Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 462 votes, 4.94 average. Display Modes
Old 12-04-2012, 03:33 AM   #6106
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,947
Originally Posted by Rocky TFS View Post
Try this: Setup-> Shortcuts-> Create shortcut-> Name="Reset ODO", You will find a red 180 turn Icon to use, No change to Profile, Setup->Page down to Reset, "Reset Trip Data-> ON, back to shortcut page, No Where to?, Application to "Map". Then "Add to Menu". Move it to Drawer later if you want.
I have a similar one I called "Reset Trip and Track" and it's accessible through a single push on the power button. Each morning before I go for a ride, it only takes a second to get ready using that Shortcut.
Old 12-04-2012, 07:09 AM   #6107
Rocky TFS
Rocky TFS's Avatar
Oddometer: 605
Originally Posted by Windrock View Post
Good stuff, Thanks, Got anymore handy shortcuts?
Sure:
Go Home (because of the aggravation of the Montana making multiples of Home, I set another waypoint called Home1, which is NEVER used in any route I build in Basecamp. Otherwise, as soon as you get multiple routes with Home in them, the shortcut ceases to work.)
Track log ON
Track log OFF
Gas Services (finds nearest gas)
Topo (changes map and profile to Topo)
Pavement (changes map to CNNA, profile to BMW Paved)
The last two basically switch back and forth between avoid and don't avoid unpaved with a different icon and background, as well as between the two maps. For me, my Topo maps don't support routing, so they also change between Direct and Automotive Activity.
Shortcuts are one of the coolest things about the Montana!
Rocky TFS is offline   Reply With Quote
Old 12-04-2012, 08:04 AM   #6108
number9
number9's Avatar
Oddometer: 313
Don't do that again!!!
This does not change anything except resets just the odo, times, speeds, etc., and returns you to the map in one second! I use it all the time. Put it in all profiles.
NICE!!! Thanks for that!
2000 Yamaha YZ250
2009 Yamaha YZ250
2013 Kawasaki Ninja 1000
number9 is offline   Reply With Quote
Old 12-04-2012, 08:10 AM   #6109
number9
number9's Avatar
Oddometer: 313
Originally Posted by TravellingStrom View Post
It would be nice if on the map screen when navigating and you select the triple bar menu option that the bottom option restore defaults was removed
I hate trying to use SETUP MAP and hitting RESTORE DEFAULTS it is a stupid place for it and should have a confirmation query before doing so at least
I agree!! Someone should submit this to the Montana dev team
2000 Yamaha YZ250
2009 Yamaha YZ250
Old 12-04-2012, 08:14 AM   #6110
Windrock
Windrock's Avatar
Oddometer: 21
Shortcuts would be even cooler if Garmin would implement some kind of Macro Language so you could have complete control of some of the functions. You could then build Custom Shortcuts exactly the way you would want them to work. Seems like maybe a simple thing to do.
Trail Maintenance Supevisor - Windrock Park Trails
Oliver Springs, Tn
Trail Machine: 2013 Polaris RzR 570 LE
Windrock is offline   Reply With Quote
Old 12-04-2012, 08:23 AM   #6111
gots_a_sol
gots_a_sol's Avatar
Oddometer: 488
I highly doubt this, but is there a way to make your current speed not light up red when going above the speed limit? I feel like it is judging me
06 Husky TE610
09 Husky WR165 - VCHSS #79L
gots_a_sol is offline   Reply With Quote
Old 12-04-2012, 08:58 AM   #6112
SKINNY
SKINNY's Avatar
Oddometer: 668
The legal speed limit in Texas is 70/75/80 depending on where you are, but Garmin/Navtech apparently thinks the speed limit is 65 mph, so I'm always in the red...
SKINNY is offline   Reply With Quote
Old 12-04-2012, 08:59 AM   #6113
number9
number9's Avatar
Oddometer: 313
It doesn't do that with the Small Data Fields dashboard, but does in the Nuvi dashboard.
2000 Yamaha YZ250
2009 Yamaha YZ250
Old 12-04-2012, 09:30 AM   #6114
Rocky TFS
Rocky TFS's Avatar
Oddometer: 605
If you are going above the speed limit you should be looking for cops instead of at the GPS!
And no, you can't, not if you are using the Nuvi dashboard.
Old 12-04-2012, 09:39 AM   #6115
TowPro
Lets ride
Oddometer: 3,298
Go into the unit storage, view the XML code file named the same as your current shortcut. This might get you pointed in the right direction.
EDIT: Add the Id-10T disclaimer.
Please backup your shortcuts and profiles first.
TowPro is offline   Reply With Quote
Old 12-04-2012, 09:48 AM   #6116
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 6,143
Originally Posted by cyborg View Post
My guess what works is the Nite Ize Backbone Case Size #20 Medium/Tall
http://www.amazon.com/Nite-Ize-Unive...f=pd_sbs_cps_5
http://www.niteize.com/product/Backb...se-Size-20.asp
I ordered the Small too from GPS City at the recommended link and haven't gotten it yet, and it was too cheap to bother returning, so I'll use it for something else.
Sorry for the confusion...I just grabbed a link to the NiteIze product.
The one I have is the: NiteIze Black Backbone Case Medium Tall, Model: NBB-03-20BLK
Cheers,
Dan - All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 12-04-2012, 09:58 AM   #6117
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Cheers,
Hey, that's what we get for believing something we read on the internet...
atlas cached is offline   Reply With Quote
Old 12-04-2012, 10:44 AM   #6118
DRTBYK
DRTBYK's Avatar
Oddometer: 6,143
The Shortcut simply calls "Profile-tags". And you would need to know the integer range for a given Profile-tag. Then of course you would find that all of the features you may want to "code" in your custom Shortcut were not available settings in the Profile (no Tag). Example: Camera ON/OFF - here is no Profile-tag for Camera.
Profile's appear to be "lookup tables" that the configuration code on the Montana uses to "setup" the unit.
Cheers,
Old 12-04-2012, 12:39 PM   #6119
number9
number9's Avatar
Oddometer: 313
I just did your shortcut except I made the Trip Computer the app to launch instead of the map. I figured I'd be in the Main Menu when I launch the shortcut anyway, and I'd like the Trip Computer to launch so I can confirm it was reset.
Thanks again for this!!!
2000 Yamaha YZ250
2009 Yamaha YZ250
Old 12-04-2012, 12:51 PM   #6120
atlas cached
OX Ambassador
Oddometer: 688
For those who want an overview of which options are currently available when creating Shortcuts on Montana, you can see that here.
atlas cached screwed with this post 12-04-2012 at 02:56 PM
Times are GMT -7.   It's 03:09 PM.
