Thread Tools Search this Thread Rating: Thread Rating: 414 votes, 4.93 average. Display Modes
Old 09-23-2012, 04:46 PM   #5221
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,773
Originally Posted by Rocky TFS View Post
Sorry, I meant "mentally" simulating..... I just turned it on, loaded a route, and looked at the dashboard. No speed field. It never occurred to me to try demo mode. In fact, I'm not even sure how to, although I'm sure it's buried somewhere in these 350 pages....
I just hate it when my toys outsmart me!!!
Setup/System/GPS/Demo
Old 09-23-2012, 04:50 PM   #5222
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,773
Originally Posted by DRTBYK View Post
When the GPS is in Simulation Mode and you start Navigating a Route or Track, whether you "Simulate Driving" the Route or not you will see the Speed data field in the nuvi Dashboard.
Probably, but when I have my gps in demo mode, and load a route, I usually click "Go" then "Yes" to "Do you want to simulate driving this route..." to see what choices the gps will make.
Old 09-23-2012, 05:13 PM   #5223
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,738
Emmbeedee,
to you since you know this unit quite well and to the point, can i build large complicated routes that contain some unmapped sections that require switching to direct routing then back to auto routing once back on mapped roads all in the same continous route in Mapsouce then upload it to a Montana and will it run it as is like my 276c chartplotter will with no fuss?
thanks my friend,
frank
Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 09-23-2012, 05:15 PM   #5224
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,773
Originally Posted by DockingPilot View Post
Emmbeedee,
thanks my friend,
frank
Sorry to disappoint you Frank, I'm not an expert on Routes. In fact, I'm not an expert on anything! Except maybe Blackboard, the LMS
I usually follow tracks since they're more reliable for my purposes. Hopefully someone here will have the answers for you.
Old 09-23-2012, 05:25 PM   #5225
DockingPilot
Oddometer: 9,738
ok thanks anyway,
anyone else?
Frank Reinbold
Old 09-23-2012, 05:25 PM   #5226
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,773
Emmbeedee,
thanks my friend,
frank
Ok, having said I'm not an expert doesn't stop me from making suggestions, does it?
I would probably break down the kind of route you're suggesting into segments, and use waypoints to help in the direct routing. That way you wouldn't need to try to get the route to work in both direct and auto-routing modes.
Old 09-23-2012, 05:33 PM   #5227
johnpitts01
johnpitts01's Avatar
Oddometer: 1,061
Segments with waypoints. Pretty sure that is the method doc rock uses with the Montana.
DP. You considering the switch to Montana?
johnpitts01 is offline   Reply With Quote
Old 09-23-2012, 05:39 PM   #5228
DockingPilot
Oddometer: 9,738
rupee. im always searching for the next big thing. lol
so far nothing can replace our *76 units as far as i can tell in regard to the way we use them.
now go get your feet massaged. lol
Frank Reinbold
Old 09-23-2012, 06:42 PM   #5229
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,493
I have significantly used every Zumo from the beginning, minus the 220. Having the Montana for 3 days and a tank full of gas including offroad, I can easily say the Montana is the way to ride. Many of the Zumo limitations gone. Just to mention a few, real sunlight visibility, multiple maps and customizable... nice. Although not perfect, it does get close and the gripes are minimal.
Thanks for the push in the right direction.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 09-23-2012, 06:59 PM   #5230
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,784
Is map instability, rotating though different orientations, on my 600 while riding a map speed issue? I've tried different map speed settings, using garmin topo, and prefer north up vs track up.
katbeanz is offline   Reply With Quote
Old 09-23-2012, 07:02 PM   #5231
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,680
Quite a few of us have had the orientation swap issue, particularly when the unit is near level when mounted. Easily solved by locking orientation in the settings.
Old 09-23-2012, 07:09 PM   #5232
OceanMtnSea
Pretty Dogged
OceanMtnSea's Avatar
Location: left middle Saskatchewan & entering middle BC
Oddometer: 601
I have tried loading a large route into my Montana (Kelowna BC to Brookings, OR via Olympic Peninsula) and it did not work. No trouble creating the route in BaseCamp, but I just could not get it to load once I transferred it to the Montana.
In testing I found the only way to get it to work was to load it in smaller (day ride length) routes with start and finish waypoints and a couple of extras waypoints inbetween.
I finally went back and converted the entire route to a track and loaded my important waypoints so I could route directly to the waypoints if I decided to go off-track and then wanted to get to the next important waypoint.
I do not think it was a space limitation as I have 1/3 of my hard drive as free space......I just think that a very large route has too much data for the Montana to load and run efficiently. The brain can only handle so much.
J
2007 BMW Dakar & 2009 Ducati Multistrada leaving the middle of the in-land sea called Saskatchewan for the Mountain Valleys of BC, Canada
http://s737.photobucket.com/user/Oce...?sort=3&page=0
OceanMtnSea is offline   Reply With Quote
Old 09-23-2012, 07:36 PM   #5233
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,739
J
The Montana is limited to only 50 viapoints in a route. Kinda hamstrings you when you want to do complicated routing.
Old 09-23-2012, 10:05 PM   #5234
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,897
Wow, we seem to be all over the place on this topic.
Strait answer to your question is, yes, you can have a mixed (on/off-mapped road) routes and send it to the Montana but you'll have to have the exact same map set on the Montana as MapSource or BaseCamp did when you created the route (and yes, you can make mixed-routes in BaseCamp). Just have to remember to set Recalculation to OFF when you navigate your mixed-route.
Example of Mixed-Route created in BaseCamp on 24K US North Central Topo:
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 09-23-2012, 10:18 PM   #5235
DRTBYK
DRTBYK's Avatar
Oddometer: 5,897
J
There are a few limits when it comes to Along-road Routing. As mentioned there is a 50 Via Point limit. There is also a distance limit which I think (haven't tested lately) is 1000 miles. If one does judicious placement of Via Points AFTER intersections they seem to not get announced and you still get the intersection shown in the Navigation Info list. I have to believe you can make a rather complex along-road route (maybe not walking) with 50 via points.
One trick I used when I had zumo's was to use waypoints for information and not route path shaping. This enabled me to have lots of Waypoints associated with the route. I used Proximity Alerts so that I would get prompts on the zumo.
Cheers,
Cheers,
Dan
All Things GPS
Times are GMT -7.   It's 05:47 PM.
