Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 09-19-2012, 07:21 AM   #5116
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,547
Originally Posted by DRTBYK View Post
Yes, but, not exactly. Since [you] created a Route you did select a destination somehow even if you didn't create a Waypoint. That destination will be in Recently Found, which just happens to be one of the "Search Near" options.
Cheers,
True, if you created the route on the GPS via a "Where To", City, Waypoint, POI, etc. But, it you create a route on a computer, download it to the GPS and then select that route, there is no "Recently Found" option for your destination. This is where the "Search Near" destination option would be nice.
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 09-19-2012, 07:26 AM   #5117
DrtSqtr
DrtSqtr's Avatar
Oddometer: 80
first issue with my 600
Hello all,
Ok so I've had my first bug pop up. ive had my 600 for a few weeks now. been testing it between the car and my 690e upgraded from v4.2 to 4.5 and now ive lost 90% of my street names. My map shows all the streets but wont show the names any longer. I have CN2010 loaded on a 32g card. I took card out while i did upgrade. Ive deleted and reloaded map on card just in case something was corrupted. tried changing the detail level on the 600 with no luck. master reset no luck. I thought i read in this post that a similar event happened to an inmate but now i cant find it..... any suggestions? I also took out the card and tried it in my other garmin devises and they all work fine (60csx & 705). any ideas ???
DrtSqtr is offline   Reply With Quote
Old 09-19-2012, 07:35 AM   #5118
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,209
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
Originally Posted by DrtSqtr View Post
Hello all,
Did your detail level get changed somehow?
Map - Advanced Setup - Detail (select from Most/More/Normal/Less/Least)
Old 09-19-2012, 08:21 AM   #5119
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 3,264
Ah, a little more data. . . since you cannot edit transferred routes I suppose they didn't see any reason to include actions that "might" be used to "edit" the route. But, I do see your point (no pun intended). I have a habit of always starting and ending a route with a Waypoint - no matter where I create it; GPS or Computer. It makes searching at my destination very easy.
I do think we need to lobby to get a few more features for Routing.
Cheers,
Cheers,
Dan
DRTBYK is offline   Reply With Quote
Old 09-19-2012, 08:59 AM   #5120
DrtSqtr
DrtSqtr's Avatar
Oddometer: 80
Tried all detail settings still no street names only thing that changes is the amount of streets shown.
Old 09-19-2012, 09:10 AM   #5121
DRTBYK
DRTBYK's Avatar
Oddometer: 3,264
Try this. . .
Setup -> Map -> Advanced Setup -> Zoom Levels -> Street Label -> anything but OFF.
If that doesn't do it for you call Garmin Prod Support and/or reload v4.50.
Cheers,
Cheers,
Dan
Old 09-19-2012, 09:27 AM   #5122
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,547
Yes I can if I send a "Direct" route to the GPS. I typically change the routing activity to "Direct" just prior to sending to the the Montana just for the capability. It does means a little more work as I then need to validate that the Montana routes the same as Basecamp.
Agree - It can't be that difficult - I'll send one off now
Moto-Treks
Old 09-19-2012, 09:41 AM   #5123
DRTBYK
DRTBYK's Avatar
Oddometer: 3,264
Sorry, I tend to forget about/ignore Direct Routing since it requires me to spend way to much time vetting the entire calculated path once I change it to Along-road routing. Much rather use a Track "under" my Route to let me know when the GPS routing algorithm decided to do something I didn't want it to.
[EDIT] I do see the advantage of your Direct Routing approach - maybe I'll play around a bit more with it. [/EDIT]
The good news here is that we both have workarounds for our needs. It's still hard for me to complain much about the features on the Montana - but I will ask for more
Cheers,
Cheers,
Dan
DRTBYK screwed with this post 09-19-2012 at 09:53 AM
Old 09-19-2012, 09:58 AM   #5124
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,547
Cheers,
Sometimes I think we cause more problems with our workflows I have a riding buddy that just upgraded to a Montana following my suggestion. I warned him that it may take some additional effort to learn compared to his nuvi. Well, a few days ago he told me the Montana is easer to use then the nuvi he loves it Made me think that I just might be putting too much effort into the whole thing
Moto-Treks
Old 09-19-2012, 10:33 AM   #5125
TowPro
I want to ride
TowPro's Avatar
Oddometer: 1,787
I agree with your buddy 100% :)
I stepped back, started over, and my Montana has been great
2010 F800GS Stone Road Touring bike!
TowPro is offline   Reply With Quote
Old 09-19-2012, 11:40 AM   #5126
shaweetz
shaweetz's Avatar
Oddometer: 175
Cheers,
Truth. For example, it was taking me no less than 8 taps to enable the power button screenshot and then capture my daily trip computer, and that is with a Setup->display shortcut. After adding a trip computer shortcut, discovered that almost every other setting under Display is available for shortcutting, but not the screen capture enable . Sent a request off to montanabeta.
shaweetz is offline   Reply With Quote
Old 09-19-2012, 12:26 PM   #5127
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 570
SO...has 4.5 passed the sniff test for upgrading from 4.2?
IBA #33260
cablebandit is offline   Reply With Quote
Old 09-19-2012, 12:50 PM   #5128
DRTBYK
DRTBYK's Avatar
Oddometer: 3,264
Working OK for me.
Cheers,
Cheers,
Dan
Old 09-19-2012, 02:09 PM   #5129
Dr. Greg
Tryin' to get home..
Dr. Greg's Avatar
Oddometer: 920
Saving waypoint using street address?
I just got the Montana, have an upcoming trip, so am trying to "figure it out" on fairly short notice.
My question: can I create a waypoint using a street address, then save it (using a name of my own choosing) for future navigational use? At first glance I don't see how to do this. Seems pretty basic.
Thanks for any help.
--Doc
2010 Ducati Multistrada 1200S (RIP...but REBORN)
2006 Buell XB12X Ulysses
2000 Kawasaki KLX300R
1992 Ducati 900SS
Dr. Greg is offline   Reply With Quote
Old 09-19-2012, 02:34 PM   #5130
Dr. Greg
Dr. Greg's Avatar
Oddometer: 920
Never mind...
I think I figured it out. Kinda "roundabout" but I figured out how to name it. Seems like you have to create a waypoint, then go back and change the name to whatever you want.
--Doc
1992 Ducati 900SS
Times are GMT -7.   It's 03:58 AM.
