Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 464 votes, 4.94 average. Display Modes
Old 11-21-2012, 08:14 AM   #5911
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by TravellingStrom View Post
I had to do the master reset because it lost things, it was done after the fact
Maybe it is me, but I am using different maps all the time
Montana 1 had Europe CN 2013.2 or 3
Montana 2 had the same then it had OSM Russia, kazak and other Central Asia maps one at a time.
Montana 3 has a combined Thai/Laos/Cambodia/Malaysisa
When I have these SD cards in I disable all the other maps that are in there
The SD card is taped in, tape around battery base and an ear plug inside battery case
It is on a rugged mount
What more am I supposed to do, I cannot think what I am doing wrong
If you can give me any pointers I would appreciate it
I will try that Jawaw thing in a while and see what it says
Cheers
TravellingStrom
Sent by arcane magic
using Tapatalk
TS - it just occurred to me, reading your post, that you are using multiple uSD cards based on where you are and what information you need available on your Montana GPSr.
When you swap uSD cards, Power the Montana on/off between removing one uSD card and inserting another. This will ensure complete re-indexing of all data.
atlas cached is offline   Reply With Quote
Old 11-21-2012, 08:21 AM   #5912
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,808
Maybe I'm misunderstanding something here but to remove the microSD card you need to remove the battery. Removing the battery would power off the Montana. Are you suggesting that after the new microSD card and battery are installed, do a power off/on after the initial power on or do you mean a master reset?
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 11-21-2012, 08:25 AM   #5913
atlas cached
OX Ambassador
Oddometer: 688
  1. Power Montana Off
  2. Remove uSD card
  3. Power Montana On
  4. Wait for boot process to complete
  5. Power Montana Off
  6. Install new uSD card
  7. Power Montana On
Old 11-21-2012, 08:53 AM   #5914
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,808
  2. Remove uSD card
  3. Power Montana On
  7. Power Montana On
ahhhhh. I can see that being needed for OSM maps that safe the same map name and ID
Moto-Treks
Old 11-21-2012, 09:07 AM   #5915
number9
number9's Avatar
Oddometer: 313
Essentially, no.
See all the differences between Garmin Montana models here.
The 650t does include nearly double the RAM, much of which is taken up by the Garmin 100K topo maps. If you decide you do not like them, they can safely be copied to your computer for archival purposes and all that extra space will be available. 32GB uSD cards are pretty inexpensive storage options as also!
Really? How much RAM does each unit have? 600-650-650T?
2000 Yamaha YZ250
2009 Yamaha YZ250
2013 Kawasaki Ninja 1000
number9 is offline   Reply With Quote
Old 11-21-2012, 09:09 AM   #5916
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,713
Info readily available here:
http://garminmontanagpsr.wikispaces.com/Hardware
Old 11-21-2012, 09:09 AM   #5917
rockinrog
rockinrog's Avatar
Oddometer: 2,953
The Montana 600 and the Montana 650 provide 3.0 GB memory for user data and additional maps. The Montana 650t provides 7.35 GB memory, of which the pre-installed topographic map of Europe occupies about 4 GB leaving about 3.5 GB for user data and additional maps.
rockinrog is offline   Reply With Quote
Old 11-21-2012, 09:39 AM   #5918
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,951
If duplicate map names are an issue, you can use JaVaWa to rename them:
And no, I do not have any vested interest in JaVaWa; I just like it a lot. It's a very useful tool.
Old 11-21-2012, 09:51 AM   #5919
number9
number9's Avatar
Oddometer: 313
Ah....ok, that was the part I didn't understand. That's interesting......but I guess at around $80 more in price, going this route and moving the topo off to gain the extra storage on board isn't worth the cost when you can get 16GB microSD cards for around $15 or so. Still, interesting option.
2000 Yamaha YZ250
2009 Yamaha YZ250
Old 11-21-2012, 11:00 AM   #5920
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,252
Posting this question here because more folks are probably subscribed. Hope that's ok.
Is there any reason that one could not buy the Garmin 24k Topo card and make copies of its contents onto a larger capacity card that could hold multiple map sets? What I am thinking is that it would be nice to have a card with a couple of map sets on it, say 24k topo for when I want that and some other set, like a streetmap set that supports routing or some custom thing. It would be nice to have them both on one card, so that I would not be fumbling around swapping cards.
If that would work, is there a particular folder structure that a GPS unit (like the Montana) would expect or require?
I know people say buy the disc instead, but I have a line on a card for a really good price so that's why I am considering one.
Old 11-21-2012, 11:07 AM   #5921
atlas cached
OX Ambassador
Oddometer: 688
If you buy the Pre-Loaded Garmin uSD Map Cards, the Map file is LOCKED to that unique uSD card, and will only function on THAT uSD card. This allows you to move the map from one GPSr to another. Also, the uSD card version of 24K Topo uses larger map segments, allowing more data to be loaded onto one GPSr, but be aware the uSD version also contains less detailed information than the DVD version.
Old 11-21-2012, 11:36 AM   #5922
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,252
Old 11-21-2012, 02:31 PM   #5923
mass-klr
mass-klr's Avatar
Oddometer: 186
Just received my 650T a few minutes ago. Let the playing/learning begin!!!
Leon
mass-klr is offline   Reply With Quote
Old 11-21-2012, 02:58 PM   #5924
atlas cached
OX Ambassador
Oddometer: 688
Leon
Awesome!
This is a great weekend to learn all about it!
Old 11-21-2012, 03:00 PM   #5925
roadspirit
Oddometer: 144
Originally Posted by Emmbeedee View Post
This sounds like the screen protector issue I had. It ages, hardens and possibly shrinks, and starts making screen selections because it's effectively touching the screen. If you have a Garmin screen protector on it, remove it to see if the issue continues. Putting on a fresh protector stopped mine from auto-selecting menu items.
I removed the screen protector. Today, riding from Popoyan to Salento the unit performed ok, so I'm hopping that you were right and there is no other kind of problem. Thank you !!!
roadspirit is offline   Reply With Quote
Times are GMT -7.   It's 10:40 PM.
