11-19-2012, 10:00 AM
#5896 | |
Oddometer: 1,437
I had found the Montana FAQ. Good info. I have lots to learn. Is the Amp Ball different from the standard Ram Ball mount? I've already got Ram Mounts on both bikes. I was hoping to just get two of the Rugged Mounts and would be good to go.. Looks like I'll order the screen cover/film also. Thx
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
11-19-2012, 10:16 AM
#5897 |
de-composer
Oddometer: 322
the AMP mount is a four screw mount so you'll need one of those with a 1" ball to use with your existing RAM mounts.
The rugged mount comes with 3 Garmin screen protectors. Good time for me to ask, what is everyone's preference on screen protectors? I know Drytbike Dan likes the Zagg. I grabbed some of those but am wondering if people like the Garmin protectors too. Seems like the Zagg are not anti-glare or smudge proof, is that a big deal? I have lots to learn too but it's pretty much all in this thread somewhere! |
11-19-2012, 10:26 AM
#5898 | |
Procrastinators
Oddometer: 5,817
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
11-19-2012, 10:51 AM
#5899 |
Deputy Cultural Attaché
+1, just the protector that comes with the mount. Works well enough for my purposes. My screen always ends up getting dusty anyway. I just don't want the dust to scratch the actual screen when I'm using the GPS.
Successfully surviving motorcycling since 1976. |
11-19-2012, 11:04 AM
#5900 | ||
Oddometer: 125
I called Garmin Support (it was quick to got to talk 2 mins) after I was lead through the master reset & again verified that the MAX Temp was the same (45C) he put me on hold & then came back to say I had to remove the battery every-time I wanted the Min/Max temps reset! I told him that I thought he was wrong & that the Tempe was a $30 piece of junk if that was the case. So I'll do some more testing after removing the battery & see what happens. Or am I missing something it the operation of the Tempe?
I Just Like To Ride ![]() '03 BMW R1150GSA '06 BMW K1200LT |
11-19-2012, 11:08 AM
#5901 | |
Procrastinators
Oddometer: 5,817
Just for the record, it only took me 6 minutes to speak to a customer service rep. Unfortunately his advice was to remove the battery for 30 seconds, to reset the Max and Min temperatures. I created a ticket on this and hope to get a fixed one soon. The CS guy thought it was going to be a software fix, but no idea if it'll be something we at home can apply. I wonder if it'll be something we download to the Montana to fix it? Possible, I suppose.
11-19-2012, 11:10 AM
#5902 | |
Procrastinators
Oddometer: 5,817
11-19-2012, 11:18 AM
#5903 | |
Oddometer: 125
wonder if he was having a hard time understanding.Did you get the same answer? Opps , I see you responded above...I didn't get to create a ticket. Maybe I'll call GPSCity & see what they have to say.
11-19-2012, 11:26 AM
#5904 |
Procrastinators
Oddometer: 5,817
I had to suggest the ticket idea. And then I had to suggest he take my name and email address. He obviously wasn't taking it very seriously.
11-19-2012, 03:27 PM
#5905 |
Oddometer: 627
11-19-2012, 04:12 PM
#5906 |
Oddometer: 200
11-20-2012, 05:04 AM
#5907 |
Oddometer: 388
Well I am not a happy person today
I have been using my third Montana for only 4 days and had to do a master reset. It just decided to lose all my waypoints, stoopid damn thing Cheers TravellingStrom Sent by arcane magic using Tapatalk
www.travellingstrom.com |
11-20-2012, 05:53 AM
#5908 | |
Procrastinators
Oddometer: 5,817
Have you tried running JaVaWa Device Manager on your gps to see if it finds errors in the maps or gpx files on it? And in my experience, a master reset does not lose things. IMHO, there's something else going on there.
11-20-2012, 06:24 AM
#5909 |
Oddometer: 72
my apologies if this has been answered already, but I will have internet availability only for a few hours and thus it is a little bit hard to review back most of this big thread.
Currently I'm in Popoyan, Colombia, and after 2.5 months of riding in South America my Montana starts doing its "things". It is as if the screen is constantly being pressed in the upper and lower left corners (portrait mode), so the unit is essentially unusable. For example, in Map, where I have the data fields in the upper section, the left datafield is pressed by its own, then switches to the "change datafield" screen etc ... and it just won't stop... At some moment, when it stopped doing it, I was fast enoug to lock the datafields. But then, the lower left corner started acting in the same way ... Is this the known screen issue? Is there a work around it, without having to replace the unit (which is something that probably won't happen here :( ) Would a master reset solve this? or a screen calibration? |
11-20-2012, 06:30 AM
#5910 |
If you are using a screen protector, try removing it.
