10-09-2012, 02:25 PM
#5506 |
STILL Jim Williams
Oddometer: 5,953
10-09-2012, 02:35 PM
#5507 |
Deputy Cultural Attaché
You have yours wired like mine. You could just pull the mount off the bike, bring it in the house, and pop the Montana into it. If it's disconnected, it doesn't matter if it's on the bike or not.
Successfully surviving motorcycling since 1976. |
10-09-2012, 02:47 PM
#5508 | |
Long Haul Adventurer
Oddometer: 3,173
If I had the electrical schematics for the Montana power management system I could tell you if there was any possible way to have "leakage current" from the Montana; e.g, if there were a "drain" on the 12vdc external lines. But alas, I don't have those schematics. Disconnect your Mount power at the source (battery?) and see if you have battery drain with the unit in the mount - as Emmbeedee suggested. Cheers,
Cheers, Dan |
10-09-2012, 03:04 PM
#5509 |
Back Home
Oddometer: 1,546
Yes I do. And if you pick the "Turn off" or just let it turn off via the timeout it will still run the battery down. The 476c had a configuration option in the system menu that let you answer the External Power lost question with something like, Always Stay On, Always Turn Off or Ask me. Can't remember the exact wording as it's been to many years since I owned one
10-09-2012, 03:17 PM
#5510 | |
Back Home
Oddometer: 1,546
May take more than 24 hours to drain the battery. I know I've left mine in for a day or two and it still had power; meaning it turned on. But for sure after a week or two its dead. Come to think of it, I've not tried this with the lastest firmware - maybe something has been fixed I'll go stick it in the mount and see what happens.Oh, I thought Emmbeedee was going to try the disconnected mount experiment for us |
10-09-2012, 03:31 PM
#5511 | |
Oddometer: 3,173
The Montana does completely shut down when power is removed and the unit is "told" to power off. Just like if you remove the battery. There is no circuit board battery that keeps the "unit" alive when the external battery is removed. Cheers,
Cheers, Dan |
10-09-2012, 04:06 PM
#5512 | |
Procrastinators
Oddometer: 5,789
Don't say I never do anything for you.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
10-09-2012, 04:08 PM
#5513 | |
Back Home
Oddometer: 1,546
Anyway, it's in the mount now with 97% on the battery meter - we'll see what it looks like after a few days. BTW, the 97% is from sitting on my desk being lightly used over the past 3 weeks. |
10-09-2012, 04:19 PM
#5514 | |
Back Home
Oddometer: 1,546
I'm going to have to send you another ear plug so you can have a matching set
10-09-2012, 04:23 PM
#5515 | |
OX Ambassador
Oddometer: 411
Thanks for taking one for the team!
10-09-2012, 04:26 PM
#5516 |
STILL Jim Williams
Oddometer: 5,953
I'll do the same. I know that I won't be on my bike the next couple days. Actually, I'll charge it overnight via USB. Tomorrow, I'll put it in the mount, turn the bike on, let it charge for a second then turn the bike off and let it sit for 24-48hrs.
10-09-2012, 04:33 PM
#5517 |
Procrastinators
Oddometer: 5,789
I'm retired with nowhere to go. Not until Friday, anyway.
#5518 | |
Back Home
Oddometer: 1,546
![]() With levain joining the scientific testing team we're going to have some great results
10-09-2012, 04:38 PM
#5519 |
Procrastinators
Oddometer: 5,789
I've only got one Montana but I could always use my wife's 650, my 62S or the Nuvi 780 in the car if I needed something to navigate by. Can't use my iPhone 'cause it's got Apple Maps and they don't know their you know what from a hole in the ground.
10-09-2012, 05:24 PM
#5520 |
Oddometer: 626
I'll try to kill another myth while we are watching batteries die!! My rugged mount is wired directly to the battery on my F650GS (Girls bike for those that care even though a am well hung). The bike hasn't been run for two weeks and I won't crank it again before three weeks pass. I put the Montana in the mount and it booted up giving me the option to turn it off. I did. Anyone wan't to bet on if the bike will start in three weeks????? My money says it will not kill the bikes battery!! GH
