Old 05-11-2011, 09:07 PM   #16
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,369
Originally Posted by bmweuro View Post
To rule all of this out pull the air tube and clean it out really well. Put it back on the bike and see if your still get oil on your boot
LOL, could do it easier by just pulling the intake runners and going for a ride! (and hope no birds fly in there)
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 05-11-2011, 09:07 PM   #17
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,364
I have seen oil migrate to the area you indicated from other places. That seems to be a natural place for it to go.
But if you have a bad tube:
IMO the key to changing the pushrod tubes is having a drift punch of just the right size and good solid support for the cylinder. I turned a punch down from some brass round stock and made a collar for the bottom of the cylinder from 1 1/8" plywood. Sometimes the tubes come out with two or three whacks with a dead blow hammer and sometimes a little heat is needed.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 05-11-2011, 09:16 PM   #18
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,462
I good friend of mine did that and it back fired through the carb and caught the garage on fire. So I'm a little paranoid about doing that. Plus if you clean the tube and stick it back on you will have an idea of how much might be coming from the breather if any.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-27-2011, 02:02 PM   #19
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,369
http://www.advrider.com/forums/showt...2#post16264852
Posted new thread since its not the pushrod seal like I had been thinking. New pictures with specifics.
Times are GMT -7.   It's 05:14 AM.
