Thread Tools Search this Thread Rating: Thread Rating: 344 votes, 4.92 average. Display Modes
Old 06-27-2012, 03:14 AM   #4156
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,756
Nearly 2ooo ks over the next two weekends so that will sort it out- I also have trouble at times with loading tracks and routes and have to do it numurous times checking to see if has loaded and make sure when following routes with more than 50 points choose direct route
Beer'o'clock Baz is offline   Reply With Quote
Old 06-27-2012, 03:57 AM   #4157
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Sounds like you might be using Mapsource to load the tracks and routes, if you're having that kind of trouble. Should be using BaseCamp to do that with the Montana.
Old 06-27-2012, 04:45 AM   #4158
Beer'o'clock Baz
Oddometer: 1,756
Yeah your rite i use both but didnt realise {until now } it was mapsource [depends what riders send the tracks to me in}-will send to basecamp then load them from now on -thanks mate
Old 06-27-2012, 05:01 AM   #4159
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by Jettn Jim View Post
I'm at about 6,000mi in the last month with the new Montana and have had the whiteouts since taking it from the Ram mount and putting it in the Rugged mount on the dash. I too have come to the conclusion that it's VIBRATION related.
I shake the thing somewhat. Always off-road. As far as I am concerned, on the Rugged Mount without battery, it nevers shutdowns. With batterry, it shut downs every 2 minutes or so ...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 06-27-2012, 05:15 AM   #4160
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Originally Posted by TravellingStrom View Post
This is something I knew nothing about, but will look into it, thanks
Cheers
TS
So were you able to sort out your Geocache loading issue? If it's Groundspeak Pocket Queries you're loading, all you need to do is load the query_name.gpx into the \Garmin\gpx folder and the gps just swallows it up whole and shows you the caches.
Old 06-27-2012, 09:02 AM   #4161
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,776
Paul Jr
I wish it never shut down on me without the battery installed, but it does.... I'll pull the batt and try it again today up Horse creek.
JJ
Jettn Jim is offline   Reply With Quote
Old 06-27-2012, 11:29 AM   #4162
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
JJ
Jim,
We talked about the Montana a couple weeks ago when Pigpen, Jungle Man, and I ran into you and Parepin at the top of Camp Creek road near Imnaha.
The open street maps that we talked about I learned about on this thread from Emmbeedee. They are available at http://www.osmmaps.com/index.html . These let you see all road detail at a 2 mile zoom on the Montana.
When I first got my Montana at the beginning of June, it crashed on me a few times just while I was playing with it. I updated it to the latest released firmware and the problem went away for the most part. On a 2000 mile trip it might have turned off on me once, and that includes lots of bouncing around.
As for the vibration damping, the mount I modifed for it provides some additional damping, only costs $15 and a bit of time with a drill press. See this post: http://advrider.com/forums/showpost....postcount=3876
Steve Lavigne
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch screwed with this post 06-27-2012 at 02:56 PM
Nut Clutch is offline   Reply With Quote
Old 06-27-2012, 02:13 PM   #4163
wtiger
Submariner
wtiger's Avatar
Oddometer: 144
upon start up, gets locked in 'loading photos'
screen freezes in startup, loading photos... I can shut it down by holding the power button, but then to power it back up, i have to remove the battery...
i just loaded 4.2...
wtiger is offline   Reply With Quote
Old 06-27-2012, 02:17 PM   #4164
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
I would do a reset, if that was mine: info here.
Old 06-27-2012, 07:03 PM   #4165
gregdee
Motocampist
gregdee's Avatar
Oddometer: 450
Import KML file
I tried to import a KML file of a route I found that displays fine in Google Earth. I go to Import, then open but then I cannot get the track to appear on any menu or in Base Camp. What am I doing wrong?
gregdee is offline   Reply With Quote
Old 06-27-2012, 07:50 PM   #4166
Crash-n-Skid
WileeeCoyote
Oddometer: 33
Vibration
"As for the vibration damping, the mount I modifed for it provides some additional damping, only costs $15 and a bit of time with a drill press. See this post: http://advrider.com/forums/showpost....postcount=3876"
That's exactly the kind of mount I was thinking I might need to make and use. Thanks for posting that link.
I was really thinking it was the battery connection, not so sure now. I'll leave the foam stuffed in the battery compartment and focus on a location and mount that reduces vibration.
Cancer, Heart Disease, Drowning. All preventable with a vegan diet and a life jacket. (South Park)
Crash-n-Skid is offline   Reply With Quote
Old 06-27-2012, 08:08 PM   #4167
Splatman
ADVrider wannabe
Splatman's Avatar
Oddometer: 33
Below is the mount I made.. Anti vibration mounts ~ $5.00 for 4.. $3.00 in aluminum.. Few dollars for nuts & bolts.. Total ~ $12.00..
Previously on my Garmin V and then my Garmin 276C I always used Touratech mounts.. I needed something very secure for off-road single track riding (Husqvarna WR250).. For me it wasn't about the bling factor and I was ok with the price because they were bought used from Ebay (about $50.00)..
But with the Garmin Montana the AMPS mount was said by others to be very secure.. And was still needed even when used with the Touratech mount (~$200.00).. Since the Montana is relatively new not many used Touratech mounts were being sold on Ebay.. But I wanted some anti-vibration damping to protect the electronics.. So I made a few of these..
Splatman is offline   Reply With Quote
Old 06-27-2012, 08:23 PM   #4168
TowPro
Lets ride
Oddometer: 3,164
How about removing the extra memory card and see if it boots without it installed.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 06-27-2012, 08:38 PM   #4169
wtiger
Submariner
wtiger's Avatar
Oddometer: 144
This.
after a number of resets, and even reloading the new update, it still would freeze up... for some reason i removed the extra memory card and put that in my computer. PC told me there was an error on the card and i clicked on 'fix'
while the card was out, the unit worked fine, and after the PC fix, the unit has been working fine.
Go Figure. I am not computer savvy enough to know what the problem was... but it seems to have been fixed. so yes, good idea!
Old 06-27-2012, 09:13 PM   #4170
TowPro
Lets ride
Oddometer: 3,164
This.
Emmbeedee?
Does he need to reformat the card?
wtiger, do you have maps installed on the extra memory card?
Times are GMT -7.   It's 05:49 AM.
