Thread Tools Search this Thread Rating: Thread Rating: 297 votes, 4.91 average. Display Modes
Old 11-10-2012, 12:17 PM   #5791
mass-klr
mass-klr's Avatar
Oddometer: 152
Thanks for all the advice guys...
mass-klr is offline   Reply With Quote
Old 11-10-2012, 02:30 PM   #5792
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,188
Comments on a 36hr. 600 mile RT I just completed.
Prior to leaving, I uploaded a few different routes. One I stole off the internet somewhere cos it looked so damn good. I don't know if my issues were user error or Montana quirkiness. Frankly, none of what I describe ever happened with my zumo, so I'm guessing Montana quirky.
The routes I made, that started as tracks in BC, worked fine. No issues. They were also very short.
The route I stole off the internet did not. The route was completely different. I'm assuming due to Montana doing its own thing-which is ok. However, the bigger issue was that it would only load sometimes. I'd tell it load, and it wouldn't or it might. Then, it would route me back to the beginning. Or, sometimes to the end. On the rare occasion it actually routed anything, and it was acceptable, I didn't touch the gps for fear of it losing me and not being able to route again. It was very frustrating. I'm happy to accept user error and be educated here. It seems weird that I'd find the route under routing, touch it, and nothing though.. well, sometimes nothing! Sometimes part. Sometimes all. Different everytime!
Oh, and occasionally I'd look down and Montana would be off taking a nap maybe? It would just be off. Hit the power button and it would fire up like nothing happened.
Another annoyance with my particular unit is the search. Often times the arrow (enter button) won't work. I need to touch it many times and it might. Or might not. I tried to find an address on Main st. in Concord, NH (state capital) and it couldn't fine main st.
When it works, its great. Mostly, though I miss my Zumo
Click Here!
2012 Triumph Tiger 800 XC
2008 Yamaha WR250R
1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-10-2012, 05:44 PM   #5793
mbabc
Curmudgeon trainee
mbabc's Avatar
Oddometer: 1,867
My SAE connector...
Followed Emmbeedee's plan...
I keep the coiled extra in my tank bag on both the Tenere and WR. I cut the audio and heat shrinked the nubs.
"I have never seen a Kentuckian without a gun and a pack of cards and a bottle of whiskey." - Gen. Andrew Jackson
'08 WR250R - '12 Super Tenere - '64 CT-Frankentrail
Little Blue goes looking for Orange
I don't know what time it is, I've switched to kilometers
mbabc is offline   Reply With Quote
Old 11-10-2012, 05:48 PM   #5794
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
There are so many variables in Routing that I'm not even going to touch that issue but the unit powering off might be caused by battery vibration. Do you have the earplug on the battery to stop it bouncing around?
And regarding the address on Main st in Concord, my gps finds that street in City Navigator.
Emmbeedee is online now   Reply With Quote
Old 11-10-2012, 06:13 PM   #5795
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,188
I'll try the earplug. The main st. issue was one of the times enter didn't work
Click Here!
2008 Yamaha WR250R
1971 Lambretta DL
Old 11-10-2012, 06:27 PM   #5796
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
In the Search menu it's the "Check" in the bottom right of the screen you're calling Enter"? Always works for me. Were you wearing gloves?
Also, when searching, the less information you put into the search, the more likely you are to be successful. As long as you put in enough letters in the search to make your result easily findable, it usually works.
So if I was looking for "Woodroffe" street, I'd put in "Woodr" then hit the check and let it bring up all occurrences. I would not put the full word in, and I wouldn't put "st" or "Street" or anything like that.
Let the gps find the first part, then choose from the results to find the right one.
Often even leaving the city name out is helpful.
Old 11-10-2012, 06:53 PM   #5797
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,188
Thanks for the help. Yeah, the check is what I'm referring to.
That's how I do it. Same as I always did with my zumo. I just tried doing the same thing from the comfort of my couch, and still had some problems. Eventually, I was able to find the address, but it took too many tries for my comfort. Seems like something isn't right. When it finally did find the correct address, it took a long time to find it. Finally, the address popped up. Sorry to seem so high maintenance, but I appreciate the help.
Click Here!
2008 Yamaha WR250R
1971 Lambretta DL
Old 11-10-2012, 07:17 PM   #5798
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
Which maps do you have on the unit? If you have multiple maps, you should not have them all enabled at once. When you have the City Navigator enabled, you should also have the Basemap enabled - this makes searches faster according to many experts.
I created multiple map based profiles so anytime I want to check a particular map, I go to it via its shortcut and that way all the right settings are switched accordingly.
One thing to note - if you do a map update, then that updated map becomes enabled on all profiles. So getting the latest City Navigator will make that map enabled, and dominant in all profiles.
City Navigator is the highest map in the draw order - it always takes precedence over all other maps, hiding the other map detail in the process.
Annoying, but easy to deal with as long as you're aware of it.
Old 11-10-2012, 07:19 PM   #5799
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
Also, when you did the search "on your couch", was the unit in Demo mode or still searching for satellites indoors? That can cause slowdowns. Using it indoors, you should always go to Setup/System/Demo first.
Old 11-10-2012, 07:45 PM   #5800
Jon_PDX
Oddometer: 1,114
Good point on the maps. It is a hassle to have to make the changes for each profile though. I don't suppose there is a global setting that will enable/disable maps for all profiles is there? I looked but could not find anything like that.
Also, do we really need all default the birds eye stuff that came with the unit enabled?
And how about the USGS Quads? What's it for?
If that stuff (birds eye and quads) is not needed, can we safely remove it from the Montana (after backing it up) instead of having to disable it in all the profiles?
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 11-10-2012, 08:19 PM   #5801
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
Jon...
I removed all the Birdseye and USGS stuff. Haven't missed it at all.
And you're right: there are very few 'Global' settings on the Montana, settings that persist through the different profiles.
Old 11-11-2012, 07:52 AM   #5802
Rocky TFS
Rocky TFS's Avatar
Oddometer: 557
Jon...
Nope, each profile has to be individually tailored for what maps enabled. Updating or adding a map will turn them all back on.....now THAT"S the really irritating part!
I deleted the Birdseye and quads the first week I had the unit....didn't even back them up.
Now, I use JaVaWa to back up all the maps, because some, like CNNA, are only partial loads, I'll never use the Eastern or Canadian sections (searches are faster too) and the backup means I won't have to go through Mapinstall and click on what I want for each map all over again. If my micro card dies, I'll just get a new one and dump the backups onto it, complete with unlock codes.
Rocky TFS is offline   Reply With Quote
Old 11-11-2012, 08:08 AM   #5803
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,528
I found that updating a map only enables that map in each profile, not all maps in each profile. I went through that just this week - the only map I needed to enable/disable depending on the profile was CNNA.
Old 11-11-2012, 10:27 AM   #5804
Rocky TFS
Rocky TFS's Avatar
Oddometer: 557
Hmmmn....maybe it's only when adding a state 24K map I get from GPSFileDepot. I sure thought I had seen it do this, turning on all the other 24K maps in each profile.
Old 11-11-2012, 09:36 PM   #5805
Hikertrash
Oddometer: 2,768
Battery Issues
Hey guys, sorry if this has been discussed before. I searched this thread for battery issues, but they seem to be vibration related. I just purchased a new Montana 600 from an online vendor and after charging the battery overnight,it still would not power on. It works just fine in the AMPS rugged mount and with AA batteries. The vendor shipped me a replacement battery, but that one doesn't work either. I checked the contacts and it looks like they are contacting the battery. Is there a simple fix to this or does it sound like I have a bad Montana?
Hikertrash is offline   Reply With Quote
Times are GMT -7.   It's 09:34 AM.
