Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 11-15-2012, 09:52 AM   #181
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by levain View Post
What size pelicans are those? What rack did you use? Can you show a picture from behind?
The topbox is a 40, though I wonder if there was a taller one, mine won't accept a helmet which would be nice. The side cases are 35s. I took them w/o the topbox on this trip just to see what living on 70 liters for a few days was like. Other than adding a tent, sleeping bag, and pad - I could pretty easily travel for months with them, so the topbox will make things more cushy.
The right side of my cheapo Givi rack sticks out a bit... I measured the distance from the outside edge of both side cases and came up with 38", so I don't really care that they're off center, which was unnoticeable when riding. I even put more of the weight in each one trying to throw off the balance, but again I didn't notice bupkis. The rack is Givi PLR6401 and my sole reason for buying it was cost: $113.84, a little more than half what I'm seeing them for now. I bought from http://www.cli-maxridinggear.com/servlet/StoreFront though they're $190 now, most stores have them @ $200+
For the most part the Tiger/Givi/Caribou combo works ok. Caribou built their cases to work with the rack, not knowing what bike the rack would be installed on. So the lock on the left side box really has to be worked to get it on or off, especially with the topbox on. This is due to the top side of the lock hitting the grab rail as you turn it. But I can live with this.
UtahFox is offline   Reply With Quote
Old 11-16-2012, 01:09 PM   #182
TekurRides
Oddometer: 73
FBJ: What do you use now? So you ended up not liking both the Givi screens?
Originally Posted by fbj913 View Post
no the bracket are different. it uses the same threaded holes but the bracket is totally different. You may be able to find some directions online that would show it better. I no longer use or have the screen.
TekurRides is offline   Reply With Quote
Old 11-16-2012, 01:14 PM   #183
TekurRides
Oddometer: 73
I am 5' 11" with 34 " in seam. Tried the Triumph Tall windscreen at the high position today. The buffeting was horrendously bad, even worse than the stock screen. I have adjusted it to the very low and give it a try in the evening. But looks like I will need to go on a different route to find a solution for the wind noise/buffeting.
Old 01-21-2013, 08:05 AM   #184
Deek
Deek / AdVentureMan
Oddometer: 72
Anyone have a Triumph Adjustable High Screen Kit? HERE
I'm looking for something that will cut down the noise and wind blast a bit. Do not want the much more expensive Madstat (sp?) and others, although they probably do work well. I like the looks of the one in the link, but I'm not sure if it will do much to cut down noise and blast.
Pictues would be appreciated, along with a comparison in the size of the stock 'screen and the Adjustable High Screen.
I'm 6', 33 inch inseam. BIke has top and side cases, Givi tank bag.
Thanks.
Deek is offline   Reply With Quote
Old 01-21-2013, 08:25 AM   #185
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Thanks.
There are several owners of that shield on here. Some have liked and others have gotten rid of it. It's like seats, depends on the person.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 01-21-2013, 08:37 AM   #186
Deek
Deek / AdVentureMan
Oddometer: 72
Heck, I think it's much worse than seats! Right now that one (OEM Adj Tall screen) and the Givi 6401 look like the most attractive to ME. I'm trying to figure out how tall the Triimph on is.....looks a LOT shorter than the Givi.
Old 01-21-2013, 10:34 AM   #187
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
Thanks.
I'm on my 3rd version of wind screens. All the others I've had others have loved. So many factors which include... helmet, rider height, etc. Madstad is probably the fan favorite. I'm back to the stock screen.
fbj913 is offline   Reply With Quote
Old 01-21-2013, 10:35 AM   #188
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
it's not a lot shorter. I'd guess about the same.. I had the Givi.
Old 01-21-2013, 11:02 AM   #189
bross
Where we riding to?
bross's Avatar
Oddometer: 4,600
Thanks.
I have the Triumph adjustable high screen. I snapped a couple lousy pics before running out the door before work this morning. I'm pretty much your size, 6', 34" inseam. Little background, I sold my Honda CBF1000 and bought the Tiger 800XC for a couple reasons, but the main reason for getting rid of the CBF was the bloody wind noise. I loved that bike but spent a couple years trying to resolve the wind noise on it. I ended up running a CalSci med screen which was a huge improvement but still loud. I'm not overly sensitive to wind noise but the CBF was horrible. I love riding my DR650 or the Scrambler I had for the nice clean, quiet ride with no screen at all.
The Tiger stock screen wasn't bad and I could have just lived with it, and it was no where near as loud as the CBF was, even with CalSci screen. I just wanted to try the adjustable one and it's stayed on. I leave it in the high upright position for long highway rides, and lower it for slower or twistier sections.
I was trying to hold the stock screen up with one hand while taking the pic so these aren't perfectly lined up etc. Check the specs but I'd say the high screen is 1.5 - 2" higher than stock.
High screen from the front
Highest position
lowest position
Bottom line is it works OK for me and I'll leave it on. My acid test on my CBF for testing different shields/configurations etc. would be to stand on the pegs. You get the nice quiet clean air, then sit down in my regular riding position and try to make a mental note of the wind noise. Ride / repeat. Good luck, I know how wind noise can ruin an otherwise brilliant bike.
Old 01-21-2013, 11:20 AM   #190
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Highest position
lowest position
Is that a Speed Triple I see or a Street Triple? Nice collection you have there.
_______________
Old 01-21-2013, 11:41 AM   #191
Dirtysouth
Stud fee waived for noobs
Dirtysouth's Avatar
Oddometer: 4,960
Triumph Adjustable tall screen...
I just put the factory tall adjustable screen on my Tiger and with 3 small trips to work, I figured out that the lowest setting works the best for me at 5'10" and a 30" inseam.
I've only tried it at the tallest adjustment, middle, and then the lowest. I am going to start adjusting it one click at a time from the lowest setting to see what it does. At the tallest setting, the buffeting was pretty bad.
"...When your time comes to die, do not be like those whose hearts are filled with fear of death,
So that when their time comes, they weep and pray for a little more time to live their lives over a different way.
Sing your death song, and die like a hero going home." - Tecumseh
Dirtysouth is offline   Reply With Quote
Old 01-21-2013, 12:27 PM   #192
bross
Where we riding to?
bross's Avatar
Oddometer: 4,600
Street Triple R, the wife's. She prefers to ride naked.
I got tired of her telling me to sell that POS Honda and buy a real bike, meaning a Triumph.
Old 01-21-2013, 02:52 PM   #193
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Thats awsome. Damn fine bike. If I had a second bike for around town jaunts and twisties, that would be the one. I loved my Sprint ST but she was a bit of a big in the twisties.
_______________
Old 01-21-2013, 03:51 PM   #194
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Laugh
Madstad. Truly a step up from OEM.
_______________
Old 01-21-2013, 03:58 PM   #195
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
Nice bike. Done nice and clean. Good work.
Times are GMT -7.   It's 04:18 PM.
