Thread Tools Search this Thread Rating: Thread Rating: 373 votes, 4.93 average. Display Modes
Old 09-21-2012, 08:59 AM   #5146
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,597
Originally Posted by DRTBYK View Post
I don't think they "screwed up" anything. The Small (or Large) Data Fields is a single Dashboard. You set the data fields to the data types you want and they will be shown wherever the Small (or Large) Data Fields Dashboard is displayed. However, you can have your Map Dashboard set to display one Dashboard when Navigating and another Dashboard when not Navigating.
If one desires to have different data fields on a Dashboard under certain conditions, then the method would be to use a Profile to change them.
Cheers,
In 4.20 I could set up Small Data Fields for both navigating and non navigating, then I could select DIFFERENT data fields to be displayed for one or the other. in 4.50 I can no longer do that. Any changes I make in Non Navigating shows up in Navigating mode and vice versa. I used to do the same thing with my 478 2 different sets of small data fields for nav and non nav.
Old 09-21-2012, 09:15 AM   #5147
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,775
I just installed v4.20 and you must have been using another method because v4.20 does not have support for multiple Small Data Field Dashboards in a single Profile. I set the Map Dashboard to Custom and put Small Data Fields in Nav and non-Nav. I then set a data field to a different data type when Navigating and then when not Navigating and that data field stayed to whatever was the last data type I put there when I switched between Nav and non-Nav. No two different Small Data Field Dashboards in the same Profile.
Are you certain you weren't playing with different Profiles?
P.S, By the way, I think that would be a nice feature request but not sure it is possible with the current Dashboard support code.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK screwed with this post 09-21-2012 at 09:25 AM
DRTBYK is offline   Reply With Quote
Old 09-21-2012, 09:38 AM   #5148
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
You have to do a Master Reset to reset the Max/Min Temp's. No big deal. Just remember to set the unit Profile to Recreation before doing the MR. Then after reboot, just select your personal Profile and you're back in business.
Cheers,
If that was how it was supposed to work, wouldn't then the Data Fields just be named Max Temp and Min Temp?
As it is, they are named 24hr Max and 24hr Min.... So one would reasonably expect they would always read the Maximum and Minimum values over the previous 24hr period, regardless.
atlas cached is offline   Reply With Quote
Old 09-21-2012, 09:39 AM   #5149
atlas cached
OX Ambassador
Oddometer: 688
Cheers,
It is now a feature request :)
Old 09-21-2012, 09:45 AM   #5150
DRTBYK
DRTBYK's Avatar
Oddometer: 5,775
No argument - and I believe the data fields are name appropriately. The OP asked how to "reset" the data field which was the solution I offered.
Cheers,
Cheers,
Dan
All Things GPS
Old 09-21-2012, 09:54 AM   #5151
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,686
Apparently software version 4.60 is out.
Montana (WebUpdater) software version 4.60 as of September 20, 2012
Change History
Changes made from version 4.50 to 4.60:
Improved map drawing at low zoom levels.
Fixed inability to edit archived tracks.
Fixed ability to use NMEA depth for waypoints and tracks.
Fixed display of geocache coordinates with non-default map datum.
Fixed position display on waypoint page.
Fixed overlapping position text for right to left languages.
Can't try it as I don't have my Montana here.
The Garmin web page says to use "My Dashboard" to install the file.
Emmbeedee screwed with this post 09-21-2012 at 10:06 AM
Emmbeedee is online now   Reply With Quote
Old 09-21-2012, 09:54 AM   #5152
81husky
Oddometer: 114
Cheers,
I did the master reset, and the max/min values are the same as they were before. The MR didn't erase the temperature values that were in there. If I take the battery out of the Tempe, then it all goes back to current temp and starts over with a new max/min. I was hoping it would actually be a 24 hour cycle, but instead it's just the maximum and minimum for as long a the battery is in the tempe.
81husky is offline   Reply With Quote
Old 09-21-2012, 10:24 AM   #5153
BruceWA
Oddometer: 557
Just installed software version 4.60. Now for a look around.
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Old 09-21-2012, 10:34 AM   #5154
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,671
Any idea why this method rather than Webupdater?
BruceWA, did you do a master reset before you installed 4.60?
Old 09-21-2012, 10:38 AM   #5155
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,686
Nope, no idea. But I bet WebUpdater would also work.
Old 09-21-2012, 10:39 AM   #5156
atlas cached
OX Ambassador
Oddometer: 688
WebUpdater is how I do mine, and it did work for 4.60 :)
Old 09-21-2012, 10:39 AM   #5157
DRTBYK
DRTBYK's Avatar
Oddometer: 5,775
You are correct. When I did my MR, the data fields were blank when I rebooted. I didn't stay on the field long enough to see that they came back on the next ANT read cycle with the previous 24hr. Min/Max readings. This is not a very handy readout given the current operation.
Cheers,
Cheers,
Dan
All Things GPS
Old 09-21-2012, 10:41 AM   #5158
DRTBYK
DRTBYK's Avatar
Oddometer: 5,775
I started testing v4.60 last night (I don't sleep much) when it popped up on BaseCamp that a new version was available.
I used WebUpdater and it worked just fine.
Cheers,
Cheers,
Dan
All Things GPS
Old 09-21-2012, 10:41 AM   #5159
atlas cached
OX Ambassador
Oddometer: 688
Cheers,
Do you have any *.gpx files stored on the Montana that reference the Tempe? I am wondering if this information is stored as a GPX file.... Like other ANT info (chirp data, for example).
Old 09-21-2012, 10:54 AM   #5160
DRTBYK
DRTBYK's Avatar
Oddometer: 5,775
The temp data is "stored" in the Track Log. . .
And as I showed the other day you will find it in the properties window of the track.
I didn't see any other log file for ANT devices but then I only have the tempē. It does seem logical to use the Track Log for storage of ANT device data since it is easily correlated with position.
Cheers,
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 09-21-2012 at 11:09 AM
Times are GMT -7.   It's 11:32 AM.
