Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 01-27-2015, 12:55 PM   #1
technikiller OP
technikiller's Avatar
Oddometer: 69
Cam chain noise?
I'm hoping for some input. I've read a bunch of posts on the cam chain tensioner going bad but I'm not sure if that's the noise I have. It's a loud knock/rattle that seems to come from the right side of the motor. It happens between 2-4k rpms, but won't do it in neutral, only when rolling in first or second gear with the clutch out. It speeds up in conjunction with the rpms. Shouldn't a loose cam chain make the noise while sitting in neutral as well?
Any input or suggestions is much appreciated.
2012 Tiger 800, 30k miles
"Faster, faster, faster, until the thrill of speed overcomes the fear of death"
Hunter S. Thompson
technikiller screwed with this post 01-27-2015 at 12:57 PM Reason: more info
technikiller is offline   Reply With Quote
Old 01-28-2015, 08:00 AM   #2
frytown
Oddometer: 73
Sounds pretty similar to when I had a delrin cam chain guide come loose in the first few hundred miles on my 800 road a few years ago. It's apparently pinned into place halfway between the cam cogs and the lower cog. I guess sometimes the pin breaks and it wobbles when the chain rides over it? Get it checked out by the dealer - there may be a notice and replacement policy. One would hope anyway.
frytown is offline   Reply With Quote
Old 01-28-2015, 11:03 AM   #3
technikiller OP
Oddometer: 69
Great, thank you for the reply.
Hunter S. Thompson
Times are GMT -7.   It's 02:03 PM.
