Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 05-27-2013, 08:58 AM   #286
Poweranger
Oddometer: 786
Thanks for the ideas. I'll start with sanding the edges or covering them. I use the shield in the lowest setting so it does stick out past the top edge of the headlight a bit.
Poweranger is offline   Reply With Quote
Old 06-02-2013, 05:29 AM   #287
rrr70
Oddometer: 157
Just ordered Laminar Lip. Will see how it goes.
rrr70 is offline   Reply With Quote
Old 06-02-2013, 07:32 AM   #288
Poweranger
Oddometer: 786
Originally Posted by TAMPAJIM View Post
Yes. I have used a black indelible marker in the past for this. Might help to dull the edges with fine sandpaper first.
I have now tried most of the suggestions. Dulling the edges had little or no effect. I tried some black electrical tape also around the edges and covered a portion of the the bottom. That helped cut it down quite a bit so I decided to just try painting it. A friend had some flat black PlastiDip and suggested using it. The nice thing about the PlastiDip it is easily removable. It peels off if you ever want to remove it. This provided the required result with no more reflected light. I really do not care for the look of the all black screen now but function over form wins out. I will probably get used to the way it looks eventually.
Old 06-02-2013, 12:33 PM   #289
FishrCutB8
Oh HAI!
FishrCutB8's Avatar
Location: The Green Between Philadelphia and Pittsburgh
Oddometer: 289
Originally Posted by Yankee Dog View Post
Here is my Madstad Adventure 20". I love it. Was easy peasy to install. Did a test drive at speeds up to 70mph. Stayed cool, calm and collected.
Curious: why did you go with the Adventure over the Explorer?
Any thoughts, for those of you that chose one over the other, as to why you made that choice?
FishrCutB8 is offline   Reply With Quote
Old 06-02-2013, 04:32 PM   #290
vanjoosten
Oddometer: 103
I had Mark make an Explorer Slim to clear my hand guards with risers installed. I think it fits the Tiger better than the standard Explorer or Adventure.
Untitled
vanjoosten is offline   Reply With Quote
Old 06-02-2013, 10:03 PM   #291
BryanCO
CO Rider
Oddometer: 503
I have the 20" Explorer. Primary difference is the astetics of the lower edge.
I have Rox Risers and stock hand guards (will be adding HDB soon) and have no interference issues.
BryanCO is offline   Reply With Quote
Old 06-04-2013, 06:30 PM   #292
FishrCutB8
Oh HAI!
FishrCutB8's Avatar
Oddometer: 289
I see what you're saying about the lower edge. This will be the first darkly I EVER buy, so I would really like to do it right. Any issues two up?
Old 06-04-2013, 09:20 PM   #293
Applevalleyguy
Oddometer: 28
Madstad vrs Givi Adjustable AF6401
I had an opportunity to examine the Givi AF6401 in some detail. It looks like it was made for the Tiger, almost looks factory. The outer screen is very easy to position and looks like it will accommodate taller riders. Has anyone been able to ride with this screen and the Madstad? I know that this is a long shot, but perhaps luck will be on my side.
Thanks,
Applevalleyguy is offline   Reply With Quote
Old 06-20-2013, 01:17 PM   #294
tombaxers
Oddometer: 2
Powerbronze Touring
Originally Posted by thumper 8 View Post
So far, so good.
Looks about 4 inches taller than stock - I still look over the top of the screen by 3 or 4 inches.
Alright Thumper, any chance of some more feedback on this now you have had it for a few months. I'm based in the UK and this is gonna be a lot more cost effective for me (and better looking) than the Madstrad.
Please can you let me know how tall you are, and whether you ride with the seat up or down. I'm 6' 0" and usually ride distance with the seat on the high setting. Ultimately, is this going to be a fair amount better than the stock crap which presently nails me in the forehead at any speed 50+?
As this screen seems to be on the standard mounts how much vibration/ movement does the screen have at speed?
Thanks in advance!
Triumph Tiger 800XC, Yamaha YBR125, Jialing JH600B-A, Hyosung Aquila 125
tombaxers is offline   Reply With Quote
Old 06-27-2013, 02:20 PM   #295
Applevalleyguy
Oddometer: 28
Adventure vrs Explorer
Has anyone tried both screens? If so why did you make the selection that you did?
Old 06-29-2013, 07:23 AM   #296
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,991
I believe the only difference is the look. I thought the adventure fit the shape of the headlight better. Strictly a personal preference. I can't see as there would be spit difference functionally.
If I was going to change anything I would go with the 18 instead of the 20. I am 5' 11", 32 inseam. With the 20 all the way down, I can just see over the top. Which is just perfect for highway miles. But in rougher going I find myself forced to look through the screen to see the ground closer to me. Something I don't like to do.
The guy at Madstadd offered to exchange the shield when I first got it but I declined the offer. He also offered to cut my shield down for me at a later date. I may take him up on that offer eventually.
As for how I like it. The screen is worlds better than stock. Very effective. Significantly quieter with less turbulence. Not at all hard to ride at 60mph with my face shield up. Something impossible with the stock screen. I consider it money well spent.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog screwed with this post 06-29-2013 at 07:28 AM
Yankee Dog is offline   Reply With Quote
Old 06-30-2013, 12:38 PM   #297
Applevalleyguy
Oddometer: 28
Adventurer vrs Explorer
The folks at Mastad confirm Yankee Dogs position that there is little difference in protection between the two. The person that I spoke with said that the Explorer was styled with the Tiger 800 in mind. After learning that I placed my order for a 22" in Med Smoke. Although there have been many positive reviews I will post mine when I get it sorted out. I was very tempted to go with the adjustable Givi but couldn't get any feedback about its performance.
Old 06-30-2013, 01:07 PM   #298
bross
Where we riding to?
bross's Avatar
Oddometer: 4,604
How tall are you? and what's your inseam? Please post your thoughts on wind noise once you get to try the screen. Thanks.
Old 07-01-2013, 04:01 AM   #299
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,991
I ................................
The missus reports that the back seat is calm, cool and collected as well.
2005 Ural
2005 BMW F650GS
Old 07-09-2013, 01:25 PM   #300
thumper 8
wag more, bark less
thumper 8's Avatar
Oddometer: 21
Thanks in advance!
We are about the same height (6 ft) and I ride with the seat in the high position. I had the bike out last week for an extended 12 hour on & off road ride and essentially no buffeting at all. Screen mounts quickly and has no noticeable vibration - very happy with the screen. Had the bike over 150 kph at one stretch and the screen was rock solid.
2012 Triumph Tiger XC
Taking the road less travelled... and loving every minute of it!
All my bike pictures here: http://www.thumphoto.com/
thumper 8 is offline   Reply With Quote
Times are GMT -7.   It's 08:46 AM.
