2011, 10:48 PM   #13
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,123
So, how do you get on with no phone reception in the remote areas?
xronly
Old 05-07-2011, 11:01 PM   #14
Copie
The resident new guy
Oddometer: 207
With an ip4? mine works fine without reception (also works fine on my wifi only ipad2) just takes a few seconds longer to acquire a signal.
2010 DR650SE
Safari Tank, B&B bashplate/rear rack, Eagle 360mm Screen, Corbin seat, Front + Rear suspension rebuilt w/ RG3, Pivot Pegz, VSM Lowering brackets, MT90 A/T F+R.
Link to pics
Copie is offline   Reply With Quote
Old 05-07-2011, 11:48 PM   #15
guzzimike
guzzimike's Avatar
Oddometer: 1,400
You don't need phone reception, it works just like any other GPS.
I have an Iphone 4 with the Tomtom app, it's the best damn GPS I have.
(2 Garmin Nuvis, 1 Garmin 60cx)
Can't tell you what it's like on the bike as I use the 60cx ATM for that.
Armageddon Was Yesterday, Today We Have a Problem
East is East & West is West 2008
http://www.advrider.com/forums/ad.php?t=400050
A Long Weekend 2009
http://www.advrider.com/forums/showthread.php?t=523893
All the Way to Nowhere & Back Again. 2010
http://www.advrider.com/forums/showthread.php?t=619683
Save 5 bucks on your Smugmug, use my discount code
hQo9Atub1N9jg
guzzimike is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 06:02 AM.
