Thread Tools Search this Thread Rating: Thread Rating: 371 votes, 4.93 average. Display Modes
Old 11-27-2012, 05:47 PM   #6016
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by stevepsd View Post
Been playing with my Montana 600. Loaded the Garmin 2008 100K topo's onto it's built storage and then put NT North America 2013.20 onto a uSD card. Everything works great.
However, I thought with all the customization available on this unit that I could have the 100K Topo's active (and the NT 2013.20 disabled) when in 'Recreation' mode and the reverse when in 'Automotive' mode but it appears that the maps that are 'active' or 'disabled' are not tied to any one mode. Or am I missing something?
-steve
What is the current firmware level of your Montana?
Older firmware had issues with maps being auto-enabled.
Yes, each map can be set to enabled or disabled in each profile, independently.
atlas cached is offline   Reply With Quote
Old 11-27-2012, 06:13 PM   #6017
stevepsd
Oddometer: 226
I am currently running 4.60 (it shipped with 3.80).
What I want to end up with is the Topo maps automatically enabled when in Recreation mode (and NT 2013.20 automatically disabled).
When in Automotive mode I want the Topo maps to be automatically disabled and the NT maps automatically enabled.
'12 XT1200Z SuperTénéré, '09 KTM 530 EXC, '08 Triumph Tiger 1050, '87 XR600R Street Legal
Gone but not forgotten: '92 Yamaha TDM850, '82 XJ550 Seca, '80 XS1100,'85 GL1200A, '84 V65 Sabre, '80 CB750F SuperSport, '77 RD400, '72 TS250, '69 CB450K, '68 CL70
stevepsd is offline   Reply With Quote
Old 11-27-2012, 06:44 PM   #6018
atlas cached
OX Ambassador
Oddometer: 688
This is exactly how I use my Montana.
I have only Topo and Trails enabled in my Geocaching profile, and City Navigator and Trails enabled in my Automotive profile.
You should be able to make those selections in one profile, change profiles, set the maps as you want them for that profile, and then be able to switch between the profiles and see only the selected maps in the map application.
Which maps (name and version) are you using, and where are they loaded?
Old 11-27-2012, 06:56 PM   #6019
stevepsd
Oddometer: 226
From my OP....
Old 11-27-2012, 07:02 PM   #6020
atlas cached
OX Ambassador
Oddometer: 688
From my OP....
Oops!
I assume then they are both DVD version?
And you are using MapInstall via BaseCamp to send those maps to your Montana?
When you enable one map for one profile, and the other for another profile, what results are you seeing in each profile? If you check again in each profile for the status of the maps you have set to enabled or disabled, do they still show as you set them, or are they changing from enabled to disabled and vice versa?
Is the SAME map always showing in both profiles, regardless of how you set them?
Have you tried any other profiles to see how they behave?
Old 11-27-2012, 07:09 PM   #6021
stevepsd
Oddometer: 226
Oops!
Installed via Basecamp.
I select Recreation profile, then go into maps and set the Topo maps to enabled and disable NT 2013.20
I then go into Automotive profile, then intp maps and set Topo to disabled, and NT 2013.20 to enabled.
I then switch back to Recreation profile and the maps show up as they were for Automotive profile (i.e. the way the maps show are how they were last set - regardless of what profile I have selected).
Old 11-27-2012, 07:15 PM   #6022
atlas cached
OX Ambassador
Oddometer: 688
Does zooming in or out on the map one click change anything, even after waiting a few seconds?
Old 11-27-2012, 07:26 PM   #6023
stevepsd
Oddometer: 226
Nothing changes.
Is there a 'master reset' on the Montana (I could not find a reference to one on the big Garmin Montana wiki)?
Old 11-27-2012, 07:33 PM   #6024
atlas cached
OX Ambassador
Oddometer: 688
Nothing changes.
Two more questions:
1. Do you have any other maps installed on the GPSr or uSD card? (I used to have an issue with some maps preventing others from enabling/disabling properly)
2. To further clarify, you are seeing the CN NA map in both profiles, regardless of settings?
I would not Master Reset just yet....
Master Reset information is available from multiple locations within the Montana wiki:
Tenth question in the FAQ and Function \ Diagnostic are a couple of examples.
Old 11-27-2012, 08:16 PM   #6025
mbabc
Curmudgeon trainee
mbabc's Avatar
Oddometer: 1,929
Originally Posted by MizzouRider View Post
Mine's still in the box. Haven't had time to look at it yet. Recd the rugged mounts and Ram Amp Ball. Ready to get started.
I still need to read much more. Not sure what software, maps, cards, etc, I need to get started.
You'll love it Jeff! Best mc unit out there, especially if you're coming from an Oregon like I did.
I sent you a PM.
"I have never seen a Kentuckian without a gun and a pack of cards and a bottle of whiskey." - Gen. Andrew Jackson
'08 WR250R - '12 Super Tenere - '64 CT-Frankentrail
Little Blue goes looking for Orange
I don't know what time it is, I've switched to kilometers
mbabc is offline   Reply With Quote
Old 11-28-2012, 06:58 AM   #6026
johnpitts01
johnpitts01's Avatar
Oddometer: 1,017
Too Many Options.... I am confused
Bought the Montana 650
Bought 2 uSD cards
Bought the Topo and CN2013 on DVD with lifetime updates.
Havent installed anything just yet.
I thought I had it figured out:
1) Put the uSD Card in the Montana
2) Connect Montana to laptop
3) Create Garmin directory in uSD Card
4) Insert DVD to laptop.
5) Install the maps to the uSD card.
6) Repeat for second uSD card.
Now i read this:
"I assume you are loading the maps to the Montana from Basecamp."
WTF!?!?!
Is there one best way to load the maps and have them available on multiple uSD cards? Or will any of these methods work?
I thought it was necessary to have a GPS device connected to the computer when you install the maps as they are locked to a single GPS device.
Am I just completely dense, or is anyone else out there also confused?
johnpitts01 is offline   Reply With Quote
Old 11-28-2012, 07:01 AM   #6027
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,666
Originally Posted by johnpitts01 View Post
Now i read this:
WTF!?!?!
BaseCamp does not load maps but it has a connection to MapInstall so MI can be called from BC. Saying BC installed the maps is kinda erroneous.
You could just load MapInstall by itself to load your maps. You can find out how to use MapInstall, and get the latest version by checking here.
Old 11-28-2012, 07:43 AM   #6028
atlas cached
OX Ambassador
Oddometer: 688
Bought 2 uSD cards
Now i read this:
WTF!?!?!
Everything you ever wanted to know about loading maps to your Garmin GPSr, but were afraid to ask, can be found here.
Old 11-28-2012, 08:41 AM   #6029
Bli55
Oddometer: 376
Security screw fix
After being unable to twist the screw out, i resorted to doing it properly.
Start off by unscrewing 6 tiny screw and taking off the back panel.
Then take out the button sliding part (hold the tiny spring!!!) and the top (hold the tiny spring!!!):
Now with access to the inside, we see the culprit. Pry it off.
Luckily, Garmin is sane (unlike RAM with their 11mm nut for a large-pitch threaded U bar...) and uses a standart pitch M3 thread. So to a bolt shop I go.
You know the standart screw has threads only at the very end and the thinner stalk moves freely in the hole in the top plastic part. I needed to duplicate that, except that I chose to leave a few more threads at the end.
And if you don't have a lathe:
The standart bolt stops not when the threads go all the way into the well, but when the bolthead touches against the plastic - so it's ok the leave more thread at the end as long as there's something on our new bolt to push against the plastic top part (to mimic the standart bolthead).
In my case, a long "handle":
Put the new bolt in with,remembering it's cone shaped spring, then slip on the retaining clip from the inside (you can leave it out if you think there will be a need to remove the lock screw without taking the mount apart again).
Then put the 2 plastic parts together. Do I need to mention the tiny springs?
They fly far once being bounced off your head and can only be found by lucky chance inside some camera cases.
And don't think breaking a lighter will save you!
Result:
Bli55 is online now   Reply With Quote
Old 11-28-2012, 08:46 AM   #6030
Bli55
Oddometer: 376
Originally Posted by ramz View Post
The replacement screw I'm using is threaded all the way, so when I screw it into the case, it does not sit loosely held in by a clip. When I want to lock the release mechanism, I screw the replacement screw all the way in using an allen wrench. It is a bit more awkward
I won't have a torx security head, just an allen head, but the screw will be the correct length.
If you go through the trouble, might as well eliminate the need to use any tool to operate the mount.
By using a MUCH longer bolt and some "handle".
Or a machined version - http://www.advrider.com/forums/showthread.php?t=223922.
Times are GMT -7.   It's 09:48 PM.
