Old 05-13-2011, 04:11 PM   #1
fullmetalscooter OP
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 2,927
helix speedo common problems
It's a common problem with the helix speedo that the fuel gauge led have one to 3 bad bars that don't light up with age. With these led being inside the whole unit it seem like there s no way to fix it. I m wondering if its possible to just wire up a set of gauges and a generic speedo to take there places. It's no worth trying to find an oem unit to replace it because it might have the same problem
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 05-14-2011, 07:24 AM   #2
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
Trail Tech Vapor?
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-14-2011, 10:41 AM   #3
Warney
Warney's Avatar
Oddometer: 568
It might be worthwhile to disassemble, spray with de-oxit, then reseat all of the multiconnectors. Those LCD segments are usually pretty reliable. If it is easier to get at the fuel tank sending unit, disconnect the leads, remove and check the potientiometer with a vom to make sure it is signalling the lcd fuel gauge. Would be worh a look before trying an add-on device.
Warney is offline   Reply With Quote
Old 05-14-2011, 10:55 AM   #4
bbishoppcm
It ain't a moped.
bbishoppcm's Avatar
Oddometer: 666
There is a chinese variant of the Helix that uses an analog gauge set in place of the costly digital one. Looks like a bolt-in replacement! Hoenstly though, these are usually pretty reliable... I'd disassemble it and check for corrosion or a loose terminal. What year is your Helix?
bbishoppcm is offline   Reply With Quote
Old 05-14-2011, 03:20 PM   #5
fullmetalscooter OP
Oddometer: 2,927
On the elite 250 and helix it seems to be common for the fuel gage to have 2 to 3 dead barrs
Old 05-15-2011, 07:25 AM   #6
Warney
Warney's Avatar
Oddometer: 568
'85-'88 Elite 250 has an analog gas gauge, unsure on the '89-'90.
Old 05-15-2011, 01:04 PM   #7
ernest t bass
ernest t bass's Avatar
Oddometer: 443
Worst Helix Speedo Problem: The numbers on mine stopped going up at 72mph.
Ha Ha Ha
If A Duck Stands Still, You Can Catch Him By The Bill.
ernest t bass is offline   Reply With Quote
Old 05-15-2011, 05:01 PM   #8
bbishoppcm
It ain't a moped.
bbishoppcm's Avatar
Oddometer: 666
Ha Ha Ha
HE LIVES!!!
Anyway... what year is your Helix with the faulty gauges?
Times are GMT -7.   It's 02:21 AM.
