Thread Tools | Search this Thread | Rate Thread | Display Modes |
05-08-2011, 12:01 AM
#16 |
Lost but laughing.
Oddometer: 4,641
Does it burn your batteries a lot quicker or do you have the phone wired in to the bike?
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
05-08-2011, 12:12 AM
#17 | |
DR650 All the way
Oddometer: 109
Good phone for a fashion tragic.. |
05-08-2011, 12:35 AM
#18 | ||
The resident new guy
Oddometer: 204
) , gets dropped out of my top pocket, used for hours on end, then gets strapped to the bike for trips away. Zero marks on it (the screen protector is a bit marked though from sitting in my pocket with keys) but if i replaced that for the 10 bucks it cost me it would be like new again.Without a case and a screen protector they are easy enough to break, but most phones are like that now (except for the 6300/C5 they are bulletproof)
2010 DR650SE Safari Tank, B&B bashplate/rear rack, Eagle 360mm Screen, Corbin seat, Front + Rear suspension rebuilt w/ RG3, Pivot Pegz, VSM Lowering brackets, MT90 A/T F+R. Link to pics |
05-08-2011, 03:57 AM
#19 |
I Ride Ms Piggy
Oddometer: 1,800
OK here is my $0.02
I have a coupla Garmins, Nüvi and a Zumo. Plus others no longer used, or broken. Plus a couple of GPS receivers hooked into a laptop with moving maps etc... And an iPhone 4 with Sygic Moving Map - it is the iP4 that is by far the best GPS interface that I have ever used. It is fast, very fast to load, to run to update, and accurate. Faster than some dedicated GPS units with the same software. Now let's kill a myth. If the GPS software comes with its own mapset (as does the Sygic moving Map) it DOES NOT NEED 3G ACCESS. It will work all by its sorry self out of phone contact with any phone network. iPhone's proprietary map system needs to download a mapset and will not work outside of a phone network. The GPS chip in the phone is as good as any, if not better. Will even work inside my house when no other GPS unit that I have will work. I have used the iPhone on the bike in its own mount and it works very well. However, vibration is going to kill it - you can see that. And you have to turn the acceleration sensor function off somehow - the acceleration of the bike and vibration makes the screen flip upside down and inside out. Amusing to watch, but not practical. I have a waterproof USB charger plug installed that charges the iPhone while I am riding - so power not an issue. The iPhone goes into a waterproof handlebar bag, but after the last trip which was liking riding in a perpetual waterfall I am also putting the iPhone in a waterproof rolltop bag... Not real good as a primary GPS, only because of vibration. Very good as a backup. If you can get around the vibration and jarring by all means go for it - there are few better units that I know of that will do the job as well or better... viz |
05-08-2011, 05:36 AM
#20 |
Oddometer: 280
Another vote for the iphone4 :-), I have a oziexplorer gps and a nuvi in the landcruiser... But prefer using iphone's mudmap ( in the place of oziexplorer) and Telstra's navigator(build by garmin) instead of the nuvi... Just one mount, one cradle, one power cable and can swith to whatever navigation app I need. I am currently in paris, and disabled 3g to prevent data charges.. So I will use the wifi in the hotel and "browse" the googlemap app arround where I am to download the maps and then start walking...
Yamaha Tenere Dress like you going to fall..... then don't! |
05-12-2011, 01:38 AM
#21 |
Oddometer: 7
well that was a big 'can o worms' i just opened.
thanks to everyone for your input. i have been doing a lot of research and i think i might go for the motorola defy. water proof to 1m (they say water resistant, but the pressure rating should be 1m) dust resistant, shock/scratch resistant. there seem to be some good android apps for pre loading maps, and as this is an emerging speciality for phones i can only imagine it will get alot better as the mapping companies try to cash in on the apps. i will avoid the i phone simple because its a bit more expensive (going OS so don't want a plan) and don't like apple that much. i view apple as a bit of an oppresive dictorial government. they restrict everything you do (e.g. no blue tooth to stop file sharing, don't get me started on itunes) and keep tabs on everything you do. just think they love money a bit too much!!! i know, what company doesn't? but i like the android freedom. thanks to everyone for thier very helpful imput
05-12-2011, 03:20 PM
#22 | |
Nipple boy
Oddometer: 4,101
If it says IPX 5 or IPX 54 then I would not buy on that (low) level of water resistance . |
10-27-2011, 09:43 PM
#23 |
Still trying
Oddometer: 659
Mudmap app
Bumping this thread to enquire if anyone has come across a new GPS app for iPhone that they would recommend for using on the bike? Is there one that is able to have tracks/routes installed?
I have used the Metroview app and had the iPhone in the tankbag map sleeve, and that works fine, but it is a basic app that can't do routes. Thanks I found this one - and TBAM mentioned in latest issue they are doing a review of it. http://www.mud-maps.com/ ![]() Leave your mark... Wouldn't it be great to have a constant recording of your every movement so you can retrace your steps if you ever get lost. That's exactly what the MUD MAP Tracklog feature does! It automatically records your movements and displays them as a trail on your map. It also gives you the option to save just a snippet, or the entire length of your journey. http://www.mud-maps.com/images/apps/...forgetable.png Unforgetable. Have you ever discovered a great camp site or spot during your adventures and struggled to find it the next time? That will never happen again... With MUD MAP, you can use the Waypoints feature to mark any spot on your map, so that you can find it again and again, time after time. You can even share your spots with your friends using the mCloud social features. What are you waiting for? There is also a 4x4 GPS app they do. OK - they also have a 4x4 GPS app @ $199 http://www.vms4x4.com/product-iphone-vms_app Some description from the itunes store THE VMS APP IS BUNDLED WITH COMPREHENSIVE 4X4 MAPS. SmartTOPO™ - TOPOGRAPHIC MAP OF AUSTRALIA Gregory's™ - TOURING & ACTIVITY MAPS ADD YOUR FAVOURITE MAPS • Provides flexibility to add over 3,000 raster maps. • Purchase online and download instantly. • Raster maps are digitized versions of the original paper maps from Australia’s leading map makers such as GeoScience, Westprint, Vicmap and many more... • Preview the entire range for free from www.mud-maps.com. Purchase and download immediately for use with the app. _______________________________________ WAYPOINTS & TRACKLOGS • The tracklog feature records your every move & overlays your movements on a map. • Mark locations of interest with waypoints, like a great camp site. _______________________________________ mCLOUD™ - ACCESS YOUR TRIP DATA ON ANY MAC OR PC • Effortlessly transfer Waypoints & Tracklogs from the app to your account. • No cables, no memory cards, it's all wireless & it just works. • Review & edit from any PC or Mac. • Simple enough for anyone to use. _______________________________________ WHERE AM I™ - GETTING LOST IS A THING OF THE PAST • Displays your position in real time on the map. • Current Speed, Altitude, GPS Co-ordinate & accuracy. EDIT: I received this email advise when I enquired about track/route options. // Add your reply above here ================================================== From: Tech Support 11 Subject: Question on iPhone app Hi Graham, Thank you for your inquiry. The VMS 4x4 app allows you to use something called Track Log. This will allow you to use your PC or Mac to plan a custom track or alternatively, as your on the track itself, to save the track as your riding on it. The app uses iTunes to sync your data onto the device and is free to download from Apple. View this PRIVATE Discussion online: http://vms4x4.tenderapp.com/help/dis...44d0bc41297222 -- |
10-28-2011, 03:31 AM
#24 | |
Oddometer: 1,423
Ask me again in a few weeks. http://www.sygic.com/en/iphone
We're building a community to help noobs choose the right oil: Stack Exchange's Proposed Motorcycle Community |
11-01-2011, 08:08 PM
#25 |
Still trying
Oddometer: 659
Hey abhibeckert, am interested in your purchase of another app. Is this as a supplement to the MotionX app, or as a replacement?
Look forward to your assessment and report, as I really need to get something soon, but am a GPS virgin for this sort of app. Has anyone tried using the battery pack add-ons for the iPhone? Or do most run it powered to the bike? |
11-02-2011, 08:55 AM
#26 | |
Oddometer: 1,036
Power on bike
Better yet- get a charger rated for the iPad - which can draw 2 full amps. I've run a iPhone 4 with a Griffin Power-Jolt charger with full Nav and continuous music for 17 hours on my bike with no problems.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 |
11-02-2011, 05:43 PM
#27 | |||
Oddometer: 1,423
But it doesn't do turn by turn navigation, and it's almost useless if you need to find a nearby petrol station. I'm not sure what the best GPS app is for street riding. The two I have are Sygic ($25) and NavFree (free). Sygic has a lot more features, and it uses commercial map data. NavFree has less features but it does have most of the important ones, and it uses openstreetmap.org's data. After using sygic for a while, I think the extra features are worth the price. But you could get by just fine without them. For example, sygic supports routes with multiple points along the way, and it shows you the speed limit, warns you if you're approaching some train tracks, tells you to what lane you need to be in, etc. Nice stuff, but not essential. The big difference is the map data. Sygic's map data has almost every road in australia, even tiny goat trails I wouldn't want to take my 690 down without someone to help me get out if I get bogged. So far I've only seen one or two tiny roads which weren't on sygic. In comparison, NavFree is missing a lot of minor roads, especially in remote australia, and street names are few and far between. On the other hand, Sygic is full of roads which flat out do not exist. They're all over the bloody place, if I ride for an hour in the places I like to ride, sygic might show me 20 or so side roads which simply aren't there. At first I thought maybe these were old roads which have been closed, or planned roads which were never built, but a lot of them make no sense at all, for example I saw a tiny side road that runs parallel to a major road and crosses river that would require a multi-million dollar bridge, and it wouldn't provide access to anything. There's no way that road ever existed or was ever planned to be built. And the built in database of speed limits is often wrong, it's handy but I wouldn't rely on it. Sygic's map data is technically better than NavFree's. But when there's something wrong on NavFree, I can, and regularly do, go in and fix it myself. And depending where in australia you're riding, I suspect NavFree might be a lot better than Sygic. I don't like the routing of sygic very much, it tries very hard to send me down all the most boring roads in the area, even if it means an extra hour or two of riding. NavFree is a little better, but still not great. My verdict is to get MotionX GPS if you want to work with tracks, and either NavFree or Sygic depending how much street riding you do. Maybe try NavFree first. I'd like to hear others opinions on the wide range of turn-by-turn apps available though, as many of them look very good and I'm too cheap to buy them all. Quote:
A battery pack would help if you have no other choice, but if the shit hits the fan you're probably going to need your phone, so I think hard wiring it to the bike is the only way to go.
We're building a community to help noobs choose the right oil: Stack Exchange's Proposed Motorcycle Community abhibeckert screwed with this post 11-02-2011 at 05:55 PM |
11-02-2011, 08:59 PM
#28 |
Still trying
Oddometer: 659
Thank you both for the useful information as always. I have the Metroview Aus nav app on my iPhone, but have only used it in the car, but it works OK for urban travelling and is only $25.
I think I will hang off getting anything else until I can get a review of the Mudmap app for ADV riding. |
11-03-2011, 02:29 AM
#29 |
I did that.
Oddometer: 6,451
Hi Abhibeckert, those non-existent roads are prolly gazetted roads that the councli has registered, but never constructed. There ar 2 near my little farm that cross the river on paper, but in reality are paddocks, but the council gazetted them so they appear in the software.
Cheers. |
11-03-2011, 03:27 PM
#30 | |
Still trying
Oddometer: 659
