Old 05-11-2011, 02:32 PM   #1
DP-WU OP
DP-WU's Avatar
Oddometer: 33
Where can I get a 17mm ball?
Looking for a 17mm ball to mount my Nuvi 550 on. I don't need/want any sort of arm/riser/etc. If I could find a 17mm ball that has a hold through it, I can run one of the riser bolts on my bike through that, and mount directly. Am I dreaming?
I'm almost ready to by a standard suction mount, cut the ball off of it, and drill my own hole.
Someone must make something along these lines, no?
TIA
DP-WU is offline   Reply With Quote
Old 05-11-2011, 03:24 PM   #2
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,716
Go to McMaster.com, search for "steel" or "plastic" depending on the material you want, click on "ball", then narrrow down depending on options. You'll have to convert 17mm into fractional inches to find a ball nearest that size. You'll have to drill the hole yourself. For plastic, you'll need a steel sleve to tighten down on.
New desert racing frontiers
It will be Devilish !
HogWild is offline   Reply With Quote
Old 05-11-2011, 03:36 PM   #3
JALnSC
JALnSC's Avatar
Oddometer: 1,033
Any ram-mount dealer can get or has the 17mm ball that threads into a 10mm bolt. Saw one at tellico outfitter not long ago. Minimike is the owner and fellow inmate.
You think chicks dig guys looking like road-grimed power-rangers with cool scars?
You must be smoking rope, Boy!
JALnSC is online now   Reply With Quote
Old 05-11-2011, 08:59 PM   #4
DennyIndy
Old F@rt
DennyIndy's Avatar
Oddometer: 349
TIA
Mount (replacement) -
The little ball is attached to the other part with a bolt.
Worked for me.
Originally Posted by Mac View Post
Fret about bigger issues, like whether a neighbor's dog is pooping in your yard.
Cheers, Denny
DennyIndy is offline   Reply With Quote
Old 05-12-2011, 03:35 AM   #5
DP-WU OP
DP-WU's Avatar
Oddometer: 33
That looks like it could work perfectly. Thanks Denny!
Old 05-13-2011, 02:17 AM   #6
DennyIndy
Old F@rt
DennyIndy's Avatar
Oddometer: 349
You might need to enlarge the hole, the ball is made of plastic so not too difficult to work with. I used it to make a 1" ball to 17mm ball adapter so I could use a Ram mount in my truck instead of the Garmin suction cup mount.
Looks like a dumbell with one ball smaller than the other.
Cheers, Denny
Old 05-13-2011, 08:49 AM   #7
mcnut
Oddometer: 1,365
I know you asked about the 17mm hard plastic ball which is the standard ball that is used by Garmin on their cheaper mounts but.....
The RAM 25mm rubber ball system works much better, is more adaptable and is priced right.
Bruce
mcnut is offline   Reply With Quote
Old 05-19-2011, 10:52 PM   #8
BootDragger
Rehibilitation Rebel
BootDragger's Avatar
Oddometer: 544
TIA
I prefer to use #68 or #67 on the riser bolt.
http://www.e-mount.com/page_results....tring=05002001
BootDragger's Spot
"I like you. People say I’ve got no taste, but I like you!."
BootDragger is offline   Reply With Quote
Old 07-10-2011, 10:52 AM   #9
wilson.c
Oddometer: 4
Just fond the a supplier of these 17mm ball mount/brackets.
Just Google 'Arkon'
wilson.c is offline   Reply With Quote
Old 03-05-2013, 07:46 PM   #10
fredz43
Location: Illinois- land of straight, flat, boring roads.
Oddometer: 637
Just Google 'Arkon'
I saw this old thread about a search for 17 mm balls to adapt Nuvi/Zumo mounts and wondered if anybody has info on where to find one. Google search for Akron finds lots of things, including a town in Ohio, but nobody that sells these.
fredz43 is offline   Reply With Quote
Old 03-06-2013, 03:45 AM   #11
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,022
That would be because it is ARkon.
http://www.arkon.com/
dunno.....
Old 03-07-2013, 09:29 AM   #12
fredz43
Oddometer: 637
D'oh!
Thanks.
Old 03-21-2013, 04:01 PM   #13
fredz43
Oddometer: 637
Found it!
BTW, I found just waht I was looking for, a 17 mm ball to Garmin standard ball adapter at GPS City. Ordered two of them.
2ea RAM Mount Snap Link to G-Ball Short Ball Arm RAP-SBA-RGU 2ea $2.71ea $5.42
Old 03-21-2013, 07:37 PM   #14
250senuf
250senuf's Avatar
Oddometer: 2,342
You might want to take a second look. The way I understand that item the RAM end is not a normal 1" ball, it is a snap-in ball.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 03-22-2013, 09:39 AM   #15
fredz43
Oddometer: 637
I see that you are correct. I owuld have to use one of these:
http://www.themountdepot.com/RAP_SB_...p-sb-187bu.htm
Thanks.
Times are GMT -7.   It's 09:37 PM.
