04-26-2012, 07:25 AM
#3121 | |
Oddometer: 200
I've been wondering how this works. Is there a setting that disables the red pin, or do you just touch it again to make it go away? Signed, Waiting for 4.00
04-26-2012, 07:28 AM
#3122 |
Procrastinators
Oddometer: 5,814
When a red pin shows up, there's a "Properties" area at the top of the screen, with an X in the lower right. Click the X and the pin disappears.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
04-26-2012, 07:59 AM
#3123 |
Back Home
Oddometer: 1,545
Route Editing
I'm still having route editing problems on the Garmin. When I create a route in BaseCamp and send it to the Montana I see this when I go to the Route Planner and view the route
![]() if I delete the route point, Pendleton ![]() The route looks like this ![]() and never recalculates If I create the exact same route on the Montana I can delete/modify all I want and the route will always recalculate when viewed in the Route Planner. I'm not sure if this is a Beta problem or has always been there as I only tried it after loading the 3.9x betas |
04-26-2012, 08:26 AM
#3124 |
Part of the problem
3.99
Tried it. Still gives me the same intermittant crash when enabling / disabling maps with a lot of topo lines.
Back to 3.90 = totally stable.
"I came into this game for the action, the excitement; go anywhere, travel light... get in, get out... wherever there's trouble, a man alone... Now they got the whole country sectioned off; you can't make a move without a form."--Robert De Niro as Archibald 'Harry' Tuttle in Brazil, 1985. The Mobius Trip index | Spot tracking live 4/6-4/21/13 | AdventureLoft™ Tent Space |
04-26-2012, 08:33 AM
#3125 |
Web Adventurer
Oddometer: 560
IBA #33260 |
04-26-2012, 11:09 AM
#3126 |
DualSport
Oddometer: 274
V3.99 Direct Routing
Garmin V3.99 changes show Direct Routing fixed but the problem I reported about not being able to load a 50+waypoint route when Activity is set to Prompted is exactly the same. Not sure what problem they were refering to as everything else worked correctly with Direct Routing (when Activity pre-set to Prompted) on V3.90.
Anyone know of other Direct Routing problems?
DR350SE DR650SE F650GS Dakar |
04-26-2012, 11:47 AM
#3127 |
Long Haul Adventurer
Oddometer: 3,181
Yep, still a number of issues unresolved with this beta-update. Maybe there needs to be a v3.991 beta-update.
Cheers,
Cheers, Dan |
04-26-2012, 12:03 PM
#3128 |
Web Adventurer
Oddometer: 560
Ten chances to get it right before 4.0.
IBA #33260 |
#3129 |
Procrastinators
Oddometer: 5,814
They sure can't call it 4.0!
04-26-2012, 01:37 PM
#3130 |
Grizzly herder
Oddometer: 1,048
Another AMPS cradle question since tech support at Garmin had no clue. Can anyone tell me wether the center pin on the cradle (the one with the little plastic fins separating it from the others) is supposed to be the Ground or the Hot? I am thinking that I may have got it wrong in attaching the battery tender plug. As it is my center pin is "ground" and the one to the immediate right is the "hot". This is with the cradle in the upright position with the pins at the bottom of the cradle.
Before I pull the connection apart and test tonight I thought someone might know. Either I have it wrong, or there is a problem with my Montana 600 as it still will not charge in the cradle. The cradle is getting power. So either the wrong pins have power(hot to the wrong pin) or for some reason the Montana is not getting it to the battery. Also note: The 600 charges just fine with the USB charger in a wall outlet from the kit, or when plugged into the computers USB port.
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv Lycan1 screwed with this post 04-26-2012 at 01:53 PM |
04-26-2012, 02:25 PM
#3131 | |
Oddometer: 200
![]() I got confused by the plus and minus on the SAE plug since any SAE plug can be either male or female. If one of your SAE plugs is directly connected to the battery, it's hot side will be the hole, not the pin, for obvious reasons. ![]() When you add the other side of the plug, it will have a minus symbol on its pin, but it's still the hot side. Just switch and resolder the wires AFTER the two SAE plugs. The center pin on the mount should be hot. |
04-26-2012, 02:28 PM
#3132 |
Oddometer: 253
For those who like picture evidence
Hot ![]() Ground
02 drz 400s/m 09 Husky wr150 |
04-26-2012, 02:42 PM
#3133 |
Grizzly herder
Oddometer: 1,048
Perfect! This I can fix. Thank you for taking the time to post that!! I managed to find a link to a site that explained the "pinout" From left to right 1.- Serial Data Out (blue wire) 2. - Serial Data in (yellow wire) 3. - Audio GND (Sleeve of 3.5mm jack socket) 4. - Power (10-50V) (red wire) 5. - Power GND / Serial GND (black and green wires) 6. - Audio L/R ( both tip and ring of 3.5mm jack socket) 7. - No Pin (this is populated on the car adapter)
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv Lycan1 screwed with this post 04-26-2012 at 02:51 PM |
04-26-2012, 02:48 PM
#3134 | |
Grizzly herder
Oddometer: 1,048
I appreciate the help and will have this fixed tonight!
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv |
04-26-2012, 04:12 PM
#3135 |
ED RN Adventurer
Ditto
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me? “When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama Life is Risk Management '09 BMW F800GS-Fate Honeyed GSabelle |
