04-19-2012, 06:57 PM
#2956 | |
Procrastinators
Oddometer: 5,772
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
04-19-2012, 07:12 PM
#2957 |
Oddometer: 103
Thanks, I've created track up and north up shortcuts. It works pretty good. Although I'm waiting for the compass arrow click to work on released firmware.
Spiritwalker2222 screwed with this post 04-19-2012 at 07:30 PM |
04-19-2012, 07:13 PM
#2958 | |
Procrastinators
Oddometer: 5,772
And the way to remove pushpins when panning the map is to hit the X at the bottom right of the pushpin's text box at the top of the screen.
04-19-2012, 07:35 PM
#2959 | |
Oddometer: 103
If it's truncating to 10,000 points, what is it doing. Is it removing the last points(doesn't appear to be what it's doing). Or removing points that are closest to each other? |
04-19-2012, 07:48 PM
#2960 | |
Long Haul Adventurer
Oddometer: 3,167
This really isn't as big of a deal as it use to be on other devices. Just set your Profile to Recreation and do a software master reset (Reset All Settings) when you want it reset. Then after you select your Language call up your personal Profile. Cheers,
Cheers, Dan DRTBYK screwed with this post 04-20-2012 at 03:05 PM |
04-19-2012, 07:49 PM
#2961 | |
DualSport
Oddometer: 274
The ATV/Off Road Driving activity looked interesting but unfortunately it doesn't work with off-road routes (gets the old 'only 50 points can be used for follow road navigation').
DR350SE DR650SE F650GS Dakar |
04-19-2012, 07:54 PM
#2962 |
Procrastinators
Oddometer: 5,772
No, I haven't. As long as I'm not wearing boxing gloves, I should be ok.
04-19-2012, 08:00 PM
#2963 | |
Back Home
Oddometer: 1,546
04-19-2012, 08:01 PM
#2964 | |
DualSport
Oddometer: 274
When in Track Up mode, tap the N arrow and screen switches to North Up BUT the N arrow remains displayed so you can tap it and switch back. |
04-19-2012, 08:07 PM
#2965 | |
DualSport
Oddometer: 274
BTW, I decided to try the Beta s/w as I have endless problems with the Red Pin when scrolling while riding. I've e-mailed MontanaBeta to ask for a Delete "X" next to the Create Waypoint flag (on next page) as that's where I end up trying to hit the X in the map screen waypoint box. |
04-19-2012, 08:11 PM
#2966 | |
Procrastinators
Oddometer: 5,772
You could keep a stylus around, and scroll/X with that too.
04-19-2012, 08:19 PM
#2967 | |
Oddometer: 3,167
. But the unit still does truncate any single track at point #10,000.Cheers,
Cheers, Dan |
04-19-2012, 08:38 PM
#2968 |
Oddometer: 3,167
This is just a little public thank you to the Montana Dev Team. The Montana 600 Series is by far the most advanced feature-rich GPS unit that Garmin has ever produced and I think it will continue to get even better if the Garmin Exec's will continue to fund it.
About the "only" thing I would really like to see is: Feature & Description
![]() Cheers,
Cheers, Dan DRTBYK screwed with this post 04-20-2012 at 03:08 PM |
04-19-2012, 09:44 PM
#2969 |
Working to ride
Oddometer: 667
04-19-2012, 10:04 PM
#2970 |
Oddometer: 3,167
Well, it turns out that with the updated Routing feature, the Montana now accepts mixed-routes. Just remember to set "Recalculate=Off" in your Routing settings when you navigate one of these.
The way to create a mixed-route in BaseCamp is to create your along-road segments using your routable map and when you need to go off-road, switch to a non-routable map - don't change the routing Activity as this will recalculate the entire route. Once you have your route the way you want it, just drag and drop the route to the Montana internal or µSD storage. ![]() Oh, here is a screenshot of a mixed-route. The area in the red circle is Direct Routing. ![]() Cheers,
Cheers, Dan DRTBYK screwed with this post 04-20-2012 at 03:24 PM |
