Thread Tools Search this Thread Rating: Thread Rating: 370 votes, 4.93 average. Display Modes
Old 10-17-2012, 12:47 PM   #5596
bighopper
Oddometer: 188
Thanks for the explanation, now you mention the recording level I do think I remember when i had the Track recording at a higher rate it was higher than the Trip!
Originally Posted by atlas cached View Post
This is a very commonly reported non issue.
The Trip Computer records track length at a rate of one waypoint per second.
If you have your Track Log set to record more often, your recorded track length will likely be longer than the Trip Computer Odometer reports.
Similarly, if you have it set to record less often, it will likely be shorter than the Trip Computer Odometer.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 10-18-2012, 05:43 AM   #5597
atreiou
XR 650R Rider
Oddometer: 61
hard enough ?
atreiou is offline   Reply With Quote
Old 10-18-2012, 06:27 AM   #5598
calltrex
calltrex's Avatar
Oddometer: 25
Purpose of that?
2012 KTM 350 EXC-F
2012 KTM 350 EXC-F
calltrex is offline   Reply With Quote
Old 10-18-2012, 06:35 AM   #5599
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,590
Originally Posted by calltrex View Post
Purpose of that?
2012 KTM 350 EXC-F
To make you have to use the sliders on your browser!
Old 10-18-2012, 06:56 AM   #5600
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 497
Getting to know my Montana a bit better. Liking how it leaves my routes alone. Can someone answer 2 Q's my searches have ended up empty on?
1. I always used Mapsource before, but am working with BaseCamp now. In MS, as you built a route, it would keep a running total of it's mileage over on the left side of the screen. I can't find that feature in BC. Is it there?
2. Somewhere in this thread I read that a route AND and track could be displayed at the same time, so that as you are riding, you could see if the route deviated from the track. How do I do this?
NCD is offline   Reply With Quote
Old 10-18-2012, 07:02 AM   #5601
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,663
I'll take a stab at this one.
Create a route in Basecamp, and convert it to a track.
Transfer both the route and the track to the Montana.
When using the Montana, select the track to "Show on Map" and select the track color of your choice.
Navigate using the route, with routing in a color different than that of the track.
The route should show on top of the track.
Old 10-18-2012, 08:04 AM   #5602
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 497
Thank you. I like having the Zumo-type stuff like arrival time, distance to next turn, etc - - but trust tracks better. To have the two together would be bliss!
Old 10-18-2012, 08:12 AM   #5603
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,352
If you double click on the new route name where it is shown in the list contents on the left side of the screen, a route detail window will come up showing the incremental and total distances among all the rest of the details about the route. That will be updated as you continue creating the route.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance screwed with this post 10-18-2012 at 08:21 AM
FatChance is offline   Reply With Quote
Old 10-18-2012, 08:16 AM   #5604
Countdown
Oddometer: 5,589
Originally Posted by bighopper View Post
Don't know if anyone else has noticed this, but the distance reported by the 'Trip Distance' & a 'Track' file seem to be approx. 6% different.
They are also both horizontal so will be different than odo if going up or sown steep hills.
Jerry Counts
Countdown is offline   Reply With Quote
Old 10-18-2012, 09:02 AM   #5605
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,758
Of course if you were using the Mac version of BaseCamp the Total Milage of the Route you are creating will be displayed on the Status Bar at the bottom of the window. It's updated as you develop the route.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is online now   Reply With Quote
Old 10-18-2012, 10:51 AM   #5606
DrtSqtr
DrtSqtr's Avatar
Oddometer: 146
discovered the source of my issues
Good day all,
So i have been having an issue with my Montana 600 not showing street, highway or interstate names or only showing a few at a time.... Ive went through all the settings, reset , changed detail, ect ect.... per all the suggestions of everyone here. I got off the phone with Garmin this morning and we did a master reset and i re installed CN2013 woohoo it worked... (for 15 feet). Ablout 45 min later i took my newly installed 600 and tried it out in the car on a trip into town... Crap back to no info.... so while i contemplated on selling this POS I stopped for a quick bite to eat and i thought lets try it not in the rugged mount. Took it out of car mount and turned it on....... perfect all the names appear as they should. I see street names highway names and interstate names, great at least now i know where i am.... I popped it into the rugged mount and BAM!!! names disappeared..... Came home did same experiment on my motorcycle rugged mount same thing.... works great in my hand, put it into the rugged mount and i loose all map info. I called back Garmin explained to them the issue and they said he'd research this issue and get back to me... SOOOO right when i was all fed up with this GSP i discovered its not that bad now to only figure out how to make it work in the mount. Just thought id share my woes.....
DrtSqtr is offline   Reply With Quote
Old 10-18-2012, 11:07 AM   #5607
DRTBYK
DRTBYK's Avatar
Oddometer: 5,758
Originally Posted by DrtSqtr View Post
Good day all,
While you are waiting for Garmin to get back to you, try going to Setup->Profiles->Options->Set Mount Profiles. Make sure you have the unit out of the mount and then set all of the Mounts to whatever you have set for "Not Mounted".
Cheers,
Cheers,
Dan
All Things GPS
Old 10-18-2012, 03:10 PM   #5608
DrtSqtr
DrtSqtr's Avatar
Oddometer: 146
Thank you.... I checked and all profile mount were set to No Change...
Cheers,
Old 10-18-2012, 07:24 PM   #5609
_cy_
Oddometer: 6,268
dumb question ... how does one input a GPS coordinate?
from where to: coordinates doesn't allow change
did a master reset... still cannot change coordinates.
Montana instruction manual is no help...
OK... what am I doing wrong?
Old 10-18-2012, 07:27 PM   #5610
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,657
Mark Waypoint/Edit and put in the coordinates you want.
Times are GMT -7.   It's 12:47 PM.
