04-21-2012, 07:44 PM
#3046 | |
Procrastinators
Oddometer: 6,046
This theory of mine will need testing, of course.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
04-21-2012, 08:49 PM
#3047 | |
Oddometer: 928
Which odometer is everyone talking about that does not reset? If I select the "trip computer" and then tap the menu to bring up the options and tap "reset" everything on the trip computer goes to zero including the "trip odometer". Is that the one you are all talking about or is there another one? Jon...
2007 FZ6 Past Bikes.....Check with my Wife.....I've lost count :-) |
04-22-2012, 03:47 AM
#3048 |
Procrastinators
Oddometer: 6,046
There is another field; it's called "odometer".
04-22-2012, 06:18 AM
#3049 |
Grizzly herder
Oddometer: 1,096
Is there a setting in the Montana for when you use it in the Amps mount so that it will charge? I discovered yesterday that it was not charging. I put a multi meter to the pins on the AMPS and got a full power battery reading. Center pin and the one next to it (can't remember which side). I have the battery that came with the unit inside, and the manual was of no help. What am I doing wrong?
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv |
04-22-2012, 06:35 AM
#3050 | |
Web Adventurer
Oddometer: 569
Is it not charging or is it discharging when the bike is off? When my mount was on switched power the Montana would slowly charge while I ride. Turn the bike off and the Montana off but the next day the Montana's battery would be nearly dead, as if it's not TRULY off. I switched the mount to being powered all the time and the issue went away. You can tell if it's charging by the lightning bolt in the battery icon on the status screen. It takes forever to charge in that cradle.
IBA #33260 |
04-22-2012, 06:47 AM
#3051 | |
Procrastinators
Oddometer: 6,046
04-22-2012, 08:49 AM
#3052 |
Adventure Seeker
Oddometer: 527
Yup and mine doesn't always show a lightning bolt either but the battery is always at 100% when it is running in the mount.
"The trouble with quotes on the Internet is that you don't really know if they are accurate" - Thomas Edison- |
04-22-2012, 10:51 AM
#3053 |
Oddometer: 228
Profile Question
I've only had it a week, so forgive the noob question:
As I understand the way profiles work, once I have set one up and am using it daily, ANY change that I make will be incorporated into that profile file the next time I switch to another profile. So say I have a profile that switches to a topo map, turns OFF logging, arranges the menu and drawer to my liking for that activity, changes the background and position indicator, among other things. So then a week later I set logging to ON, but do not change it back to OFF before changing to a different profile a couple of days later. So now my first profile will turn logging ON if it's off whenever I switch back to it? Is there any way to lock profile files so that this does not happen unless I unlock that profile and make a change? Or is the only way to save the first profile before any changes on the PC, and then if I change it all around and don't like it, overwrite that profile file from the computer backup? Thanks. |
04-22-2012, 11:03 AM
#3054 | |
Long Haul Adventurer
Oddometer: 3,250
Cheers,
Cheers, Dan DRTBYK screwed with this post 04-22-2012 at 11:28 AM |
04-22-2012, 11:09 AM
#3055 | |
Oddometer: 3,250
Cheers,
Cheers, Dan |
04-22-2012, 11:15 AM
#3056 | |
Oddometer: 3,250
Cheers,
Cheers, Dan |
04-22-2012, 11:24 AM
#3057 |
Oddometer: 3,250
I stand corrected - thank you Emmbeedee - the Setup->Reset feature does not reset the Odometer. Only the Master Reset will do that. I haven't found it to be that big of a deal to do but I sometimes forget to do it before departing on a trip/tour.
![]() Cheers,
Cheers, Dan |
04-22-2012, 12:20 PM
#3058 |
Oddometer: 928
Found it......thanks.
I have not played with those settings so I did not even know it was there. Jon...
04-22-2012, 12:30 PM
#3059 |
Web Adventurer
Oddometer: 569
Nope, it's been sitting on my desk since Friday and it still is almost 100%. I only get the drain in the mount using switched power.
IBA #33260 |
04-22-2012, 07:04 PM
#3060 |
Procrastinators
Oddometer: 6,046
Map displays don't get much better than this: we still use Canada Enhanced Basemap, a mapset which Garmin gave up on years ago, but which can't be beat for backroad travelling since they show the secondary roads as far out as the 5 kilometer zoom level.
Here's a few examples of the screens we can get with those old maps on the Montana. ![]() ![]() ![]() City Navigator is far better for looking up addresses, and Topo is better in other respects, but to get a useable large map view, the Enhanced Basemap can't be beat. As far as I can tell, this mapset was put out in 2000! Sure wish Garmin would re-issue it. What's the point of having such a great display if current maps like City Navigator lose most of the detail if you zoom past 1.2Km?
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 04-22-2012 at 07:09 PM |
