Thread Tools Search this Thread Rating: Thread Rating: 433 votes, 4.94 average. Display Modes
Old 11-07-2012, 01:55 PM   #5776
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,846
Originally Posted by mass-klr View Post
Hi,
If I can get a new Montana 650T for $300, should I get it? And if I am doing 60/40 pavement/dirt should I get the 660 or 650T?
Thanks...
No, you shouldn't get it.
Where, pray tell?
New 650Ts do not go for $300 unless they "just fell off a truck".
Old 11-07-2012, 04:51 PM   #5777
mass-klr
mass-klr's Avatar
Oddometer: 179
Originally Posted by Emmbeedee View Post
Where, pray tell?
Garmin employee sale...
mass-klr is offline   Reply With Quote
Old 11-07-2012, 04:57 PM   #5778
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,846
We're all practically employees here!
Old 11-08-2012, 04:10 AM   #5779
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,846
There's an update out today for Lifetime Map Updaters.
2013.30
Old 11-08-2012, 05:30 AM   #5780
guavadude
de-composer
guavadude's Avatar
Oddometer: 891
2013.30
I just ordered the CN 2013 DVD and was wondering if I should have spent the extra money on the lifetime maps.
I figured the maps themselves wouldn't change that much just the POIs and I can use my phone for that. I imagine in a few years I'll want the latest greatest gps and the maps are locked to one unit.
guavadude is offline   Reply With Quote
Old 11-08-2012, 06:52 AM   #5781
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
If you use CNNA mostly for navigation in cities and suburbs, it's probably worth it, 'cause those roads are constantly changing. You can get a lifetime card on Amazon for about $55, about the same as a single update.
If you use it for navigation mostly in the country and get updated POI's on your phone, it may not be worth the bother.
Rocky TFS is offline   Reply With Quote
Old 11-08-2012, 07:45 AM   #5782
guavadude
de-composer
guavadude's Avatar
Oddometer: 891
Good to know about Amazon update, thanks!
Old 11-10-2012, 05:12 AM   #5783
mass-klr
mass-klr's Avatar
Oddometer: 179
Mounting with Amps Rugged Mount
Hi,
Ordered my 650T and Amps rugged mount. (Can't wait )
When mounting the Amps mount for the Montana what do you usually do with the audio cable? Do you just coil it up somewhere in the front near the mount?
And what is the prefered method of hooking the mount up to the battery, switched or not? Does it make sense to connect it to a SAE lead close to the Mount?
Thanks for the advice...
Old 11-10-2012, 06:23 AM   #5784
Bill Murray
Bill Murray's Avatar
Oddometer: 101
Hi,
Congratulations!
I ran an audio extension cable from the steering head, under the tank, to the base of the seat. This allows me to plug in a set of ear buds, or a coiled audio cable to my Scala Rider G4. My bike has a CANBus accessory connector in the steering head area. I have my Montana 650 connected to that power source (it is a switched source that powers down about 45 seconds after the ignition is shut off).
Bill Murray
2009 BMW R1200GS Adventure
Me on Google+
Bill Murray is offline   Reply With Quote
Old 11-10-2012, 06:35 AM   #5785
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,846
Hi,
Sounds like the exact setup i have on the 4 rugged mounts I have here: Cable coiled with tie-wraps holding it to the crossbar, and powered by an SAE cable at the steering head.
Old 11-10-2012, 06:44 AM   #5786
mass-klr
mass-klr's Avatar
Oddometer: 179
So you are not cutting the power cord of the mount shorter? Left it long and coil with audio?
Old 11-10-2012, 06:47 AM   #5787
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,846
No, I cut the power cable a few inches from the junction so most of the coiled part is just the audio cable.
Old 11-10-2012, 08:00 AM   #5788
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Hi,
I left everything long, coiled and tied off somewhere out of the way so I could still access the audio plug for earbuds or for someday when I moved it to another bike. I don't use the audio much for my kind of riding.
I prefer a direct wire to the battery so that the Montana doesn't keep powering off during short stops, with the attendant waiting for it to re-boot. When home for the day, I just unmount it and let in hang in the mount by the lanyard. (You DO have a lanyard in mind, don't you?) However, my bike lives in my garage, so theft is not an issue.
Switched or not, you still have to remove it when theft is a concern. There are numerous posts in this thread about the pros and cons of each....search for Rugged Mount.
Old 11-10-2012, 08:44 AM   #5789
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,690
Thanks for the heads-up. I got a lifetime card from Amazon for $54.
It worked flawlessly.
Best price I've seen on the lifetime maps option.
Old 11-10-2012, 09:48 AM   #5790
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Montana Mount & Power Cable
I prefer to have as little cable as possible on my dash or bars so I shorten everything where possible. Here's the Montana install on my KTM 990 ADV.
The mount is home brew that uses a bicycle axle skewer for tilt. It is semi-easy to remove. The cradle tilt plate is slotted on one side only so the skewer nut has to be fully removed to get the cradle off the base bracket. The cradle removal is a 5 minute exercise and prevents the 10 second ripoff. This lets me leave the cradle on almost all of the time without having to worry about it "growing legs".
I shortened the Montana harness between the cradle and the "Y" and again at the power cable. The plug is one of our Baryl plugs. The audio cable was left full length. I curl it up between the speedo and GPS cradle.
The power cable plugs into a Baryl panel-mount socket that is connected to switched power rather than direct to the battery. The Montana gives the option to "Turn Off" or "Stay On" when the bike is switched off so it doesn't have to be restarted after a fuel stop.
Shov3BR is offline   Reply With Quote
Times are GMT -7.   It's 12:17 PM.
