Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 05-15-2012, 02:00 PM   #3511
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,062
Originally Posted by mbabc View Post
Sweet!
Thanks for posting Mike. The 'wisdom' thread has been a great read. I check it several times a day, keep it coming.
Finished your request, Mark. Added "Creating a Shortcut To Another Profile" Info.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 05-15-2012, 02:07 PM   #3512
AirLock
Adrift
AirLock's Avatar
Oddometer: 24
Yes, relative to the file size of a waypoint or a short track 3k to 5k points is large. I only meant relative to the limit of 10k 3k is small. Its not the speed i am having an issue with, its the random failures. Some transfers of larger files work but that is not the norm. Small files and waypoints usually work but not always. Perhaps this is an issue with one of our GPS though it seems from the site i referenced earlier it is a know issue they have not resolved. I asked here hoping to find out if this is something other have experienced and just not posted about or if it was just me.
Thanks for the feed back guys i think ill see if Garmin gets anywhere on this, my buddy has been emailing with them the last couple of days but so far its at the do you it turned on stage of questions...
AirLock is offline   Reply With Quote
Old 05-15-2012, 03:07 PM   #3513
TowPro
I want to ride
TowPro's Avatar
Oddometer: 1,787
Originally Posted by moto-treks View Post
Well, not older betas but it will install the last "official" release
Mine don't Have that choice. (Its windows 7 64 bit-
plus the Webupdater logo is all the way on the Left Upper part of the screen where yours is center.
Plus mine has a Big arrow logo on the LS screen. Must be a newer version.
2010 F800GS Stone Road Touring bike!
TowPro is offline   Reply With Quote
Old 05-15-2012, 04:24 PM   #3514
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 672
Originally Posted by AirLock View Post
The problem is we have had random problems sending tracks between units, the problems range from one or the other unit shutting down to Lost Connection error messages. After this error message no transfers will work until the units are rebooted. The small way points and very small tracks under say 900 points seem to work the most often. Tracks with 3000 to 5000 points almost never work. No software updates seem to have helped much though some were almost useless.
I shared a couple large 4K point tracks over the "Share wireless" feature last weekend using 4.03, didn't have any problem. We only shared tracks, no routes or waypoints if that makes a difference. Although the transfer took a really long time (~5 to 10 minutes), which seemed significantly longer than the previous 3.9 firmware release. Also, we always initiated receive mode first on the slave gps, then "send" on the master.
dvwalker is offline   Reply With Quote
Old 05-15-2012, 05:48 PM   #3515
AirLock
Adrift
AirLock's Avatar
Oddometer: 24
It's rare i have a 4k file work. Maybe i do have some hardware failing.. Damn it.
I wish there was a way to test for sure and decide which unit it is.....
Old 05-15-2012, 05:59 PM   #3516
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,062
Not sure how big this track file is but it was recorded last weekend on my Montana, and is 271 kms at auto setting, and it's going to take 8 minutes to do. It's been 4 already, and the transfer's at 52%.
Edit. File was 549K, and took 8 minutes.
My transfer was from my Montana 650 to my 62S.
Emmbeedee screwed with this post 05-15-2012 at 06:25 PM
Old 05-15-2012, 06:30 PM   #3517
woodsatyr
What?!!!
woodsatyr's Avatar
Oddometer: 254
Could you put the stock profiles on the wisdom page for folks to download if needed?
I'm still hot... it just comes in flashes now.
woodsatyr is offline   Reply With Quote
Old 05-15-2012, 06:35 PM   #3518
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,062
The stock profiles are in a Dropbox share. Not sure putting them into a forum is the best way to keep them available but we'll put some thought into it.
Old 05-15-2012, 06:43 PM   #3519
woodsatyr
What?!!!
woodsatyr's Avatar
Oddometer: 254
K. I was thinking I ought to get them and stash them somewhere in case I need them because I'm always messing around with mine.
Old 05-15-2012, 07:20 PM   #3520
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,062
If you do need them, we can set you up with access to the share.
Old 05-15-2012, 07:37 PM   #3521
TowPro
I want to ride
TowPro's Avatar
Oddometer: 1,787
thats what I did :)
If you edit the file, it's XML, you can kind of make out the settings.
TowPro screwed with this post 05-16-2012 at 04:12 AM
Old 05-15-2012, 07:41 PM   #3522
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,062
Originally Posted by TowPro View Post
thanks what I did :).
Predictive text strikes again?
Old 05-16-2012, 12:04 AM   #3523
_cy_
Oddometer: 2,725
are you referring to profile as in setup ... a total PITA to keep redoing all the settings again and again for all the beta changes.
downgraded to last stable 3.90 then to 4.02 for a trip to Texas. Just got back .. had problems with main menu holding changes. lost compass button, which disappeared from menu anywhere.
needing a functional GPS ... not a beta in works.... what version o/s do you recommend?
_cy_ is online now   Reply With Quote
Old 05-16-2012, 05:53 AM   #3524
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,062
I'm referring to "Profile" as in Montana Profiles. It's possible that you have to redo all the settings on your profiles if you're modifying the Garmin supplied default profiles, but if you create a bunch of new profiles from the Garmin supplied ones, you won't end up having them revert to default when you up or downgrade.
We all need functional gps units, obviously. I am not having any problems with 4.03.
Old 05-16-2012, 05:54 AM   #3525
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,062
Latest Wisdom Post: MORE WAYS A MONTANA CAN FAIL: The Dreaded White Screen:
Times are GMT -7.   It's 01:02 AM.
