10-06-2012, 05:29 AM
#5461 |
Kool Aid poisoner
Oddometer: 4,813
Probably the most important aspect of a GPS for me. Tracks are fine if I'm just smelling the flowers and taking in the scenery. But if I'm doing a serious pace, the last thing I need to be doing is staring down at a GPS.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
10-06-2012, 05:40 AM
#5462 | |
Kool Aid poisoner
Oddometer: 4,813
10-06-2012, 07:58 AM
#5463 | |
Long Haul Adventurer
Oddometer: 3,170
Cheers,
Cheers, Dan |
10-06-2012, 08:33 AM
#5464 | |
Kool Aid poisoner
Oddometer: 4,813
Well, the biggest issue being that routes are so mapset dependent. Maybe if Garmin actually put some effort forward in creating actual WORKING algorithms that would recalculate routes intelligently across different mapsets this wouldn't be an issue. I agree with you 100% that it would be nice to see this work. I was playing around with a route today that a buddy sent me. He created it on 2010.10 and when I try to recalculate it and then reshape it while using 2013.20 I can't get it to route the same. I know all the roads he's got routed STILL exist because I've ridden on them plenty. It's seriously frustrating that the algorithm is so flawed that it actually creates U turns rather then following the logical path simply because I changed the version of the mapset.
10-06-2012, 10:09 AM
#5465 | |
Oddometer: 3,170
Also, don't forget that all of the "dependancies" are eliminated with Direct Routing. Cheers,
Cheers, Dan |
10-07-2012, 03:17 AM
#5466 |
Oddometer: 3,692
I'm considering a Montana but am wondering about the mounting options.
Anyone know if the touratech locking mount can stand up to rough off-roading and trail conditions?
"Civilize the mind, but make savage the body." To the house of a friend the way is never long. "Show respect to all, but grovel to none." '12 690 Enduro |
10-07-2012, 05:26 AM
#5467 |
Oddometer: 539
Ready to buy - one question t or no t
Ready to pull the trigger.
Good price at REI plus 20% member discount on any item plus my member refund = great buy. So a bit of clarifcation, please; 1) Which Topos are non routable? 2) Are any of the Topos routable? As I understand 100k Topo are non routable. 24k Topo are routable. Is this correct? (I want non-routable Topo maps so I can create direct line mixed mode routes in Basecamp) The "t" version comes with 100k Topo maps pre-installed. These will be non-routable. Correct???
'12 Yamaha Super Ténéré (Blue) '08 WR250R I refuse to tiptoe through life only to arrive safely at death THE DEAN OF WESTERN ADVENTURE ROUTES Backcountry Byways Journal |
10-07-2012, 05:56 AM
#5468 |
Pretty Dogged
Oddometer: 442
I have the 100K topos and they are NON routeable........................don't know about the 24K topos thou.
2007 BMW Dakar & 2009 Ducati Multistrada entering the middle of the in-land sea called Saskatchewan Canada http://s737.photobucket.com/home/OceanMtnSea |
10-07-2012, 06:37 AM
#5469 | |
Procrastinators
Oddometer: 5,780
And just because a map is routable doesn't mean it forces you to use it that way.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
10-07-2012, 09:47 AM
#5470 | |
Oddometer: 240
Can only say my 650t is in a Touratech locking mount on my K1200GT, hope to also set it up for mounting on my 530EXC. Quality piece of gear, IMO.
Figures don't lie, but liars can figure |
10-07-2012, 04:00 PM
#5471 |
Oddometer: 192
CNNA 2013.2 won't route.
I don't remember this happening when I updated from 2012.4 to 2013.1. All my routes were created on 2013.1 or earlier, some way back in Mapsource. Now, with 2013.2 on the unit, when I choose a route, I get an error message that the route will not exactly follow the map, do I want to recalculate? When I hit yes, it says no routable maps in this area and kicks me back to the map with no route. (Or No, either way)
I haven't tested with all routes, direct or not, older than CNNA or not, yet. Perhaps the answer is obvious, but this is stumping me. I hope I don't have to go back and re-create several hundred routes!! ![]() EDIT: Perhaps I didn't actually use a route, but instead a recent find, i.e. a town 60 miles away I often go to for lunch. So I did a Where To?-Cities-spelled out the name, hit go, it routed normally. So now I look in recent finds, there are two Stanleys, one exhibits the above behavior, the one I just created routes normally. One test of an old route seems to work, so perhaps all that is necessary is to remember to clear the recent finds list when updating CNNA. More testing required. Perhaps when I last updated the map, I never used a recent find until the old finds from the previous CNNA had scrolled way down and were no longer visible. The Montana saga continues...... Rocky TFS screwed with this post 10-07-2012 at 04:43 PM |
10-07-2012, 04:20 PM
#5472 | |
OX Ambassador
Oddometer: 404
This is how Garmin works. I love their hardware, but their software engineers are the worst in the industry. |
10-07-2012, 05:14 PM
#5473 |
Procrastinators
Oddometer: 5,780
I don't agree - often the reason they can't keep software working as it was in the past is that there's a better way or something more they're adding in the new software. They aren't doing anything just to piss owners off. So if you need to rejig your routes, well, there's probably a good reason for it.
It's too bad for people who've got so much time invested in routes created with maps which have been updated, but I don't think that kind of thing can be avoided. IMHO of course.
10-07-2012, 05:33 PM
#5474 | |
OX Ambassador
Oddometer: 404
I am thinking more about the dozens and dozens of glitches included with each GPSr firmware update, and an absolute lack of useful functions/controls with their PC/MAC software. It's almost as if none of Garmins engineers actually use their own products. Of course, that is just my opinion. |
10-07-2012, 05:40 PM
#5475 | |
Procrastinators
Oddometer: 5,780
