06-27-2012, 08:47 PM
#4186 |
Submariner
Oddometer: 78
i put the city nav 2013 and a bunch of topos from gpsfiledepot on a 32 gig card. when i put it in the card reader, microsquish indicated errors, and gave an option to fix... i did that, and since then the gps has not frozen up... i am willing to reformat the card if this comes back up... what do you guys think?
http://www.youtube.com/user/wtiger5252 |
06-27-2012, 10:07 PM
#4187 | |
Back Home
Oddometer: 1,546
moto-treks screwed with this post 06-28-2012 at 09:30 AM |
06-27-2012, 10:23 PM
#4188 | |
Oddometer: 388
Yeah, I did do that and for the first time got a message saying I have reached the limit for geocaches? Not sure whether I need to remove some of the other stuff I have in there, but after this weekend I should get a chance to clean up as there are a lot of waypoint files in that folder Cheers TS I just fired it back up again and never got that message this time, so maybe I won't touch it ;)
www.travellingstrom.com TravellingStrom screwed with this post 06-27-2012 at 10:34 PM |
06-28-2012, 12:43 AM
#4189 | |
OX Ambassador
Oddometer: 415
Remove one of your geocache GPX files, reboot the Montana, return the GPX file, and reboot again. Do you still get the warning? |
06-28-2012, 02:37 AM
#4190 |
NORTH WALES TRF.
Oddometer: 1,963
When recording a route, ie, making a track with the Montana, the 'Track Log On' icon is hit. Track starts recording and you can see the line travelled on the screen. Then after a while the line becomes broken. When back at my PC, the route has not been fully recorded. There was never a 'Lost Satellite' shout from the unit nor was I under trees, bridges or inner city.
This only seems to have started after the last software update I loaded, v4.10. The rest of the unit seems to be operatng fine. Any ideas? T. Edit: Just put v4.20 in, but no mention of a fix for this in the brief.
The Rave Generator...... Timpo screwed with this post 06-28-2012 at 02:56 AM |
06-28-2012, 02:56 AM
#4191 | |
Procrastinators
Oddometer: 5,790
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
06-28-2012, 04:58 AM
#4192 |
Oddometer: 103
06-28-2012, 09:42 AM
#4193 | |
This is Liv'n!!!
Location: Northeast PA, Some... On HIGH ADVENTURE Most!
Oddometer: 1,224
thanx for the info and the links! I'll try to do the latest firmware update tonight and also load that mapping program you showed me. Thanx again and Peace, Woooop Wooop Jim |
06-28-2012, 10:41 AM
#4194 |
SE Asia adventure tours
Oddometer: 573
Hey guys - I have a basecamp question I was hoping you could help me with.
I'm in Indonesia right now and have a good Indonesian map on my unit, but I want to see the maps on a laptop I am using. I've downloaded basecamp onto the laptop, have plugged my device into it and can see my device and all my waypoints and tracks. However I can't view the Indonesian maps on the big laptop screen. I tried going under the view tab AND in the drop down menu but it just is not listed in either place. I thought it was going to work when I used my device as a external hard drive. I opened it up, and had 2 folders; documents and Garmin so I clicked on Garmin: ![]() When the folder opens I can see the file - "navigasi.net Indonesia Maps". ![]() Clicking on it to open it I found the default program to open it was something called "Windows Disc image burner". I changed that program to BaseCamp, clicked on it, and it looked like it was going to open after "struggling" for a bit but then I got this message: ![]() and it wouldn't open. The map is working great on my device, I just want to be able to see the map on the big lap top screen to work some routes. Sorry I should have said I'm using my 62s but posted here as this seems to get the most traffic. :) Any help greatly appreciated!! |
06-29-2012, 12:07 AM
#4195 |
Oddometer: 573
Atlas huge thanks - it worked!! And also thanks for the tutorial and links Embeedee!
For any other "techno-tards" like me reading this, here it is with pictures. 1. Download the link Atlas links to above - v1.4 is 2.93 megabytes (about 20 minutes download time on Indonesion broadband! )2. This is the page that comes up when you start the javaWa program: ![]() Mine didn't find my unit until I hit the "scan drives" button in the upper left corner. From there I just clicked on the manage maps button and the following page came up with the maps on my 62s (I'm sure Montana would be the same): ![]() I clicked on the map that I hadn't been able to see in basecamp before and then just clicked on the visible in basecamp button. The only catch was I had to shut down basecamp first. When I reopened it, it worked no problems! One more question for you experts: Should my Indonesia map now be visible on all computers with basecamp when my unit is plugged in, or do I need to download javaWa on all the computers I download basecamp on? (I like to travel light without a computer, and here in SE Asia, ever town has tons of "internet cafe's" where for mega cheap you can rent computer time with BIG screens!) |
06-29-2012, 12:18 AM
#4196 | |
OX Ambassador
Oddometer: 415
Also, no need to download JaVaWa Device Manager on each computer. Just install it to the uSD card on your GPSr and use it with any host PC. Likewise with BaseCamp. Just copy your BaseCamp program directory to your uSD card, and run from there on any host machine! I store many additional maps, waypoint files, tracks, routes, GPX files, etc. in a hidden directory on my Montana uSD card, and am able to manage the unit quite nicely running BaseCamp and JaVaWa Device Manager directly from the unit itself on any host machine with a compatible operating system. Cheers!
06-29-2012, 05:55 AM
#4197 | |
Oddometer: 388
Sent from my iPhone using Tapatalk Cheers TravellingStrom
www.travellingstrom.com |
07-01-2012, 12:51 PM
#4198 |
Motocampist
Oddometer: 179
I keep trying this and get the same result: nothing. Anyone have any insight? The import function acts like it works but I don't see the track on my map and it doesn't show up in any menu that I can see. Help!
07-01-2012, 03:35 PM
#4199 | |
OX Ambassador
Oddometer: 415
07-02-2012, 01:35 PM
#4200 |
Ungeneer to broked stuff.
Oddometer: 1,848
Heat stops screen response
Anybody else seen this?
When hotter than about 90f, my 600 screen will continue to display but become unresponsive to touching the screen. Which is the main input method, of course. The power button still works. Pulling the battery doesn't help. If I put the unit somewhere cool, it will function normally when it cools about to the temperature of an air conditioned room. When placed in the cradle on the bike, the unit does not start up on the map page when powering up, so it is locked to the "home" page with the icons until cooled down. For our latest trip in the summer heat, this made it a very expensive and useless clock and we could not rely on it for navigation.
Super Tenere in black AMA, IBA June 2012 Maryland to Alaska: http://advrider.com/forums/showthread.php?t=796138 |
