Thread Tools Search this Thread Rating: Thread Rating: 371 votes, 4.93 average. Display Modes
Old 08-22-2012, 02:54 PM   #4711
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,763
Originally Posted by marco polo View Post
No I didn't.
If it happens again to you, give Master Reset a try. I don't think this issue has to do with the Route itself. I think it has to do with how the Montana is referencing the maps or Index.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 08-22-2012, 03:00 PM   #4712
DRTBYK
DRTBYK's Avatar
Oddometer: 5,763
Originally Posted by oxygenrace View Post
I looked back at the image in google earth and the resolution is fine, is there a way to ensure the image isn't resampled when i "save pace as"?
there are trail numbers on the map that aren't visible on the montana. is it the resolution of the montana screen?
Check the Image (CustomMap) in BaseCamp. The image might have been reduced to meet pixel density restrictions. In which case you could brake up the image into smaller tiles and in Google Earth georef the tiles so you still keep the resolution you are after.
Cheers,
Cheers,
Dan
All Things GPS
Old 08-22-2012, 03:10 PM   #4713
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
Originally Posted by atlas cached View Post
When you say they do not show up on the Montana, do you mean in the Map Selection Menu or the Map Application?
Can you host one for download so I and/or others can look at it?
here are the files
http://www.4shared.com/archive/XtYyj...h_Area_2.html?
http://www.4shared.com/archive/C0JjG...h_Area_1.html?
oxygenrace is offline   Reply With Quote
Old 08-22-2012, 03:15 PM   #4714
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
Cheers,
the image looks fine in basecamp. the image is only 500K but 300dpi. garmin says that images will be resized if greater than 1MB.
Old 08-22-2012, 03:33 PM   #4715
DRTBYK
DRTBYK's Avatar
Oddometer: 5,763
Sorry, I don't register at sites like this - they just sell my info.
Cheers,
Cheers,
Dan
All Things GPS
Old 08-22-2012, 03:52 PM   #4716
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
Cheers,
can you recommend a site? I registered just to share the file.
Old 08-22-2012, 04:19 PM   #4717
DRTBYK
DRTBYK's Avatar
Oddometer: 5,763
I use www.Dropbox.com. People that you want to share data with do not have to have an account to access it. You get a lot for free and they don't share your personal info.
Cheers,
Cheers,
Dan
All Things GPS
Old 08-22-2012, 04:32 PM   #4718
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
Cheers,
ok here are the files for limerick forest
https://dl.dropbox.com/u/99840880/Li...20Area%201.kmz
https://dl.dropbox.com/u/99840880/Li...20Area%202.kmz
Old 08-22-2012, 04:40 PM   #4719
DRTBYK
DRTBYK's Avatar
Oddometer: 5,763
The image pixel density is greater than 1MP. You need to reduce the "resolution" of each image to below 1MP before you import it to Google Earth.
Example: 1024px x1024px = 1MP as atlas cache noted some posts back.
I just opened them in BaseCamp and the image Resolution is 8MP. Reduce the image resolution to ≤ 1MP
Cheers,
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 08-22-2012 at 05:01 PM
Old 08-22-2012, 07:49 PM   #4720
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
Cheers,
by breaking the image into chunks I was actually able to piece together a trail map with satellite imagery behind it and the resolution is great. they all get packaged together into one kmz file. check it out.
https://dl.dropbox.com/u/99840880/Li...st%20South.kmz
i'll have to test it riding to see how the draw rate is.
thanks for all the help.
Old 08-22-2012, 07:54 PM   #4721
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Hey, that looks really nice!
Hope it works to your satisfaction... Let us know!
atlas cached is offline   Reply With Quote
Old 08-23-2012, 04:41 AM   #4722
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 490
Just got back Saturday from a one-month motorcycle trip with the Montana. ... I'm not sure where this leaves me. No, I have not yet called Garmin.
I had exactly the same experience as you did only I use Winders7. I too was/am on a month long trip to ride the Trans Labrador Hwy, Labrador, Newfoundland, and Nova Scotia. Did the same as you taking all the precautions noted throughout this thread. Got the same results. I ended up using the Where to, pick a waypoint, go method of routing because none of my routes created in Basecamp were usable.
woodsatyr is offline   Reply With Quote
Old 08-23-2012, 05:46 AM   #4723
Jon_PDX
Oddometer: 1,114
WOW.....that's really cool looking!
I've read about others doing that but that is the first time I have seen the end result. Does it look the same on the Montana as it does in BaseCamp?
Guess I need to go back and read up on how you did that.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 08-23-2012, 10:17 AM   #4724
DRTBYK
DRTBYK's Avatar
Oddometer: 5,763
Nice job on adjusting your imagery and adding the sat background. I use BirdsEye Sat Imagery - it provides zoom layers like the maps.
If you're not moving to fast the map refresh rate should be OK.
Zoomed In on the Montana
Cheers,
Cheers,
Dan
All Things GPS
Old 08-23-2012, 10:22 AM   #4725
atlas cached
OX Ambassador
Oddometer: 688
Are you using the layered JPG's with CustomMaps? If so, please explain how! Last time I checked, CustomMaps will not function with layered JPG's.
Times are GMT -7.   It's 12:31 AM.
