04-27-2012, 01:10 PM
#3151 |
Procrastinators
Oddometer: 6,046
This needs no explanation. 4.01 is out!
Only one fix but it's a biggie: Changes made from version 3.99 to 4.01: Fixed issues with map set selections across Profiles Problems with this beta software may be reported to MontanaBeta@garmin.com EDIT: This fix does work! - it has cured the problem. My map selections are maintained when I switch profiles.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 04-27-2012 at 05:58 PM |
04-27-2012, 01:12 PM
#3152 |
Just Lookin'
Oddometer: 303
Basecamp >>>> Montana 600, 650, 650t
Is possible to send individual routes, tracks or waypoints from Basecamp to the unit or is sending a "list" of any of these the only option as the Basecamp menu would have you believe?
'00 BMW R1150GS -- '07 TRIUMPH SPEED TRIPLE
04-27-2012, 01:24 PM
#3153 |
Oddometer: 928
I'm to lazy to go look, is it a beta or the real deal?
Jon...
2007 FZ6 Past Bikes.....Check with my Wife.....I've lost count :-) |
04-27-2012, 01:32 PM
#3154 |
Procrastinators
Oddometer: 6,046
I'm too lazy to answer that.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
04-27-2012, 01:48 PM
#3155 |
Road Captain
Oddometer: 9,364
Of course, you can have a list with a single waypoint, right? As a test I also did a right click and "copy" of a single waypoint from multiple waypoints in an existing list and "pasted" it into All Data on the device using Basecamp. It created a "waypoint.gpx" file in /Garmin/GPX containing that single waypoint and that waypoint shows up on the device in addition to the other waypoints I already had on the Montana. So, yes, it is possible.
Pain in the Butte Ranch Durango, Colorado - Calculated risk or forbidden fruit? FatChance screwed with this post 04-27-2012 at 01:53 PM |
04-27-2012, 03:31 PM
#3156 | |
Long Haul Adventurer
Oddometer: 3,250
When you send data from BaseCamp to the Montana internal storage, each item (waypoint, track, route) is saved in it's own GPX file labeled according to the type of data: e.g, waypoint.gpx, waypoint1.gpx, waypoint2.gpx, track.gpx, track1.gpx, route.gpx, route1.gpx, route2.gpx, etc.... This method of writing data from BaseCamp to the Montana is handy for multiple data transfers but it is also why some users are seeing duplicates of their Waypoints that are included in Routes. When you select both routes and waypoints from a list (or the whole list) and send it to the Montana internal storage the waypoint that is in a Route.gpx file is also in the Waypoint.gpx file that is created, hence duplicate Waypoints. This was done so that you could make repeated transfers of data while the GPS was connected to BaseCamp. But, this only applies to internal storage on the Montana. If you send data to the µSD card it goes into a file called userdata.gpx and there is only one of those created. So if you send a second data object or set of objects to the µSD card the userdata.gpx file is overwritten. Cheers,
Cheers, Dan |
04-27-2012, 06:20 PM
#3157 |
Oddometer: 928
![]() ![]() ![]() Good one EB......you win. Beta Software: Montana, Ver. 4.01, Beta as of Apr 27, 2012 Jon...
04-27-2012, 06:27 PM
#3158 | |
Road Captain
Oddometer: 9,364
Pain in the Butte Ranch Durango, Colorado - Calculated risk or forbidden fruit? |
04-28-2012, 08:39 AM
#3159 | |
Part of the problem
Duplicate waypoints
I have a folder with subfolders on my hard drive that contains various "lists" of waypoints and/or routes and/or tracks... trips I'm working on, each exported as it's own .GPX file and named in a way that I know what it contains. These folders and files synchronize automatically from my home and work computers and my laptop. When I want to use basecamp, I open the program, delete anything that was left in "My Collection" and then import the appropriate .GPX file. When I'm done working with the data, I export the list again as a .GPX file. If I'm really paranoid about losing data or am working on an extended project, I'll name the .GPX files "draft1" "draft2" etc, so I can always go back to a previous version if I've screwed things up. Once I've got the route how I like it, I trash the drafts. When I want to load stuff on my GPS unit, I first delete everything on there (tracks, waypoints, routes), and then send the list over. This way I never get duplicate waypoints. Basecamp stays lean and fast, and doesn't get bogged down keeping track of a ton of extraneous data.
"I came into this game for the action, the excitement; go anywhere, travel light... get in, get out... wherever there's trouble, a man alone... Now they got the whole country sectioned off; you can't make a move without a form."--Robert De Niro as Archibald 'Harry' Tuttle in Brazil, 1985. The Mobius Trip index | Spot tracking live 4/6-4/21/13 | AdventureLoft™ Tent Space |
04-28-2012, 09:08 AM
#3160 | |
Oddometer: 3,250
Through all of the beta testing and moves from Windows to Mac, I have never lost a single data object. BC gives you the option to Backup/Restore your data and it always does an auto-backup of your data as you create/edit/delete. The good news is that you can use BaseCamp and the Montana how you want. Nothing in this world is "fail-safe" though so backup your HDD as well. ![]() Cheers,
Cheers, Dan |
04-28-2012, 09:38 AM
#3161 | |
Oddometer: 3,250
I'd actually like to see BaseCamp give us the option of sending data as parsed data type files (as it does currently to internal storage) or as most Garmin GPS require, a "userdata.gpx" file with everything in it. Cheers,
Cheers, Dan |
04-28-2012, 10:53 AM
#3162 |
Oddometer: 187
I am looking at the best option concerning accessories to mount the Montana on my motorcycle as well as on my mountainbike.
I am looking at the Garmin Bike Mount partnumber 010-11654-07 ![]() I would be able to mount this on: - the handle bar of my motorcycle - a possible future dakar fairing with navigation tower - the handle bar of my mountainbike I like this option because it is a low cost but solid mount, very compact and I only need 1 that can be used for both the motorcycle and the mountainbike. To be able to use external power and/or charge the battery of the Montana when used on the motorcycle I was thinking about:Vehicle power adaptor cable to USB partnumber 010-10851-11 ![]() However I've read about the problem that in some cases some GPS devices will draw it's power from this cable but not to charge the battery. Battery will remain uncharged if it is uncharged. Does anybody know if this problem will pose with specifically the Montana in combination with this specific cable? If so: any fixes or solutions or alternatives? |
04-28-2012, 11:06 AM
#3163 | |
Oddometer: 4,098
Congratulations you have found a way to turn Basecmap into MapSource, I like it. The thought of one giant file with all data just won't go down with me.
Jerry Counts |
04-28-2012, 11:08 AM
#3164 |
Oddometer: 562
Question Re Audio Out On Rugged Mount
Does anyone know the "specs" on the audio out lead on the Garmin rugged mount? I'm assuming it's 3.5mm; is this right? I can't seem to find that spec anywhere. I like hearing audio prompts in congested areas, and since I ride an R12RT, I'm not going off-road. I use a Sena Bluetooth intercom with my passenger and I anticipate buying the soon-to-be-released Sena SM10 Dual Stream Bluetooth Stereo Transmitter. It has 3.5mm ports for things like a GPS with no Bluetooth. Does the number of poles matter (obviously I'd need the appropriate cable to connect the SM10 to the Montana's audio out.
04-28-2012, 12:11 PM
#3165 |
Oddometer: 389
www.travellingstrom.com |
