Thread Tools Search this Thread Rating: Thread Rating: 296 votes, 4.91 average. Display Modes
Old 06-19-2012, 05:40 PM   #4066
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,464
Originally Posted by Emmbeedee View Post
You did know that version 4.20, available through WebUpdater, does give Alphanumeric sorting? At first I thought you were being facetious then I realized you may not have noticed a few pages back where we discussed it.
See...that's why I asked. I did miss something. I've been in Remote Medicals WFR class the past 10 days and they don't give you much time to "recreate" during these classes.
I'm updating to v4.20 now. . . Thanks for keeping an eye on me.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 06-19-2012, 05:59 PM   #4067
DRTBYK
DRTBYK's Avatar
Oddometer: 5,464
Originally Posted by dvwalker View Post
Well little by little, we did receive 1/3 of #17 on the master list in the last release. The waypoint sort setting sticks, like it should, so one needs to remember to set from Alpha back to Nearest if that is preferred.
The Montana really does need many of the other enhancement items though...dev team has been mainly concerned with stability this past year, with a few bones (route no-calc) here and there...
I'm with dvwalker, we got 1/3 of what FR#17 was requesting. I think we should definitely keep asking for the others.
Cheers,
Cheers,
Dan
All Things GPS
Old 06-19-2012, 06:18 PM   #4068
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by DRTBYK View Post
This is the Track Tool in Mac-BaseCamp:
As Abenteuerfahrer noted, it would be easier to use the Route Tool when there are roads that match up with the TAT maps and then convert them to Tracks. When you come to a unmapped road section in the TAT, just use the Track Tool to create a track of that section and "add" it to the previous or following Track section.
As a data point you can, using Mac-BaseCamp only, create a "mixed-route" (a route with both Direct and Along-road sections).
To create a mixed-route:
  1. Start by using one of the Along-road Activity's to map your route.
  2. When you come to a segment where your want to go "off-road" on the map, just move the cursor over to the Route in your List and select it. Open the Route Properties window and change the Activity to Direct.
  3. The Route on the map will change to a Direct Route but don't worry, just use the Cmd-Z (undo) and the Route will revert back to the Along-road route you had before. Now with the Activity still set to Direct the next via point you place will be in Direct Activity mode.
  4. Continue placing your via points until you get back to a routable road on the Map.
  5. When you want to go back to Along-road routing, just change the Activity in the Route Properties window and you're Along-road routing again. You can repeat the steps above as many times as you like to create your route.
I then recommend converting your mixed-route to a Track.
Cheers,
What version of base camp are you running? Mine looks different,it doesn't show route tool or track tool-I'm running 3.3.2.0 version(I thought the latest) . Mine has: hand tool ,zoom, selector,waypoint , create route,overview map,activity. I did try to switch from motorcycle to "Direct" when I was trying to connect way points across that section of un mapped roads.
leftystrat62 is offline   Reply With Quote
Old 06-19-2012, 06:42 PM   #4069
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
That is 3.3.2.0 for Mac, as is my screen shot below.
Does this help? Go to View/Customize Toolbar
Emmbeedee screwed with this post 06-20-2012 at 10:03 AM
Old 06-20-2012, 12:37 AM   #4070
konfucius
konfucius's Avatar
Oddometer: 220
Yeehaw!
Running WebUpdater gives the update, with the following changes:
Changes from version 4.10 to version 4.20:
Added ability to sort waypoints alphabetically
Improved search speed in Where To? menus
Fixed review of individual route points through the Route Planner
Fixed issue with the Glide Ratio data field
Fixed occasional map display issue when using Topo Deutschland 2012 Pro or Garmin TransAlpin 2012 Pro
Just compared my 650 with 4.20 and my wife's 650 with 4.10 and there's a new "Sort" field that allows you to sort by "Nearest" or "Alphabetical" in the menu in "Waypoint Manager" and in "Where To/Waypoints".
Yay!
Does it still have the problem/limit with maximum 50 points in a route?
konfucius is offline   Reply With Quote
Old 06-20-2012, 05:07 AM   #4071
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
I added a new post about using Javawa Device Manager to enable map visibility in BaseCamp to the Wisdom and FAQ thread.
Old 06-20-2012, 07:46 AM   #4072
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 767
I wonder if you could install Basecamp on your memory stick, or make a portable app out of BC?
It works!!!
This saves a step of having to install BC onto a host computer for emergency track repair while out in the field. I simply copied the BC app files from my PC into a folder on the SD card. I had to include GlobalMaps (\Basecamp\Maps folder) since BC requires at least one map during initial load. After initial load then BC will recognize the other BC enabled map files (img files) from the Montana. Very cool...
1. In windows 7, BC is installed in the C:\Program Files (x86)\Garmin\BaseCamp directory
2. copy all files (*.dll, *.exe, etc) and \Maps folders to directory on your SD card. I created folder [SD]:\Tools\basecamp. I skipped copying the help file folders (\en).
3. plug Montana into any Windows XP/7 PC and run BaseCamp.exe
notes:
  • \Database folder is a copy of My Collection (Alldata.gdb) database in case I ever need to do an emergency import.
  • \Setup folder is a copy of the BC installer file, just in case I need to install onto host computer...
dvwalker is offline   Reply With Quote
Old 06-20-2012, 08:06 AM   #4073
Jon_PDX
Oddometer: 1,114
Base Camp on memory stick
DV,
That is a great post
Thank you very much for posting the info. I even printed it out for safe keeping.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 06-20-2012, 08:15 AM   #4074
ramz
Professional Trail Rider
Oddometer: 1,990
This needs to be in the Wisdom and FAQ thread. Please.
ramz is offline   Reply With Quote
Old 06-20-2012, 08:37 AM   #4075
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
With DVWalker's permission, I would post it.
Old 06-20-2012, 08:37 AM   #4076
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
It works!!!
Awesome! Glad to hear you made it work!
Old 06-20-2012, 01:12 PM   #4077
BobM
DualSport
Oddometer: 326
That was fixed in V4.10 - see this post.
There is a 50 waypoint limit for routes that use Follow Roads routing (i.e. all Activities except "Direct"), but that's the same for most Garmin GPS. I haven't found the upper limit of waypoints for Direct Routes but it's at least the same as the 60CSx (i.e. 250 waypoints).
Bob
BobM is offline   Reply With Quote
Old 06-20-2012, 07:57 PM   #4078
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 767
As a CYA, I searched and didn't find any legal lawyer stuff on Garmin's website that says we can't redistribute/run their free BC software in this fashion. Let me know if anyone knows otherwise....
So you have my perm to post to the wisdom thread, gulp...
Emmbeedee, just wanted to say good job collecting all the random thoughts and data bits in the wisdom thread. Really starting to look like an excellent reference for folks trying to move forward in the Montana learning curve.
Old 06-20-2012, 08:06 PM   #4079
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
Ok, thanks for the permission, and for the feedback on the Wisdom and FAQ thread. I doubt Garmin would care; it's not like anyone's making money on it, or reverse engineering their product.
Old 06-21-2012, 01:26 AM   #4080
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Great post!
Was this even possible without JaVaWa?
atlas cached is offline   Reply With Quote
Times are GMT -7.   It's 03:51 AM.
