10-18-2012, 07:27 PM
#5626 | |
Procrastinators
Oddometer: 5,804
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
10-18-2012, 07:42 PM
#5627 |
Oddometer: 2,534
already tried that... marked waypoint, then waypoint manager... will not allow editing of coordinates.
is there a separate edit button? where?
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
10-18-2012, 07:54 PM
#5628 | |
Procrastinators
Oddometer: 5,804
10-18-2012, 08:00 PM
#5629 | |
Oddometer: 2,534
example ... need 35 79... allows edit for first two digits, then will not allow edit for third digit or forth
10-18-2012, 08:07 PM
#5630 |
Procrastinators
Oddometer: 5,804
When you select Edit Waypoint, if you click anywhere in the address it brings up a menu at the top which allows you to go to any part of the address and change that.
10-18-2012, 08:18 PM
#5631 | |
Long Haul Adventurer
Oddometer: 3,181
Couple more questions... 1. You went to Where To?->Coordinates, and you cannot edit the coordinates shown in the window? If the answer to that question is "Yes" you should call Garmin Product Support. 2. Waypoint Manager: you saved a Waypoint then opened Waypoint Manager, selected a waypoint, pressed the Coordinate field and were unable to edit the coordinates? If the answer to that question is also "Yes", call Garmin Product Support. 3. Waypoint Manager: Select a waypoint. Press the Options button, select Move Waypoint. Are you able to move the waypoint by selecting a new position on the map? If the answer to that question is "No", call Garmin Product Support. Cheers,
Cheers, Dan DRTBYK screwed with this post 10-18-2012 at 08:24 PM |
10-18-2012, 08:23 PM
#5632 | |
Oddometer: 3,181
Cheers,
Cheers, Dan |
10-18-2012, 08:34 PM
#5633 | |
Oddometer: 2,534
just downloaded the latest version 4.60 and a master reset trying to resolve this issue. Looks like I'll be contacting Garmin tomorrow. this Montana has been a major pain in the ass from day one.
10-19-2012, 12:36 AM
#5634 | |
OX Ambassador
Oddometer: 422
My first thought is Garmin software engineers wanted to simplify the map while navigating to prevent driver/rider distraction trying to read all map detail. Will contact Garmin for more information. |
10-19-2012, 02:31 AM
#5635 |
XR 650R Rider
Oddometer: 45
10-19-2012, 08:19 AM
#5636 | |
Oddometer: 3,181
I'm not having this same condition. I even set my Mount Profiles to switch from mount to mount (although I don't have an Automotive Mount) and Powered to non-Powered. It all worked just fine with no map changes. Well, I did a little more investigation and the culprit seems to be the Recreation Profile - at least I know that one causes the issue - and maybe it's by design. I haven't tried the other profiles but I have based my 'custom Profiles" off of the Automotive Profile and it does not exhibit this condition. Cheers,
Cheers, Dan DRTBYK screwed with this post 10-19-2012 at 05:27 PM |
10-19-2012, 10:55 PM
#5637 | |
Oddometer: 2,011
I used this technique while navigating a 1,000 mile ride yesterday within WA state. It worked like a charm. I colored the track WHITE and it overlayed the route, the White track seemed to be the dominate color compared to the purple route.
Tim in Burien, WA '05 R1200GS (Sleeping in Germany) '03 F650GS '03 Wing '01 ST1100 |
10-19-2012, 10:57 PM
#5638 | |
Oddometer: 75
Another thing to look at is i noticed that when im moving the names disapear. i was thinking perhaps the gps can not update that fast.. I noticed that on the way to work tonight i took out the gps and sat it on the dash and while i was moving no names. I stopped for gas and as soon i got back in to go i noticed all my names were back untill i started moving then they went away again.
10-20-2012, 09:43 AM
#5639 | |
Oddometer: 3,181
Cheers,
Cheers, Dan |
10-20-2012, 04:12 PM
#5640 |
Deputy Cultural Attaché
Crazy Montana.
All working great today, except a strange shutdown when attempting to zoom out in map view. Oh, it worked the other 50 or so times I zoomed out, and all of the times I zoomed in. But not all!
Successfully surviving motorcycling since 1976. |
