Thread Tools Search this Thread Rating: Thread Rating: 376 votes, 4.93 average. Display Modes
Old 10-10-2012, 09:00 AM   #5521
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,690
Originally Posted by DRTBYK View Post
The Automobile Mount that Emmbeedee shows above has an inductive voltage divider in the power plug adapter. It is only capable of passing a small amount of current: I don't have one but it is usually around 400ma - it should say on the plug.
I see nothing on the plug, and a label on the cable which only specifies the fuse rating.
Old 10-10-2012, 09:13 AM   #5522
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,356
FWIW, I last rode my 1150GS on September 30 after a 2 day ride up in the San Juan Mountains (I've been riding the DR650 instead since then). I left the Montana in the Rugged Mount when I parked it in my shop at that time because I didn't need it for local rides. I have switched 12v power to the Montana and told it to shut down when prompted when I turned off the bike. It has been getting down into the upper 20s to low 30s at night and the shop is not heated. I just went out and got the Montana off the bike and the internal battery is still at 98%. There is NO way the Rugged Mount drains the internal battery when the Rugged Mount power is off based on this 10 day test.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 10-10-2012, 10:46 AM   #5523
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,107
OK, I have now v4.60 installed.
I also now have a number of old tracks in my 'Track Manager' that i can not 'delete' nor 'show on map' nor work with in any of the other 'Track Manager' functions.
Am I able to delete these tracks by using my laptop with the Montana connected?
T.
The Rave Generator......
Timpo is offline   Reply With Quote
Old 10-10-2012, 11:02 AM   #5524
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,671
T.
That method has worked well for me.
Are you seeing the old tracks in your Archived Tracks? That might explain why they won't show on map.
Old 10-10-2012, 11:03 AM   #5525
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
T.
Others had reported Bug 32 was resolved with firmware 4.60.
Are you certain you are running 4.60?
Can you try another profile? Do other tracks still hide/show/etc correctly in Track manager?
EDIT: Firmware 4.60 still exhibiting Track issues (Bug 36) - Will have to wait for 4.70 for new fixes and new bugs :)
atlas cached screwed with this post 10-10-2012 at 12:40 PM
atlas cached is offline   Reply With Quote
Old 10-10-2012, 11:25 AM   #5526
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 705
I have the same issue. I had two tracks showing even after I hide them. I deleted those two, but I can't delete the remaining three tracks from that same trip. These are from the track manager. Not archived.
IBA #33260
cablebandit is offline   Reply With Quote
Old 10-10-2012, 11:33 AM   #5527
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,107
Yes, Software Version 4.60 installed.
There are no tracks in the 'Archive' or 'Current' files.
I have also just deleted all 'Waypoints' from the unit just in case they were keeping the Tracks from not being deleted.
What else will stop Tracks being deleted?
And, having the deleting process available that is in the 'Waypoint Manager' for us in the 'Track Manager' would be very usefull......
T.
Old 10-10-2012, 11:34 AM   #5528
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,107
Yes, this sounds familiar dude.
In the 'Track Manager' when trying to delete a track, the word 'Delete' is highlighted when touched, the 'Delete' bar is highlited in orange but goes no further into the deleting process. The bar has stayed orange in colour.
Also, no other function works in the 'Track Manager' on these remaining tracks.
T.
Old 10-10-2012, 12:25 PM   #5529
atlas cached
OX Ambassador
Oddometer: 688
T.
If you manually remove them from the Montana, reboot, and copy them back, does Track manager continue to exhibit the same unfavorable behavior?
Can you share one or two of the offending tracks?
Old 10-10-2012, 12:33 PM   #5530
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,690
T.
These tracks which you can't delete aren't part of an "Adventure" are they? I wasn't able to delete some tracks for this reason. Once I got rid of the "Adventure" I was able to delete the tracks.
You might also want to do a "Reset" to see if it frees those tracks for deletion.
Old 10-10-2012, 12:40 PM   #5531
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,107
I have just reloaded the tracks and waypoints, and the reloaded tracks can be deleted again.
The older tracks, which are no longer required can not be worked with using any function of 'Track Manager'....?
Old 10-10-2012, 12:55 PM   #5532
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,107
OK, I have just tried to send the tracks from device into my mapsource/laptop, and it says the device has no waypoint, routes or tracks in it. Yet, the Track Manager displays a list of old tracks, that I do not need anymore. Can I do something to clear this list? This is like the track manager is scarred by the old tracks, but they no longer exist, hence not being able to use track manager functions on then..... iykwim.
Old 10-10-2012, 01:05 PM   #5533
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,671
Well, if you can create new "dummy" tracks in basecamp that have the same names as the "bad" tracks on the Montana, maybe copying the dummy tracks to the Montana location will overwrite the bad tracks and then allow you to delete them.
Or, if you prefer not to use basecamp, just connect your Montana to a computer and open it up with file manager; locate the track files and give them a good wipe!
Old 10-10-2012, 01:18 PM   #5534
atlas cached
OX Ambassador
Oddometer: 688
You can NOT use MapSource with the Montana. It will not see your waypoints and tracks. You MUST use BaseCramp with the Montana :)
Old 10-10-2012, 01:47 PM   #5535
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,107
OK....
But I had loaded into Montana using Mapsource, but them was unable to work with the tracks and waypoints loaded.
Now, I have opened basecamp and deleted the tracks (scarrs) and waypoints, so far so good.
And now, I have used Mapsource to load my tracks to Montana, hey-presto, it's all good now.
A mystery to me though why earlier, pre-v4.60 tracks had left the scarring?
Thanks all.
T.
Times are GMT -7.   It's 09:07 PM.
