Thread Tools Search this Thread Rating: Thread Rating: 428 votes, 4.94 average. Display Modes
Old 04-21-2012, 11:31 AM   #3016
DR. Rock
Part of the problem
DR. Rock's Avatar
Oddometer: 5,531
New MapInstall released
Further testing required, but it seems that it may erase any and all map .img files when loading a new map onto an SD card, even if it isn't named "gmapsupp.img" I generally load maps onto a Garmin folder on my iPod's hard drive, then rename and copy onto a device or an SD card. I'm loading 24K topos for the Montana andI know I had a few maps on the iPod, and when I just looked they were all gone with a new "gmapsupp.img" file copied there.
I'll double check and report back, but in the meantime, don't presume your loaded maps are safe just because they've been renamed.
"I came into this game for the action, the excitement; go anywhere, travel light... get in, get out... wherever there's trouble, a man alone... Now they got the whole country sectioned off; you can't make a move without a form." --Robert De Niro as Archibald 'Harry' Tuttle in Brazil, 1985. The Mobius Trip index | Spot tracking live 4/18-5/4/13 | AdventureLoft™ Tent Space
Old 04-21-2012, 11:34 AM   #3017
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
I've done it many, many times, writing files then renaming them and never has any map been overwritten or deleted unless it was called gmapsupp.img.
Old 04-21-2012, 01:32 PM   #3018
DR. Rock
Part of the problem
DR. Rock's Avatar
Oddometer: 5,531
So you'll thank me for taking the hit
I just confirmed what's going on: MapInstall 4.0.0 released today for Mac will erase any map.img files in the root Garmin folder of a NON-GPS mounted SD card, disk or drive no matter WHAT the map is named. The information in those individual map .img files will then be compiled into a single gmapsupp.img file which will be written back into the folder. It's still there, it's just been renamed and touched. My name is Francis, and I don't want ANY of you touching my stuff.
When writing maps directly to the Montana unit's memory OR to a µSD card in the unit, existing maps appear to be erased, updated, and then rewritten*. There are more options and an updated interface when using the GPS unit instead of writing directly to a disk or drive. When MapInstall is used to place maps directly on the unit's memory, or onto a µSD card inserted into the GPS's slot, the .img files containing maps are renamed with Garmin's names for the maps (need to retest if this is what's happening).
*If you watch the Garmin folder, existing maps .img files disappear when Mapinstall starts building the new map, then reappear after the transfer is done. The file modification date of existing maps is updated to the transfer time. The gmapsupp.img in the folder is overwritten as before, but now it contains the maps that were already there.
It would seem that if you want your map files named something other than what Garmin wants to name them, you will have to load the maps one at a time onto one card or drive, rename them, and then use the finder to move them to the µSD card that you will then insert into the GPS.
DR. Rock screwed with this post 04-21-2012 at 01:42 PM
Old 04-21-2012, 02:28 PM   #3019
DR. Rock
Part of the problem
DR. Rock's Avatar
Oddometer: 5,531
Hmmm.
I'm running v3.98, and the Odometer doesn't seem to be resetting even with a switch to Recreational and a Reset All Settings maneuver.
Also, waypoints didn't delete from that same Setup -> Reset -> Delete All Waypoints... but I was able to Delete All from the Waypoint Manager application --> Delete All.
Also, why does the icon for the Track Manager application show a dead guy who's just been crushed by a huge box that must have fallen out of a window?
Old 04-21-2012, 02:41 PM   #3020
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
I think the Odometer reset is actually only possible by doing a gps reset, by holding the top left of the screen when you start the unit.
Not the best feature on the Montana, really.
Old 04-21-2012, 02:46 PM   #3021
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
IAlso, why does the icon for the Track Manager application show a dead guy who's just been crushed by a huge box that must have fallen out of a window?
As you know, the Montana holds a lot of tracks. He knows that now, too. They were so heavy, he put his back out.
Old 04-21-2012, 02:53 PM   #3022
bighopper
Oddometer: 192
Weird Things Happening
I finally managed to get out riding today .
A had a couple of things happen that I don't remember reading in posts before.
1. The display would rotate from Landscape to Portrait in 360 2 or 3 times, then stop back at landscape that I have it running in. I had this happen 3 times during my ride that I noticed.
2. At one point I had a route running & when I had to make the first turn, all was good till I did then the unit shut-off! Powering back on I was asked about recalculating the route, which I chose to do. But then got a message that the Maps didn't support routing (basemaps only showing in list) I have North America 2012.4 & OSM maps of North America on an SD card.
I waited till I got home & found that I had to turn off & on the Montana again & all the maps were again available!
Currently running 3.90
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 04-21-2012, 03:02 PM   #3023
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
Depending on the angle you have your Montana set at, it may be better to lock the orientation in Landscape or Portrait to keep it from flipping from one to the other. Check Setup/Display/Orientation.
Re the maps issue - have you got something like an earplug under the cover, wedging the battery in place? Sounds like you might have experienced a momentary battery disconnect, to me.
Old 04-21-2012, 03:17 PM   #3024
advNZer?
advNZer?'s Avatar
Oddometer: 2,921
Originally Posted by igormortis View Post
Paul, I’ve got both the NZ open GPS maps and the Garmin topo maps on my Montana. You’re welcome to come and have a look to see if it’d suit you.
might just do that
aka BMWST?
advNZer? is offline   Reply With Quote
Old 04-21-2012, 03:30 PM   #3025
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,973
Originally Posted by Countdown View Post
As I have said many times, the 3rd party map makers really need to get the letest Travel Management decisions from each forest in the US into their maps. The world for motorized use in forests has changed in the last couple years.
A problem we have had for years in OHV management is "H" vs. the "R". "Off Road" travel in only legal in very specified and well posted "Open" areas and it is actually called "Cross Country" travel by land managers. Everywhere else "Off Road" travel is ilegal.
The correct term for routes that are open to non-licensed drivers and non-street legal vehicles is "Off Highway" routes. Although most of the people on this thread are street legal (dah AdvRider) there is a very large population of Off Highway vehicles with GPS. I know it is a streach but in a perfect world there needs to be autorouting for "Off Highway". This would obviously require map makers to first have all Travel Management routes and also know which dirt roads are (level 3 & up) are only open to licensed vehicles. In many forests that is very fuzzy enforcement.
Jerry, I'd like to introduce you to Open Street Maps. With your knowledge and Track library, you could singlehandedly map the Western US for Off Highway use for generation to come!
At least in my State, I have contacted the Forest Travel Management Team and requested the they do what the Black Hill FSTM did re: Garmin Maps of the MVUM when they do get around to publishing their "plan" in 2013.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 04-21-2012, 03:39 PM   #3026
DRTBYK
DRTBYK's Avatar
Oddometer: 5,973
Originally Posted by moto-treks View Post
Can you get your selection to "stick"? When I select a new item to avoid, like Tool Roads, I get the green checkmark. But when I exit the display and reenter Avoidance Setup, Tool Roads, is unchecked
You are correct they do not stick. Did you send an note to the Montana Beta team?
Cheers,
Cheers,
Dan
All Things GPS
Old 04-21-2012, 04:16 PM   #3027
DRTBYK
DRTBYK's Avatar
Oddometer: 5,973
Using the "Advanced" button, you get the "old" map product drop down and map segment selector. When MapInstall writes your new map it gives it the name of the map I selected no more gmapsupp. Very good! What I see in the v4 MapInstall is a product that can "adjust" to the GPS and storage that is attached. Not a bad thing.
Cheers,
Update: When using the "Advanced" option, if you select segments from multiple map products, the resultant file is named after the first map product you selected segments from - uh, OK, I can live with that AND it did not write over the other IMG file I had on the device. Cool.
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 04-21-2012 at 04:35 PM Reason: Update:
Old 04-21-2012, 04:37 PM   #3028
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
Cheers,
Update: When using the "Advanced" option, if you select segments from multiple map products, the resultant file is name after the first map product you selected segments from - uh, OK, I can live with that AND it did not write over the other IMG file I had on the device. Cool.
This is the change log for version 4 of MAC MapInstall:
Added ability to automatically send all current map products to newer devices if possible.
Added ability to send full map products to newer devices rather than needing to select individual map tiles.
The map selection page no longer lists map products that are locked for the selected device.
Fixed map transfers failing with errors saying there wasn't enough space left on the device.
Wow, Garmin's really starting to make good use of the advanced properties of units like the Montana.
I think the Windows version of MapInstall is still on V 3.15.0.
Emmbeedee screwed with this post 04-21-2012 at 05:39 PM
Old 04-21-2012, 04:40 PM   #3029
DRTBYK
DRTBYK's Avatar
Oddometer: 5,973
I pointed this out yesterday morning. Do try to keep up, eh?
And in my post at that time: Edit: just checked version 3.97 on my wife's Montana and in that version, it's still got the confusing dialogue/interface so this Avoidances clarification comes with 3.98!
Yesterday? Uh, what day was that?
Cheers,
Cheers,
Dan
All Things GPS
Old 04-21-2012, 04:44 PM   #3030
bighopper
Oddometer: 192
Depending on the angle you have your Montana set at, it may be better to lock the orientation in Landscape or Portrait to keep it from flipping from one to the other. Check Setup/Display/Orientation..
I think I have it parallel, but I will try your suggestion.
I don't as I thought if it is in the AMPS rugged cradle with direct 12v from battery that this shouldn't be an issue, but hey I'll give that a try also & see what happens.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
Times are GMT -7.   It's 09:21 AM.
