Thread Tools Search this Thread Rating: Thread Rating: 428 votes, 4.94 average. Display Modes
Old 09-30-2012, 09:26 AM   #5326
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
Originally Posted by Elsjo View Post
Emmbeedee,I think I found your request on Facebook and added some, thanks.
Good! The more, the merrier!
Old 09-30-2012, 09:52 AM   #5327
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,451
I'm not much of a facebook'r, but I've found that when you post on Company facebook pages, ie: a public forum, you get things DONE!
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 09-30-2012, 10:12 AM   #5328
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
The only result I've seen so far from that is a couple of virus laden email messages from someone masquerading as "Cardo Scala Rider". I'm not holding my breath, but it would be nice if we could set our own audio source priority. It must be some engineer who's set that up so I don't see why they can't give users the choice.
Old 09-30-2012, 10:16 AM   #5329
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
You did get the right thread there. Just checked.
Old 09-30-2012, 10:34 AM   #5330
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,975
Originally Posted by scotty69 View Post
I registered the new Montana and under the maps section it shows I have Topo 100,000 but does not show city navigator. Does anyone know where to go from here to "unlock" city navigator on my new device?
When you purchased CNNA did you register it at my.garmin.com and link it to your previous Montana?
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 09-30-2012, 10:57 AM   #5331
scotty69
scotty69's Avatar
Oddometer: 903
Yes, I did have them previously installed on another Montana. I've been to my.garmin.com and cant seem to find any answers there.
Orchestrated Chaos
arkansas500.com
scotty69 is offline   Reply With Quote
Old 09-30-2012, 11:06 AM   #5332
DRTBYK
DRTBYK's Avatar
Oddometer: 5,975
If you don't see your CNNA maps listed under My Maps, then Garmin has removed the link to your old Montana. You just need to register your CNNA maps to the new Montana - just like you did the first one.
Cheers,
Cheers,
Dan
All Things GPS
Old 09-30-2012, 12:09 PM   #5333
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
'Installed' is not the same as 'Registered'. Did you register the map in your name on My Garmin?
Old 09-30-2012, 12:31 PM   #5334
Elsjo
Oddometer: 18
Also copy and paste it into a direct email, always unsure how facebook works, hopefully it will help, last firmware update for the scala was some time ago...
Elsjo is offline   Reply With Quote
Old 09-30-2012, 06:36 PM   #5335
dmottv
Take the Long Way Home
dmottv's Avatar
Oddometer: 419
Map Priority setting?
I just installed the GPSFileDepot Northeast Topo to my Montana and the detail is quite good. However, it's not routable. The CNNA is routable but when set active it appears it has a higher visibility priority, and the Topo becomes not visible even though still active. Anyone know if there is a way to set the Topo to a higher priority than the CNNA, so I can see the Topo but use the CNNA and it's routing capability?
Dave - NH Seacoast; RT-NH1; AMA; MVTR; NETRA;
'07 KLR650; '02 R1150RT-P; '01 R12C Montana; '00 KDX200;
Gone: '05 450EXC; '99 K12LTC; '94 KDX250; '92 R100GS; '77 R75/7; a few others...
dmottv is offline   Reply With Quote
Old 09-30-2012, 06:49 PM   #5336
dmottv
dmottv's Avatar
Oddometer: 419
Example
For example, the routing capability of Garmin's Canada Topo was very helpful while recently traversing the Gaspe, even though many of those old roads had become overgrown/disappeared due to nonuse. Newer roads were often nearby, and in one case we eventually discovered a little used older road that the CA Topo kept trying to route us on, that connected us to where we wanted to go, and the reward at the end of the Gaspe ride. Here's a few pics that show the gem through the hidden door:
Old 09-30-2012, 07:30 PM   #5337
Fred26
Fred26's Avatar
Oddometer: 13
Help! Leaving tomorrow and the Montana just died!
New to this thread. Looking for help with my Montana 650. Just purchased last Thursday for my trip tomorrow. Loaded maps, POI, some basic stuff to make it start working really. This morning, I turned it on after being charging all night and it started searching for satellites, since we were indoors it asked me if I wanted it to continue or stop, I pressed stop searching, and it turned off. When I tried to turn it back on the word 'Garmin' comes on, nothing else loads up, and after a few seconds, the screen goes white and shuts off. That's it! Keeps doing this routine and shuts off, never actually turns on. Hard reset doesn't work. Plug into the computer and it does the same. never shows that it is connected and just shuts off...any clues what to do? Will contact GArmin in the morning but my plans were to leave tomorrow....This sucks!
Fred26 is offline   Reply With Quote
Old 09-30-2012, 07:43 PM   #5338
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
I'd take any uSD card out, and try another hard reset this way:
To perform the master reset:
Power the device off
Press and hold your finger on the upper left side of the display
Power the device on while still maintaining pressure on the display
Release on the display when the Do you really want to erase all user data? message appears
Touch Yes
The Montana is now reset. You will want to leave the device outside with a clear view of the sky for a minimum of 20 minutes to acquire satellite data.
Old 09-30-2012, 08:06 PM   #5339
Fred26
Fred26's Avatar
Oddometer: 13
I tried this too. viewed it on a youtube video. Didn't work. Seems that it does not even start up. Only the word 'Garmin' comes up. No other fine print. the word Garmin stays on for a few seconds. Screen flashes and unit shuts off. Hard reset doesn't even get a chance. Any other ideas? The store I bought it from told me that I would have to go through GArmin if I had any problems as they don't refund or exchange. I need a GPS for tomorrow...sucks big time..
Old 10-01-2012, 03:35 AM   #5340
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
There's no way that I know of to set the map priority. CNNA always gets top priority, as you've found. But Garmin Topo Canada V4 is routable so why not just get that? I've seen it as low as $80 but it seems to be back up to $100 now at GPSCity and GPSCentral
Times are GMT -7.   It's 02:02 PM.
