05-12-2011, 01:37 PM
#1 |
Oddometer: 129
BMW 800 GS pictures
The first two pictures of the 800GS / M72 install. More will be added over the next couple days as the install progresses. Barry
DMC SIDECARS General Manager, designer, installer, test rider, problem solver. Generally whatever needs doing. ![]() 37 YEARS PLAYING WITH SIDECARS Myths and misinformation are more seductive than the truth. |
05-12-2011, 01:39 PM
#2 |
Oddometer: 129
800 GS pic
Second picture.
05-12-2011, 02:05 PM
#3 |
Dana
Oddometer: 1,814
06 Ural Patrol 03 R1150 GS Sport/ Friendship II 94 R1100RS 99 Rokon Ranger 71 Rokon RT140 Hack'n the TLH http://www.advrider.com/forums/showthread.php?t=592860 http://dirtydr.smugmug.com/ Proud Member of the Patrol Patrol
05-12-2011, 02:53 PM
#4 |
The Examiner
very much looking forward to watching this thread
i know it's going to be great
Greg '07 K1200 GT '11 R1200 GS Adventure with a DMC M72DX Sidecar live life like you mean it... but take your family and friends (and DOGS) along for the "ride" |
05-13-2011, 01:06 PM
#5 |
Oddometer: 130
Me too. Can't wait to see the finished product.
05-13-2011, 01:25 PM
#6 |
What are we waiting for?
Oddometer: 3,339
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay I tell it what it wants to hear, and it does what I want it to do. I made that Motronic my bitch. Poolside Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6 |
#7 |
Oddometer: 129
mounts on
Just got our first in house built Sportster trike out the door. Now I can concentrate on this build.
Barry
05-13-2011, 02:22 PM
#8 |
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,987
05-13-2011, 03:05 PM
#9 |
Oddometer: 129
Frame
M72D frame mounted on adjustable installation stand. This allows us to level the frame and roll it around while mounting to the bike. B
05-13-2011, 03:11 PM
#10 |
Oddometer: 129
Custom wheel
We used this custom built Excel wheel. This is the same rim used by Touratech in combination with the spline drive spokes to upgrade stock BMW wheels. This also allowed us to match the rim color on the bike and install the same tire used on the rear.
I don't know if I will get more pics posted today or not. I will be away through the weekend so posts will probably start again Monday. Barry
05-13-2011, 03:51 PM
#11 |
Oddometer: 129
Motorcycle install stand
This stand allows us to set the preload and initial lean out.
05-13-2011, 03:54 PM
#12 |
Oddometer: 129
Together
You can see in this picture how we can roll the sidecar up to the bike and align the two. More Monday. Barry
05-13-2011, 04:39 PM
#13 | |
Oddometer: 3,339
05-13-2011, 08:26 PM
#14 |
The Examiner
i can't wait to see more....
and..... not just of that 800GS install.... maybe a couple of bikes with 400 more cc on their designation... great thread, barry awesome stuff happening at DMC and... even more all the time
05-16-2011, 10:53 AM
#15 |
Oddometer: 129
800GS build
The next step is to connect the A-arms between the bike and sidecar frame. At this point we only snug the bolts as adjustments still have to be made. The A-arms set the wheel lead and put the toe-in close while not compromising ground clearance like can happen with the usual boss/clamp setup. Next we fine tune the toe-in with a turn or two in or out on the heim joints. This will mean rolling the frame stand away from the bike to allow the heim joints to be turned in the required direction. Fortunately the use of the heim joints also allows for easy alignment with the clevis. Once the toe-in looks good we re-snug all the bolts and check the toe again. If it is still good we then torque the A-arm pinch bolts to 80 ft lb. and tighten the jam nuts on the heim joints. One last check of the toe-in is a good idea as it can sometimes move while tightening the bolts.
