Thread Tools Search this Thread Rating: Thread Rating: 437 votes, 4.94 average. Display Modes
Old 10-01-2012, 03:53 AM   #5341
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
Originally Posted by Fred26 View Post
I tried this too. viewed it on a youtube video. Didn't work. Seems that it does not even start up. Only the word 'Garmin' comes up. No other fine print. the word Garmin stays on for a few seconds. Screen flashes and unit shuts off. Hard reset doesn't even get a chance. Any other ideas? The store I bought it from told me that I would have to go through GArmin if I had any problems as they don't refund or exchange. I need a GPS for tomorrow...sucks big time..
Have you tried this?
http://garminmontanagpsr.wikispaces.com/Recovery
Old 10-01-2012, 05:32 AM   #5342
dmottv
Take the Long Way Home
dmottv's Avatar
Oddometer: 419
Originally Posted by Emmbeedee View Post
There's no way that I know of to set the map priority. CNNA always gets top priority, as you've found. But Garmin Topo Canada V4 is routable so why not just get that? I've seen it as low as $80 but it seems to be back up to $100 now at GPSCity and GPSCentral
You've confirmed what I thought, there's no way to set the map priority. Yes, I have the Topo Canada. The issue is regarding the GPSFileDepot Northeast Topo that I downloaded and installed. I suppose I could purchase the Garmin US Topo 1:24k that is supposed to be routable. Thanks much, Emmbeedee.
Dave - NH Seacoast; RT-NH1; AMA; MVTR; NETRA;
'07 KLR650; '02 R1150RT-P; '01 R12C Montana; '00 KDX200;
Gone: '05 450EXC; '99 K12LTC; '94 KDX250; '92 R100GS; '77 R75/7; a few others...
dmottv is offline   Reply With Quote
Old 10-01-2012, 08:00 AM   #5343
Fred26
Fred26's Avatar
Oddometer: 13
Gave it about 1 hour of my time. Seems to be getting somewhere but still would do the same thing and I just gave up. Returned the unit, they agreed to give me a new one since I was leaving today. Loaded up the new one and I'm shortly on my way to the Blue Ridge trail/Parkway. Thanks for all your help. This is awesome to get some real support so fast. Hope the new unit will be trouble free, I just love the Montana over the Zumo as long as it works :)
Happy riding!
Fred
Fred26 is offline   Reply With Quote
Old 10-01-2012, 10:35 AM   #5344
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 6,004
I've noticed an interesting condition with v4.60 and would like someone else to check this if you wouldn't mind. I use Shortcut's to set my Display Orientation Lock so that the display doesn't jump around when the going gets a bit bumpy.
With v4.60, I've noticed that the Display Orientation "Lock" setting is kept in the Profile so that when you power down/up the setting sticks. That's great but it seems to be causing another issue. When I try to switch display orientation with the opposite shortcut, it will not switch. If I do it manually via Setup it works fine. Also, if I change Profiles and then switch back to my custom profile, it will work again until I power down/up.
Could someone please confirm this behavior?
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK screwed with this post 10-01-2012 at 10:40 AM
DRTBYK is offline   Reply With Quote
Old 10-01-2012, 11:30 AM   #5345
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Cheers,
Duplicated and Confirmed with temporary solution:
atlas cached is offline   Reply With Quote
Old 10-01-2012, 11:33 AM   #5346
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,693
Best way to remove a single map?
Okay, Montana is at home, I'm stuck not at home.
I loaded a specific map (Black Hills USFS trails) for a trip, along with my other maps.
Now I'm done with the trip and want to remove this one map. Can I do that from the Montana, or do I need to go to the Map Installer program and perform a new install on just the maps I want to keep on the Montana?
Thanks for helping with what might be a simple and obvious question.
Old 10-01-2012, 11:41 AM   #5347
DRTBYK
DRTBYK's Avatar
Oddometer: 6,004
You cannot delete the map directly from the Montana settings BUT you can simply attach the Montana via USB and open the Montana storage location where you installed the map, select the map file and delete it. You do not need MapInstall to do this.
P.S, The Black Hills Forest Manager is the only one I've found who is forward looking enough to produce the MVUM in a Garmin format. Sure hope more Forest Managers take a look at what the Black Hills team did.
Cheers,
Cheers,
Dan
All Things GPS
Old 10-01-2012, 11:47 AM   #5348
OceanMtnSea
Pretty Dogged
OceanMtnSea's Avatar
Location: left middle Saskatchewan & entering middle BC
Oddometer: 607
"Okay, Montana is at home, I'm stuck not at home."
What you can do on the Montana is just "disable" the map and it will not be shown on the Montana in that user profile.
Setup - Map -Select Map .....then choose the map you want to disable or enable.
2007 BMW Dakar & 2009 Ducati Multistrada leaving the middle of the in-land sea called Saskatchewan for the Mountain Valleys of BC, Canada
http://s737.photobucket.com/user/Oce...?sort=3&page=0
OceanMtnSea is offline   Reply With Quote
Old 10-01-2012, 11:49 AM   #5349
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,693
Ah, thanks! I can already see it in my mind's eye and will do exactly that.
The reason I want it off the Montana is that it is enabled by default in every profile. It seems easier to remove it for now, than to have to modify every profile (and I have plenty.)
Old 10-01-2012, 11:55 AM   #5350
atlas cached
OX Ambassador
Oddometer: 688
This has LONG been one of my biggest gripes with Garmin. Every Garmin GPSr I have owned (more than a dozen) will automatically enable any new maps loaded to the unit. If you have several maps you update often and several profiles, this can be a very time consuming process to go into each profile and enable/disable every time, on each of your GPSr units.
I have asked many many times that they do not automatically enable every new map loaded, but they have not responded.
Old 10-01-2012, 12:05 PM   #5351
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
Got a Tempe Sensor today. There seems to be a bit of a run on them right now - GPSCity was out of them and not expecting any until Oct 15, but I found one at GPSCentral.ca.
Looks like it works with multiple gps units at once, which is nice. I have it connected to both my Montana and 62S.
Old 10-01-2012, 12:35 PM   #5352
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 705
4.6 issue.
I have a handful of tracks loaded from a 6 day trip last month. I have a track for each day's ride and just "show on map" at the beginning of the day's ride. At the end of the day I would hide that day's track and "show" the next day.
I've always had an issue with the "show on map" button functioning unless I wait a while. I'm guessing it's doing some background calculations based on the number of points. (they were long tracks). However, ever since 4.6 the first two day's tracks always show on the map after I power up the unit. I can hide them but as soon as the unit is power cycled they show up again.
I'm not sure if anyone else has noticed this. It's not a big deal as I can just delete them, but thought it was worth mentioning.
IBA #33260
cablebandit is offline   Reply With Quote
Old 10-01-2012, 12:39 PM   #5353
igormortis
igormortis's Avatar
Oddometer: 1,388
There don't seem to be any Tempe sensors to be found here in New Zealand, but that's no surprise - we'll probably get them much later. Buying online from the US doesn't appear to be an option either, since shipping quotes are about $45...
igormortis is offline   Reply With Quote
Old 10-01-2012, 01:18 PM   #5354
DRTBYK
DRTBYK's Avatar
Oddometer: 6,004
Originally Posted by cablebandit View Post
4.6 issue.
The delay you are experiencing is because it takes a bit to load very high point counts into active memory space.
The Tracks showing after you "Hide on Map" and then Power cycle may be linked to the same Profile issue that I posted about earlier today. Some things seem to be "stuck" in the Profile when they shouldn't be and that is keeping some other functions from working. You should report this condition none the less to the Montana Team.
Cheers,
Cheers,
Dan
All Things GPS
Old 10-01-2012, 02:33 PM   #5355
TowPro
Lets ride
Oddometer: 3,242
Is there anyway to "reverse" a route I made in Basecamp and pushed to the Montana? I want to "reverse" it out in the field on the Montana. I am pretty sure I can do i in basecamp.
Example, I have three 60 mile routes on my GPS (that connect), running north to south.
This weekend I rode into the area of the routes from the south end. I know if ride into the middle of a route area, and press "GO" it will start to route you to the end (which turned out to be 1/2 mile away.)
But If I could just reverse the routes I would have been set
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Times are GMT -7.   It's 10:46 PM.
