Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 08-25-2012, 08:24 AM   #4771
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 3,181
Originally Posted by B2 View Post
Hey fellas
on basecamp what does the activity profile change and which should i be using
thanks
In BaseCamp, from the HELP file:
Activity Profiles
You can select activity profiles for different activities. Each activity profile stores preferences for displaying the map and calculating routes. You can add custom profiles, and you can customize the included activity profiles.
Use whichever Activity suites your ride planning needs. Currently, none of that information is passed to the Montana except what Routing data is normally used to create a route.
Cheers,
Dan
DRTBYK is offline   Reply With Quote
Old 08-25-2012, 02:32 PM   #4772
B2
"Racin Mason"# 4
B2's Avatar
Oddometer: 1,392
Activity Profiles
Thanks mate -the part that you said it doesn't get passed on to the montana is what i was after
B2 is offline   Reply With Quote
Old 08-25-2012, 09:46 PM   #4773
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 422
seeing this behavior previously...
When setting the Zoom Level for "User Waypoints", the Montana considers my actual User Waypoints and what used to be called Custom POI's (on the Montana now called "Extras") to be the same.
Meaning if I load the POI-factory's "Free Wi-Fi" list (67K locations) onto the Montana using POI loader, and I have a few User Waypoints loaded, say "Saloons that I frequent" , the map (in a city) is completely obscured by the clutter of the Custom POI's (Free Wi-Fi). If I'm in a less densely populated area, and I want to pan out to get my bearings, again, way too cluttered with the Custom POI's.
On the 60/76 series, "User Waypoints" and user-loaded POI's are treated differently. You can set the zoom level of User Waypoints to be visible at 500 MILES resolution, but you won't see Custom POI's until you're zoomed in to 500ft or below (pre-set, not adjustable).
Anyone know a way around this? I want to see my WAYPOINTS when zoomed all the way out, and I don't want to see my POI's until I'm zoomed in close.
If not, can I make a motion to add it to the feature request list?
Feature Request #55 Created.
Garmin Montana Wiki Oregon 6xx Wiki BaseCamp Wiki
atlas cached is offline   Reply With Quote
Old 08-26-2012, 04:24 PM   #4774
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 53
Fuel gauge on montana?
Can the montana be calibrated to estimate when your fuel tank is getting low like the zumo?
oxygenrace is offline   Reply With Quote
Old 08-26-2012, 05:19 PM   #4775
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
Nope, but might be worth submitting to Garmin as an enhancement request.
But doesn't your streamliner have that capability?
"Don't play a lute to a cow" (Old Chinese Idiom)
Emmbeedee screwed with this post 08-26-2012 at 06:05 PM
Old 08-28-2012, 02:42 PM   #4776
bighopper
Oddometer: 124
Voice Guidance on Montana 650
I have been scratching my head the past few days trying to figure out why my Montana only gives me voice commands when I go off route eg; 'Recalculating' 'Drive x klm to turn'.
I do not get any voice guidance on any turn that will occur during the route. I have the latest CN North America NT installed & Enabled along with the World Base Map, all other maps are 'Disabled'.
I have the Montana mounted in the Rugged mount with the audio output connected to a Sena SM10 (Bluetooth transmitter) & have my SMH10 headset paired with the SM10. I am going to try using an ear plug headset direct to the Montana in the car to see if that makes any difference. But my feeling is that is something else that i am missing!
Any one have an idea what i should check?
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 08-28-2012, 02:47 PM   #4777
atlas cached
OX Ambassador
Oddometer: 422
Yep.
Which voice do you have enabled?
You will need a TTS voice for spoken street names, etc.
atlas cached screwed with this post 08-28-2012 at 05:33 PM Reason: TTL= TTS
Old 08-28-2012, 03:57 PM   #4778
bighopper
Oddometer: 124
I have Aussie Karen, which I thought would be a TTL but maybe I'm wrong. I will try one of the standard voice files that were on the Montana.
OK, just did a test using the Demo mode & all the voice files work with ear bud headset in the audio out jack of the Montana. Maybe it has something to do with the Rugged Mount (I have one on each of 1150GSA & K1200LT) I will test again tomorrow.
Originally Posted by atlas cached View Post
Yep.
You will need a TTL voice for spoken street names, etc.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
Old 08-29-2012, 10:52 AM   #4779
DRTBYK
DRTBYK's Avatar
Oddometer: 3,181
Montana's Display RULES!
I asked the folks at GPSCity to compare the displays in bright sunlight of the new zumo 350 and the Montana.
Looks to me as though the zumo Team blew the opportunity to provide better display technology. The Montana display is still the "gold-standard" for outside use IMHO.
Cheers,
Cheers,
Dan
Old 08-29-2012, 04:51 PM   #4780
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
Looks to me as though the zumo Team blew the opportunity to provide better display technology. The Montana display is still the "gold-standard" for outside use IMHO.,
Ugh, that's terrible. I'm sure the 350 will still sell to people who put too much emphasis on spec sheets, but I'm sure glad I have my Montana.
Old 08-29-2012, 05:31 PM   #4781
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
Cheers,
No
276, 378, 478 are still far better. Less resolution, but better against the sun.
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 08-29-2012 at 06:02 PM
Gros Buck is offline   Reply With Quote
Old 08-29-2012, 05:44 PM   #4782
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
Originally Posted by Gros Buck View Post
No
276, 378, 478 are still far better. Less résolution, but better agaisnt the sun.
Paul Jr
I think the selection only consists of currently available gps units.
Emmbeedee screwed with this post 08-29-2012 at 07:26 PM
Old 08-29-2012, 06:04 PM   #4783
Jeffer
Jeffer's Avatar
Oddometer: 86
No
Paul Jr
I own a 276C and a Montana. As for a prefrence the Montana exceeds the 276C from my feeble eyes
Jeffer is offline   Reply With Quote
Old 08-29-2012, 06:25 PM   #4784
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 167
Montana vs. ZUMO 350
We purchased a ZUMO 350 to see if we could cut the regulator of the cradle wire and replace it with a USB plug so it could be powered from one of our TAPP USB power ports (it worked fine). Never thought to compare the screen brightness against the Montana on my KTM.
We'll put the Zumo on Kurt's GSX-R and I'll stick with my Montana thank you very much. I just got back from a pretty long ride (London to Samarkand UZ) and the Montana was everything I could have hoped for an more.
Shov3BR is offline   Reply With Quote
Old 08-30-2012, 04:09 AM   #4785
TravellingStrom
TravellingStrom's Avatar
Oddometer: 388
Help, Buggered Screen
Hi all
Once again the Montana has let me down
This time the screen is broken. It lights up but the touch screen itself will not work, so it is useless :(
I grabbed a Torx bit and dismantled it and on close inspection it seems there is a crack on one side and that may have let some water in between the glass and whatever else is there
It is still under warranty, but am not sure this will be covered, so if I can I need buy a replacement
The issue is I am now in China, so I am not sure how to go about it
Can anyone let me know if it is possible to buy the screen separate and if so what part numbers please?
I can probably take it to an electronics shop when I get to Urumqi in about 5 days, I am reluctant to send it anywhere
on a second failure, there is no longer any power coming out of my Rugged Mount, I had a bit of an off so there may be a broken wire I have not found yet, but I do not know which of the 6 pins are the power connectors, any ideas please?
Cheers from Kashgar
TravellingStrom
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Times are GMT -7.   It's 12:17 AM.
